G2 as effect processor?
Page 1 of 1 [10 Posts]
flextone
PostPosted: Thu Oct 30, 2008 4:58 pm    Post subject: G2 as effect processor? Reply with quote  Mark this post and the followings unread
Hey,
I'm considering buying a G2 engine to run my MPC3000 through it. How is it as an effect/modulation tool? And what about sequencing the MPC to create unusual patterns?
Would you recommend getting one?
Thanks
Tim Kleinert
G2 patch files: 236
PostPosted: Fri Oct 31, 2008 4:21 am    Post subject: Re: G2 as effect processor? Reply with quote  Mark this post and the followings unread
flextone wrote:
Hey,
In my opinion the G2 is the best modular hardware FX processor ever built, only surpassed by Eventide in terms of flexibility and sound quality. However it is far easier to use, and alot(!) cheaper than those.
There are a few caveats though. If you are looking for very high studio quality reverb, the G2 might disappoint you. The reverb module isn't exactly bad, but not stellar either. While I have no hesitations to use it live or as a subtle adjunct, I have my reservations about using it prominently in a professional mix.
Also, there has been some discussion about the quality of the AD and DA converters. These discussions seem to have a subjective component to them, with opinions on both sides. Personally I find the converters fine.
Different kinds of pattern generators -straightforward, algorithmic, chaotic, whatever- in conjunction with being able to send MIDI note and controller information from those, is an area were the G2 is truly unmatched by any other hardware system.
For the applications you described -absolutely.
flextone
PostPosted: Fri Oct 31, 2008 9:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Tim
Is 660$ a good price?
PostPosted: Mon Nov 03, 2008 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
flextone wrote:
Thanks Tim
I'd say that's an ok price, considering the difficulties people have in finding engines at all.
/Stefan
hyperstationjr
G2 patch files: 24
PostPosted: Wed Nov 05, 2008 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
As Tim alluded to, I wouldn't use the G2 as say, a replacement for a dedicated compressor or EQ, or even studio quality reverbs, BUT, if you wanted to get some interesting effects by way of modulation, or sequenced effects, or midi-automated effects, yeah, the G2 is perfect for that.
The out of box effects are there more out of convenience than actual usability, but the kind of stuff you can make is incredible. Someone on this board made a looper and delay-based "stutter" effects with just the G2... You can make all kinds of bit crushers and distortions...
Anyways I could do this all day, yeah, so long as you expect to have to make most of your own effects, I'd go for it...
Studio:
Analog Four Mk2, Digitone, Iridium Desktop, Nord Modular Rack, Nord Modular G2 Engine, Octatrack Mk2, Syntakt, Torso S4, Torso T1
For Sale/Trade:
Alesis Microverb 4, Panasonic RQ-705 Reel-to-reel, Roland Alpha Juno1, Roland R5, Yamaha TG55
flextone
PostPosted: Sat Nov 08, 2008 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Got one!
Watch this space for newbie questions
Roland Kuit
G2 patch files: 127
PostPosted: Sat Nov 08, 2008 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
HI welcome!
if you're looking for audio in patches, follow this link:
http://electro-music.com/forum/forum-51.html
flextone
PostPosted: Sat Nov 08, 2008 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
thank you roland !
GovernorSilver
PostPosted: Tue Nov 11, 2008 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
David Torn uses a G2 to convert nonrhythmic loops coming out of his customized Lexicon looper (PCM 42 I think) into rhythmic ones.
Definitely a nice creative sound processing tool, as long as you don't expect it to do better reverb than a high end Lexicon box, better delays than a high end tc electronic, etc.
Some old stuff on VIRB
flextone
PostPosted: Wed Nov 12, 2008 8:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thats sounds like what i'm doing with an akai s6000.
Any idea how does he go about doing this?
