bit reduction/crushing
Page 1 of 1 [4 Posts]
Rinko
PostPosted: Sat Jun 28, 2008 4:05 pm    Post subject: bit reduction/crushing Reply with quote  Mark this post and the followings unread
hullo all!
just wondered if anyone could tell me how i can reduce the bitrate of an audio signal in chuck to get 8bit/lofi/chiptune sounds
cant find any info on this on here, in the manual or anywhere else Sad
thanks for your time!!!
PostPosted: Sat Jun 28, 2008 8:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure!
Here's one I prepared earlier for Atte;
https://lists.cs.princeton.edu/pipermail/chuck-users/2008-May/002913.html
I hope that's clear enough, if not do shout.
Rinko
PostPosted: Tue Jul 01, 2008 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
thank you!
i'll take a peak at that now...
edit: cool cheers! don't really understand it yet though so i'll have to go over it again later.
PostPosted: Tue Jul 01, 2008 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I wrote it for Atte who is a experienced ChucKist so I could assume he would grasp all of it without too many comments. I was also assuming a knowledge of sampling theory.
If the manual is not of help for the bits you don't quite get yet we can go over them, there's some interesting stuff going on that might actually be fun to go over if you'd like. Don't hesitate to ask. If you don't get it at all you can still use it, that's why I put all of the actual re-sampling in a function but of course you're way better off with code you get.
