My twin SN-Voice
Page 4 of 18 [428 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, ..., 16, 17, 18 Next
PostPosted: Mon Nov 13, 2006 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can put one of the round metal can types into an 8 pin DIP footprint. That's what's on the ASM2. I've put MAT02s into the 8P-DIP on that, and it works fine. (With room for a tempco to lay erotically underneath each one Laughing Wink )
sneakthief
PostPosted: Tue Nov 14, 2006 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Same here, Unkle Krunkus - all of my ASM Vco's (ASM-2 & Bi-N-Tic) use MAT-02 metal cans and I have them working perfect in 8-PIN DIP IC-sockets.
Bill, do you have any reasons why one should avoid doing this?
michel
Sneak-Thief - raw electrofunk
Scott Stites
Audio files: 96
PostPosted: Tue Nov 14, 2006 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Balancing play, family, and work is a challenge my friend.
It's really quite easy - all you have to do is enslave them in your DIY mill. For example, I've chained my son to the breadboard and I'm always sure to feed him when he gets results. My wife, bless her heart, has finally learned that her soldering efficiency is directly linked to how much time she gets in the excercise yard. We're all one big happy family!*
Scott
*As long as you keep the other members separated, of course. They tend to hatch plots of escape when they're placed too close together.
PostPosted: Tue Nov 14, 2006 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wrote:
Just make sure when you all purchase the LM394 matched transistor pair that you get the 8-PIN DIP style package. The board will not use the metal can
I retract this statement .... Embarassed
Yup, you fellas are correct. You CAN use METAL CANs if you sort of shape the legs a bit. I was thinking strictly asthetics at the time .... Very Happy So, if you have a can, use it for sure Very Happy
I put in for the manufacture of 60 boards! The documentation is done, the connectors, sockets (except the skinny), headers and pins are all ordered! I will be getting the first run of PCB's in 14 days. I will build up a board for personal use and check things out.
If all is a GO, I shall give you all pricing and start the ordering process! The board price is firm at $18.00 each. I will price the connector kits soon.
More soon!
Bill
mono-poly
PostPosted: Wed Nov 15, 2006 4:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Let me know if i can signup for 2 boards Smile
PostPosted: Wed Nov 15, 2006 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure, I am doing a run of 60 boards. When I post the announcement for orders, it will be first come first serve. I will, however, treat all the people on this thread, ordered by date posted, as being the first in line so you are in sir ... Very Happy
Bill
PostPosted: Wed Nov 15, 2006 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy Very Happy Very Happy Hmmmm, so thats the secret !!!
PostPosted: Wed Nov 15, 2006 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
State Machine wrote:
Balancing play, family, and work is a challenge my friend. Shocked
First and foremost, BE HAPPY !!!
aww- State Macheee, thanks for the kind words Very Happy
Its a pisser indeed- and here I am hangin on EM when I really should be........ Shocked Laughing
ACHTUNG!
Scott Stites
Audio files: 96
PostPosted: Wed Nov 15, 2006 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, and it delivers in spades! Here's a pic of my little Igor delivering my Triple EG module ahead of schedule.
That Howard Moscovitz, he's just an electro-music enabler!
Cheerio,
Scott
Now where's my Popcicle?
 Filesize:  29.78 KB
 Viewed:  13174 Time(s)
germaniac
PostPosted: Wed Nov 15, 2006 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Friends,
Any chance the LM394 can be subbed with a 2SC1583? I have some of those on hand. . . .
BTW, awesome-looking board Mr. Machine!
Ah, so THAT'S how you're able to get as much done as three people! I always secretly thought you had a clone or a robot or an evil twin named Truman S. Barksdale or something. . . .
Regards,
Joe
Scott Stites
Audio files: 96
PostPosted: Wed Nov 15, 2006 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
A 2SC1583 would work, not quite as well as the LM394, but it certainly would be doable, I'd think. Might take some pretzlizing to fit into the PCB.
Barksdale actually authored the more psychotic Klee samples - Third Eye Tiara was the centerpiece of a suite he'd been working on. Got turned down on his application for that Ice Capades gig (for which these samples were demos), and went missing again. Local authorities are baffled and they've tightened security at TI. It's a shame - if anyone could market "Buns of Klee" it would be him.
Cheerios,
Scott
PostPosted: Wed Nov 15, 2006 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is a great picture !!! I love it!
Hmmmm, hey, no ESD strap! Oh Scott, what were you thinking? Very Happy Very Happy
Bill
PostPosted: Wed Nov 15, 2006 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
The SN voice board has the TEMPCO over the top of the LM394. A bit of thermal compound will then be used to make a small fillet between the TEMCPO and the body of the LM394 to equalize the temperature.
Bill
 Filesize:  10.04 KB
 Viewed:  13148 Time(s)
Scott Stites
Audio files: 96
PostPosted: Wed Nov 15, 2006 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
The ankle chain has a 1M resistor to ground Very Happy
fluxmonkey
PostPosted: Wed Nov 15, 2006 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bill
if this is the queue, then I better line up... 2 for me, por favor!
bbob
chonald
PostPosted: Wed Nov 15, 2006 7:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ohhh. Has anyone started designing a front panel?
I think this would be next in line.
synthmonger
PostPosted: Thu Nov 16, 2006 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice work!
I'd also be interested in a couple PCB's. Pre-made pcbs are a huge time saver 8D
PostPosted: Thu Nov 16, 2006 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
which format do you have in mind? my modular is in eurorack and i use schaeffer front panel designer...
sneakthief
PostPosted: Thu Nov 16, 2006 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Some layouts:
1. Scott Stites' 19" front panel (PDF of this available along with SN-Voice schematics on Scott's SN-Voice page http://mypeoplepc.com/members/scottnoanh/birthofasynth/id22.html
2. Tim's (aka Servo at Magic Smoke) Euro-rack layout:
3. My Frac-rack layout:
PostPosted: Thu Nov 16, 2006 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
hey sneakthief,
i like your layout the most. why? if you have a small panel format (like euro or frac) IMO it's the best to have the pots in rows. tim's layout will be a little bit harder to operate...
and i like the idea to have the trimmers panel mounted. that makes it much easier to calibrate afterwards! i will incorporate this feature in my future projects, i think.
chonald
PostPosted: Thu Nov 16, 2006 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd be interested in a MOTM front panel.
It's just too bad i can't run Front Panel Express on a Mac.
Cole
sneakthief
PostPosted: Thu Nov 16, 2006 6:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Vielen Dank Matthias!
If anyone is using my layout as a basis for their own and doesn't want the 556-mixers, they should use something like this layout instead - it adds a knob for PWM and one between Attack & Release called "Env". It controls envelope speed - the mod for this is on Scott's page.
PostPosted: Thu Nov 16, 2006 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Cole
Perhaps that app might run in Crossover/Vine
http://www.codeweavers.com/products/cxmac/macdeal/
Flickr
PostPosted: Thu Nov 16, 2006 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Front Panel Express seems to be running fine on my Mac now. Try Crossover! Very Happy
Flickr
chonald
PostPosted: Thu Nov 16, 2006 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
"Note: CrossOver Mac requires an Intel based CPU in your Mac"
I have an older Tiger, with a PowerPC chip. So it won't work.
