My twin SN-Voice
Page 8 of 18 [428 Posts]
Goto page: Previous 1, 2, 3, ..., 6, 7, 8, 9, 10, ..., 16, 17, 18 Next
PostPosted: Sun Dec 10, 2006 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I just put in an order for one... the socket for the SN in the socket kit, is that for a wide or a thin body SN? I figure if you're getting this many orders this fast, I'd better acquire my SN now, lest our sources dry up!
It's for the wide body. The Thin Mill-Max socket was a bit steep in price. I just soldered mine to the PCB .... I still have a good supply of boards, about 30 left !!!
Bill
shawn
PostPosted: Sun Dec 10, 2006 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
AY-89xx series huh? I have 2 or three of those as well!
Glad I scored my boards now. I'm not suprised they are selling so quick.
bdu
PostPosted: Sun Dec 10, 2006 5:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
[quote="State Machine"]
Yeah, I'm more worried about the sudden availability of an sn76477 project that everyone's building would sink the current sources of the chip ;0)
So I just ordered a wide body so I know that'll be here!
Thanks for getting these done up, ought to play nicely with my MIDINES and MIDIbox SID-NUXX (not to mention the modular!).
questionable
PostPosted: Sun Dec 10, 2006 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
i just ordered the chips as well. are there gobs of these chips sitting around out there, or is this something where the chip supply could potentially dry up?
Sounds Questionable
Tenine
PostPosted: Mon Dec 11, 2006 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Tenine wrote:
(I was born here, not sent Wink )
Shocked Confused Laughing Question Question
LOL!!!
So Cov has been gentrified too?
Squeezed out by a yuppie wielding a pasta machine? Shocked
Laughing
Well, I'm not sure if I'd say it has or not.
You could come to both conclusions at first glance,
but change your mind upon closer inspection.
Pasta machine!?
I have a few guitar/bass pedal ideas to get out of the way first, but
I think I'll try this project.
If not, I think the SN chip would make a good drum voice Smile
mhapps
PostPosted: Tue Dec 12, 2006 2:37 pm    Post subject: sn76477 narrow and wide body Reply with quote  Mark this post and the followings unread
I have about 50 of each of the wide body and narrow body SN76477's left at www.arcadechips.com Here is a link to all the sound chips I have listed
http://www.arcadechips.com/forums.html?cPath=27_22
Shipping is cheap worldwide or in the US.
Does anyone have a datasheet on the 76488, I have the 76477 but no 76488
Thanks to all who have been buying these lately and all orders are on the way,
Mark Capps
www.arcadechips.com
PostPosted: Tue Dec 12, 2006 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I dug this link up so far ....
http://www.physicsenterprises.andrews.edu/diy_archive/manuals/misc/index.html
Bill
Bill
volare
PostPosted: Tue Dec 12, 2006 9:30 pm    Post subject: SN76488
Subject description: PDF file
Here is the pdf file from the gif files
Sn76488.pdf
 Filename:  Sn76488.pdf
 Filesize:  758.43 KB
 Downloaded:  476 Time(s)
mhapps
PostPosted: Thu Dec 14, 2006 3:51 pm    Post subject: Thanks for the pdf. Reply with quote  Mark this post and the followings unread
I just wanted to that you for the pdf file for the 76488!!!
Mark Capps
shawn
PostPosted: Thu Dec 14, 2006 9:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
very cool, saved me the hassle of finding a scanner!
PostPosted: Fri Dec 15, 2006 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
20 boards left! It's been a busy week! I kept two for myself and want to get rid of the remaining 20. Thanks to everyone who purchased PCB's and connectors thus far.
Whatever is left, I will try to sell on Ebay since "SVdistributing", an Ebay store, is selling SN76477's and other groovy sound chips from TI, GI, NS, etc .. I will also link Arcade chips website as well since they have done us good!.
Thanks again,
Bill
mono-poly
PostPosted: Fri Dec 15, 2006 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok i made a modcan layout witch will fit in a double width cyndustries panel.
I can not make a jpg of the layout yet.
Need to find out how i have to realize that.
Comments and suggestions are welcom ofcourse.
Oow i added an extra socket for a switch to manual gate the envelope.
mono-poly
PostPosted: Fri Dec 15, 2006 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok and the design.
thomas hendry sn76477.fpd.zip
thomas hendry sn76477 modcan format
 Filename:  thomas hendry sn76477.fpd.zip
 Filesize:  2.64 KB
 Downloaded:  348 Time(s)
questionable
PostPosted: Fri Dec 15, 2006 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
mono-poly, you could just take a screenshot of that window and post that.
Sounds Questionable
mono-poly
PostPosted: Fri Dec 15, 2006 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
voila
 Filesize:  36.4 KB
 Viewed:  8130 Time(s)
PostPosted: Fri Dec 15, 2006 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks nice !! Good job. I took the liberty to post your panel, I hope you don't mind.
I have one suggestion, you might want to make the numerics around all the pots just a bit larger. They (1 to 10) sort of get lost. making them larger will improve this. Also, make sure the radius is large to accommodate the knob. Very Happy
Just a bit of constructive critique.
Bill
 Filesize:  33.47 KB
 Viewed:  10306 Time(s)
PostPosted: Fri Dec 15, 2006 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
What are the panel dimensions just out of curiosity?
ACHTUNG!
PostPosted: Fri Dec 15, 2006 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="mono-poly]
[/quote]
Okay. Are you using photoshop??
ACHTUNG!
mono-poly
PostPosted: Fri Dec 15, 2006 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
I just use ms paint hahaha and the schaeffer software.
I am not happy about the knob scales yet they are to thin.
When i get at work this night i'll ask a collega to make some nicer ones in viso.
He is pretty good in viso and i will convert them to hpgl then.
Sorry i am not sure about the panel size yet but it is the exact size of a double size Cyndustries blank panel.
Hopefully i get a reply on my email about purchasing some boards Smile
Now i am gonna design some panels for the standard wogglebug.
PostPosted: Fri Dec 15, 2006 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I could knock up a front panel in Solidworks and save it as a DWG/DXF/STL file if you want?
ACHTUNG!
PostPosted: Fri Dec 15, 2006 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
a tape measure? A ruler??
Laughing
ACHTUNG!
PostPosted: Fri Dec 15, 2006 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey mono-poly. this panel really looks nice. its good to have that much space on a frontpanel (i build in eurorack format Sad ).
you have a pot for PWM. i can't find it on the schem. maybe you did the same mistake as me and took the 3pos turning switch for a pwm pot or do you plan to do such a mod?
or maybe i just missed something...
Dan Lavin
Audio files: 21
PostPosted: Fri Dec 15, 2006 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
mono-poly:
Um....who's Thomas Hendry? You might want to give Thomas Henry credit on the panel. He doesn't seem like the jealous type, but you never know!
mono-poly
PostPosted: Fri Dec 15, 2006 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
The only problem i have now that the BMP i got for the pot scaling almost match the ones used with Modcan/Cyndustries.
If someone could help me out with a better design that would be so great!
Yeah Fonik i did use your design a bit for the panel to look if i had all contacts/pots/switches so that's how i made the same mistake Shocked
Oow yeah what a stupid typo about Thomas his last name.
Gonna have this all fixed tomorow.
