Dumping CC's from controller patch
Page 1 of 1 [11 Posts]
BobTheDog
PostPosted: Tue May 02, 2006 10:45 pm    Post subject:  Dumping CC's from controller patch Reply with quote  Mark this post and the followings unread
Hi Guys,
I'm having come difficulty with a controller patch I am doing for the Arturia Minimoog.
When I press shift/patch on the keyboard to dump the CC messages out, the G2 is not sending "midi control send" or "midi automate" CC values.
So I have rigged up a momentary switch to the send of one of the "midi automate" modules and then daisy chained all the others to this.
So now when I click the momentary switch it sends all the CC's which is super.
So now I can press shift/patch and my momentary button and all CC's are properly sent. This is a little tedious!
So I have a few of questions.
1. Is it possible to set the G2 up so that shift/patch sends all CCs for all modules?
2. Is it possible for me to trigger the other modules (switches etc) to send their cc values from my momentary switch?
3. Is it possible to make all this automatic when a variation changes?
4. How do you turn lead into gold?
Andy
BobTheDog
PostPosted: Tue May 02, 2006 10:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have worked out how to send the "midi control automate" CCs on var change useing the Status module, so now when my variation changes it sends the CCs, hooray.
So now I am just stuck not being able to send switch values automatically.
Andy
BobTheDog
PostPosted: Mon May 08, 2006 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Guys,
I cannot believe you are all stumped by this one, or is it not possible?
Andy
Audio files: 231
PostPosted: Mon May 08, 2006 5:18 am    Post subject: Reply with quote  Mark this post and the followings unread
It stumps me. I've never tried it.
Audio files: 299
PostPosted: Mon May 08, 2006 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
and me too, really no idea ...
BobTheDog
PostPosted: Tue May 09, 2006 1:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Guys,
So I am not alone!
Maybe I should put it on the feature request list.
Thanks for replying
All the best
Andy
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue May 09, 2006 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Andy,
Disclaimer: I don't have the G2 here right now, so I don't know if this patch will work.
It uses a cc send and recieve to talk to the device (on CC #12 for in this example), while the midi cc recv maps the value to another controller (#13), on slotA which happens to be midi assigned to the 1-8 switch.
this solution eats up 1 extra controller for each thing you are trying to controle with a switch.
Let me know if this works or if it helps you.
/Dasz
SwchAutomate_DZ.pch2
 Filename:  SwchAutomate_DZ.pch2
 Filesize:  955 Bytes
 Downloaded:  1621 Time(s)
BobTheDog
PostPosted: Thu May 11, 2006 4:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Dasz,
Thanks for this, I am away from the G2 at the moment. When I get back I will give it a go.
Andy
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu May 11, 2006 8:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lemme know ... curious ...
/Dasz
BobTheDog
PostPosted: Fri May 12, 2006 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Dasz,
It did not quite work. The values send on CC12 where not in the full range 0-127.
I have modified it to scale the input into the CtrlSend and it works great.
Thanks for the help, it is very good of you.
All the best
Andy
swchautomate_dz_scaled.pch2
Slight variation on previous patch to scale to get correct CC values
 Filename:  swchautomate_dz_scaled.pch2
 Filesize:  999 Bytes
 Downloaded:  1997 Time(s)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri May 12, 2006 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sweet! That's exactly what I was expecting!
/Dasz
