micah
Posted: Fri Mar 10, 2006 6:29 pm Post subject:
UGH! Micro Mod and Midi in OSX |
OK, Just got the gen 1 micro mod.
I am an experienced synthesist and studio owner but for some reason I cannot get the MIDI setup working in the OSX beta editor. I've tried 2 different USB midi ports. There isn't even an error message. It just says "Looking" and then "Still Looking" and never stops looking. I assume the PC IN port goes to the MIDI IN of my interface. I can't figure it out.
Any help would be much appreciated.
Micah |
Posted: Fri Mar 10, 2006 6:31 pm Post subject:
OS X? Which version? Which mac? Which midi interface? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
micah
Posted: Fri Mar 10, 2006 6:38 pm Post subject:
Oh, good point. Sorry>>
OS: 10.4.5
MAC: 1.5GHZ Powerbook G4
MIDI Interfaces: Evolution X-Session, Edirol PCR-M1 |
Posted: Fri Mar 10, 2006 6:56 pm Post subject:
I am using a dedicated mac for the editor app and a battered midisport thingie for midi. I don´t think I can easily debug this one. I guess you have already checked the cables and whatnot? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
micah
Posted: Fri Mar 10, 2006 7:12 pm Post subject:
yeah, i've checked all the cabling, switched it etc. also looked for other posts with the same problem.
I also tried a Midisport. Does the Midi Setup in the editor usually give a notification if things aren't set up properly? I mean, it just keeps on searching for it. |
Joined: Apr 03, 2004 Posts: 24454 Location: The Netherlands, Enschede
Audio files: 297
Posted: Fri Mar 10, 2006 7:33 pm Post subject:
Searching, that;s what it does when it can't finf the synth, and searching stops when it found it. Not very informative indeed.
Did you check the midi ports to be working for other purposes ?
Do you have a sequencer program installed maybe that claims all midi ports it can find ? _________________ Jan
micah
Posted: Fri Mar 10, 2006 7:48 pm Post subject:
yeah, i hooked it up to logic and the MIDI IN was working fine - I was able to play the patches. Is the PC IN/OUT like a regular MIDI port? I assume I cannot hook the editor up to the MIDI ports on the Micro Mod but only to the PC in/out. Right?
All My MIDI ports work fine. Very Strange.... and frustrating |
Audio files: 297
Posted: Fri Mar 10, 2006 8:12 pm Post subject:
micah wrote: | I assume I cannot hook the editor up to the MIDI ports on the Micro Mod but only to the PC in/out. Right?
Assumption correct, can feel your frustration, it can work, it can be a long search sometimes though, on a PC as well. There is http://nm-archives.electro-music.com/010_NordModular/018_FAQ/ but it has no OSX section on connection trouble. _________________ Jan
micah
micah
Posted: Sat Mar 11, 2006 7:43 am Post subject:
I'm wondering if there is a problem with them PC IN/OUT ports. Is there any way to check these without using the editor? |
Audio files: 297
Posted: Sat Mar 11, 2006 10:26 am Post subject:
micah wrote: | I'm wondering if there is a problem with them PC IN/OUT ports. Is there any way to check these without using the editor? |
Maybe .. when you have a software that can act like a midi spy. I'm not 100% sure but I think the MM sends out some sysex repeatedly to it's PC port to invite a conection with the editor. With some effort I think I could come up with a sysex command that you could send to the MM to which it should reply then.
For a PC midi-ox would be a good program, but for the Mac I wouldn't know. _________________ Jan
micah
Posted: Sat Mar 11, 2006 10:36 am Post subject:
yeah, you sure are right. plugging the PC out into the MIDI in port delivers a constant MIDI led.
I wonder, is there a way to factory reset the micro? Or something? Man, I cannot figure this out  |
Audio files: 297
Posted: Sat Mar 11, 2006 10:42 am Post subject:
I don't think the problem is with the micro actually ... but it would be best to check that of course ... do you have another computer somewhere to try, maybe a friend or a neighbour ? _________________ Jan
micah
Posted: Sat Mar 11, 2006 10:47 am Post subject:
HA! I got it!
Oh man, I am way too embarrased to even describe what the problem was, and i'm very sorry for wasting anyone's time  |
Audio files: 297
Posted: Sat Mar 11, 2006 10:59 am Post subject:
Good !
but you _must_ tell  _________________ Jan
Audio files: 297
Posted: Sat Mar 11, 2006 11:00 am Post subject:
(just to avoid others making the same mistake :-) _________________ Jan
Posted: Sat Mar 11, 2006 11:05 am Post subject:
micah wrote: | HA! I got it!
Don´t tell us, we already know you have gnomes inside your mac.
Flickr |
Gothboy
Joined: Feb 21, 2006 Posts: 371 Location: Santa Monica, Ca.
Posted: Sun Mar 12, 2006 5:56 pm Post subject:
Let me guess....You had the micro plugged into to like, Port 7 on the midisport and didn't realize you had to have it on one of the first 4 ports? This is what I did the first time around and nearly went mad. _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.11.6/El Capitan
Novation SL49, Behringer 2600, Crave, Edge
Mophox4, Nord Lead 2,Modal electronics Argon 8m, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland d-05, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE, Korg ER-1, Unosynth
Dymaxion Vehicle Music at www.dymaxionvehicle.com/ |
cappy2112
Joined: Dec 24, 2004 Posts: 2495 Location: San Jose, California
Posted: Sun Mar 12, 2006 10:36 pm Post subject:
Hey- you're not the first one to get the ins&outs confused.
This is the reason I have my cables color coded- particularly on the Nord Modular |
Joined: Jan 31, 2003 Posts: 18249 Location: Durham, NC
Audio files: 226
Posted: Mon Mar 13, 2006 12:37 pm Post subject:
When I had a NM1, I used to always confuse PC IN and PC OUT. It is not obvious what that means. I'm always confused anyhow, so the NM1 made me feel quite comfortable.  _________________ --Howard
my music and other stuff |
GovernorSilver
Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
Posted: Fri Mar 17, 2006 8:17 am Post subject:
My money is on Micah discovering a bad MIDI cable after all.
Of course my opinion is colored by my own very recent experience. I learned that if you buy MIDI cables in pairs so that they are attached to each other, one of them can still go bad while the other one still works! Doh! |
saturnineproductions
Posted: Sat Apr 29, 2006 4:28 pm Post subject:
sorry to say. i'm having this very problem. i've just gotten my nord modular, installed everything i think/thought i needed and still the mac doesn't seem to recognize it.
i'm not a total tard, but i think i might need some help with this.
i'm running 10.4.6
nord modular nm1
i've got the midi ports connected to:
korg microkontrol (in)
electribe er-1 (out)
and the pc ports are connected to
m-audio 1x1 midisport.
please please please? |
Posted: Sat Apr 29, 2006 4:41 pm Post subject:
The usual problem is to mix up which "pc" ports are in and out..  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sat Apr 29, 2006 4:53 pm Post subject:
tried switching those. i got a lot of noise... i can only assume the noise is due to reversed cables.
still trying |
Posted: Sat Apr 29, 2006 4:56 pm Post subject:
Hmm..
This is weird. I dunno. I am using a G4 just for the editor app. I am not running any other midi stuff on it at all. I have never actually tried running he editor from the main DAW. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
