Posted: Fri Dec 15, 2006 12:38 pm Post subject:
mono-poly wrote: | The only problem i have now that the BMP i got for the pot scaling almost match the ones used with Modcan/Cyndustries.
If someone could help me out with a better design that would be so great!
I'll help you out
jpegs, bit maps and the like are great for images which need resizing, but for front panels, they're a joke.
I recommend that you buy a copy of Q-cad by Ribbonsoft. It's only $26. Q-cad will save both a BMP/ PNG/ PDF file etc- so you can post it here for everyone to have a look at, and it will also save to DXF, which has all your metadata and is the industry standard technical document format (and DWG too!).
Also get GIMP. It's like Illustrator/ Photoshop, yet it's FREE!
But I need those front panel dimensions for the modcan stuff. _________________ ACHTUNG!
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Fri Dec 15, 2006 12:50 pm Post subject:
The circle is about 16mm and 22m (midddle / outside)
Here is an example from a panel from her site.
Posted: Fri Dec 15, 2006 1:59 pm Post subject:
mono-poly wrote: | The circle is about 16mm and 22m (midddle / outside)
I need more info than that I'm afraid. I need the measurements in Height, Depth and Width (in mm) for the front panel. I also need the exact width of the collar of the knob (the piece nearest the panel).
Also are the pots miniature or standard?
Did you see my Q-cad mock-up of the modcan frontpanel decal on the wogglebug thread? _________________ ACHTUNG!
Posted: Fri Dec 15, 2006 6:01 pm Post subject:
LATEST REPORT:
Got another spike in sales:
Only 12 Boards , 12 socket kits and 2 connector kits left !!!
Now, who will plan the SN Voice concert/convention ???
Bill |
Posted: Fri Dec 15, 2006 6:04 pm Post subject:
State Machine wrote: | Now, who will plan the SN Voice concert/convention ??? |
what a great idea  _________________ ACHTUNG!
Posted: Fri Dec 15, 2006 6:08 pm Post subject:
OR, even a bunch of us post some songs involving the SN Voice so we can burn some neat collections to CD-R and bounce around to the tunes as we drive to work! It would put a smile on our faces I am sure!
PS: I just packaged your board. It will go tomorrow in the mail ...
Bill |
shawn
Posted: Sat Dec 16, 2006 12:04 am Post subject:
Boards came today. Everything looks great. Even loved the colored staple for the docs!
Mine will be on hold until I finish my two soundlabs. Can't wait! |
Posted: Sat Dec 16, 2006 3:31 am Post subject:
shawn wrote: | Mine will be on hold until I finish my two soundlabs. Can't wait! |
LOL!!!
I started to build my ONE SoundLab TWO years ago. It STILL isn't finished!!
I did however, do some more work on the front panel the other day. It's now cut to shape  _________________ ACHTUNG!
krisp14u
Posted: Sat Dec 16, 2006 5:47 am Post subject:
got my pcb nice work State Machine hope you come up with more
cheers paul darlow |
Posted: Sat Dec 16, 2006 2:04 pm Post subject:
OR, even a bunch of us post some songs involving the SN Voice so we can burn some neat collections to CD-R and bounce around to the tunes as we drive to work! It would put a smile on our faces I am sure! |
Sounds good to me
Out of curiosity, what is the PCB design software called that you are using? Does it autoroute too? _________________ ACHTUNG!
Posted: Sat Dec 16, 2006 3:16 pm Post subject:
Quote: | Out of curiosity, what is the PCB design software called that you are using? Does it autoroute too? |
Well, I will be switching over to Eagle Layout but for now I am using the tried and true, at least for small projects, Express PCB. Fonik also uses it for his layouts. I also use Multisim 2000 Ultiboard and Ultaroute.
An autorouter is the way to go for larger multilayer projects since it is not as time consuming. It can take literally hours just to layout a simple 2 sided board like the SN Voice without one.
Autorouters come with a price, good ones cost big $$$. Eagle layout professional is about $1200.00 which is not bad and comes with a large database of part footprints and a schematic editor.
Look them up, you can get a base package for only $49.00 !!!
My forte' is really not PCB's though, but is in embedded systems, digital, and analog design. My real job is in radar and avionics design.
Bill |
Scott Stites
Audio files: 96
Posted: Sat Dec 16, 2006 3:26 pm Post subject:
Quote: | My forte' is really not PCB's though |
If that's the case, those really must be some far out embedded system and radar designs! The SN-Voice PCB is as good as it gets, people. If you're sitting on the fence as to whether to get one or not, I'd go for one before they're gone.
Scott |
Posted: Sat Dec 16, 2006 4:31 pm Post subject:
State Machine wrote: | I will be switching over to Eagle Layout but for now I am using the tried and true, at least for small projects, Express PCB. |
Ah yes Eagle. Very good. I haven't used it in a while, because of my University work. I think Eagle is the business, because it's multiplatform; unlike Express PCB which is PC only. But at least the latter is free
At first I had problems getting eagle to work- all that terminal stuff
However, I soon found a work around and printed a little guideline to getting it to work on Versiontracker.com;
Quote: |
1. Download Eagle 4.1 from Cadsoft and unstuff it using Aladdin Stuffit Deluxe (free download)
2. Download X11 from Apple's website (another free download )
3. Take the unstuffed download from your 'documents' folder (or wherever you have set the download folder to be in Safari). Take it and move it to your 'applications' folder.
4. Start up the X11 server and leave it running in the background
5. Locate the file marked 'bin' in the Eagle folder in your applications folder, open it and double-click
on the Unix exec file named "Eagle" (NOT "Eagle.1", with the logo). |
I don't know whether this still works with the latest version of Eagle, but I'll see in a sec
Interestingly enough, I used to know (through a friend) the guy who ran the pedal company Lovetone. I think his name was Dan? It's been a while...
Anyway, while Lovetone were developing new designs of pedals, they noticed one very peculiar thing, if components' positions on the boards were populated on the board in different layouts, or configurations, it would have a differing result to the final sound. It may be worth bearing this in mind. Of course Lovetone are strictly analogue, and use no digital components;
http://www.dinosaural.com/
http://www.lovetone.com/
- it was Dan! I just found him on the website The top one is the new address. Lovetone is there, but maybe he's not with them anymore? _________________ ACHTUNG!
Posted: Sat Dec 16, 2006 4:43 pm Post subject:
v-un-v wrote: |
Apple users;
Click on X11 server, then click on "Eagle" in bin file (with red logo). Forget the readme  _________________ ACHTUNG!
Posted: Sat Dec 16, 2006 4:52 pm Post subject:
Bill, I'm running Eagle now. It reminds me very much of Q-cad from Ribbonsoft- which also does schematics, but in a slightly different way. Q-cad also does dxf, it's really cheap and there's no size limit- which is really nice. _________________ ACHTUNG!
mono-poly
Posted: Sat Dec 16, 2006 7:05 pm Post subject:
I'm thinking about making a 4 voice synth of it  |
Posted: Sat Dec 16, 2006 9:27 pm Post subject:
Quote: | Bill, I'm running Eagle now. It reminds me very much of Q-cad from Ribbonsoft- which also does schematics, but in a slightly different way. Q-cad also does dxf, it's really cheap and there's no size limit- which is really nice. |
OK, cool. I assume you like it? I will likely get the full up professional edition some time after the holiday. I want to make sure I like it by using the "stripped" down edition for while. I don't like to make hasty decisions when it comes to engineering software.
Quote: | Ah yes Eagle. Very good. I haven't used it in a while, because of my University work |
Speaking of university work, I have a class to start: "Signal's and Systems" with lots of "Matlab" usage .... very intense I will be out of circulation for a bit of time because of this but will pop in from time to time to check on the forum.
Bill |
shawn
Posted: Sat Dec 16, 2006 10:43 pm Post subject:
Matlab isn't too bad. Had to mess with it some for my Applied Physics degree. Enjoy!  |
Posted: Tue Dec 19, 2006 3:15 pm Post subject:
State Machine wrote: | Quote: | the socket for the SN in the socket kit, is that for a wide or a thin body SN? |
It's for the wide body. The Thin Mill-Max socket was a bit steep in price. I just soldered mine to the PCB ....
Bill |
i had a hard time finding a socket for the narrow bodied SN at all! so i'm gonna use singlerow SMD sockets. they are quite cheap! _________________
Tech Buddy at Random*Source |
bigtex
Joined: Mar 30, 2006 Posts: 323 Location: Cupertino, California
Posted: Tue Dec 19, 2006 8:01 pm Post subject:
Wow, how could I have missed all of this??? Very exciting stuff!!! I've been away from electro-music.com for nearly two months
I'm going to buy two boards (I have two skinny SN76477s) and I just wanted to make sure you still have two left. As soon as I hear back that you've got some, I'll PayPal away.
Thanks for taking on the project of making a board available for everyone. Great!
Also, I highly recommend Eagle. I've used it for lots of projects and it's fantastic. Sometimes you have to fight with the autorouter a bit if you're anal about low via counts and pretty looking traces, but it's otherwise a great program. Very easy to add library components once you get used to the Eagle way of thinking.
I can't wait to finally use those SN76477s. They've been in my parts bin for over six years! |
Posted: Tue Dec 19, 2006 8:11 pm Post subject:
Quote: | Wow, how could I have missed all of this??? Very exciting stuff!!! I've been away from electro-music.com for nearly two months |
Hey Bigtex !!! How are you dude?? I was wondering where you went
Some of us has been doing lots of "Thomas Henry" type stuff this last few weeks!
Sure I have 8 boards left! I would act fast since tonight alone I have sold 6 boards. I may sell out by the end of the weekend.
Quote: | Also, I highly recommend Eagle. I've used it for lots of projects and it's fantastic. Sometimes you have to fight with the autorouter a bit if you're anal about low via counts and pretty looking traces, but it's otherwise a great program. Very easy to add library components once you get used to the Eagle way of thinking. |
OK great, I am convinced since I have heard some good FB from many of you on this software package ! Thanks for the details ...
Good to see you back !!!
Bill |
bigtex
Posted: Tue Dec 19, 2006 8:23 pm Post subject:
State Machine wrote: | Hey Bigtex !!! How are you dude?? I was wondering where you went |
Busy busy busy. Lots of work, moving to a new apartment, etc etc. Also been in a bit of a creative slump. But coming back to this board today and reading about all of the exciting goings on in the DIY world has got me excited! Actually, in the last week or so it's like my head has cracked open and tons of amazing new ideas have poured out into my comp book.
Order: placed.
2 x $18 per board + $4 for shipping = $40.
Can't wait to get these boards!  |
Scott Stites
Audio files: 96
Posted: Tue Dec 19, 2006 9:49 pm Post subject:
Quote: | I was wondering where you went |
Ditto! Nice to see you back.
Quote: | I may sell out by the end of the weekend. |
Holy cow!
Scott |
Posted: Wed Dec 20, 2006 4:30 pm Post subject:
Quote: | Holy cow!
Scott |
Holy cow is right my friend !!! I have 5 boards left now ... thats a BUNCH of 1V/Oct SN Voices out there !!!!
Bill |
Posted: Wed Dec 20, 2006 4:36 pm Post subject:
Quote: | Busy busy busy. Lots of work, moving to a new apartment, etc etc. Also been in a bit of a creative slump. But coming back to this board today and reading about all of the exciting goings on in the DIY world has got me excited! Actually, in the last week or so it's like my head has cracked open and tons of amazing new ideas have poured out into my comp book.
Order: placed.
Can't wait to get these boards! Very Happy |
Good luck with the apartment and glad to see your emerging from the "slump". I think we all do from time to time. The distraction from moving is certainly NO help Also, you need to fill us in on that groovy pile of Blacet stuff you have been constructing over the past few months ....
More good news is I will be shipping your SN Voice boards first thing tomorrow so hang tight, they will be there in a few days....
Bill |
