TekniK
Posted: Sun Mar 21, 2010 3:57 am Post subject:
Any news abouth this project Juergen? |
Assrael
Posted: Fri Apr 23, 2010 11:37 am Post subject:
I'm in for two (2) boards. The MN3005 chips still on stock. |
dcreatorx
Posted: Fri Apr 23, 2010 11:49 pm Post subject:
boards |
I'll take two as well. |
(freakwincy)
Posted: Wed Apr 28, 2010 12:11 pm Post subject:
I would be down for 3 boards |
dcreatorx
Posted: Thu May 13, 2010 5:16 am Post subject:
how many ? |
Hi ! How many of them I need to buy to build 2 BBD modules ?
Thanks. |
jhaible
Posted: Thu May 13, 2010 8:24 am Post subject:
Re: how many ? |
dcreatorx wrote: | Hi ! How many of them I need to buy to build 2 BBD modules ?
Thanks. |
I plan to make something with 2 BBDs, but with an option to only use one.
If no one has reserved the name yet, I might call it "Living Delay" as a reference to emulating the liveliness of the early Dynacord BBD-based echo devices.
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Thu May 13, 2010 9:16 am Post subject:
Yeah "living delay". That's catchy.  |
/mr
Joined: Aug 05, 2007 Posts: 223 Location: Elektron City, Sweden
Posted: Thu May 13, 2010 9:53 am Post subject:
I have a vague feeling of some kind of trend here, in the JH naming conventions lately...
the next project must be a reverb - the "Living Room."  |
jhaible
Posted: Thu May 13, 2010 11:00 am Post subject:
/mr wrote: | I have a vague feeling of some kind of trend here, in the JH naming conventions lately...
adambee7
Posted: Thu May 13, 2010 9:19 pm Post subject:
Thats not a bad name either.  |
loydb
Joined: Feb 04, 2010 Posts: 393 Location: Providence, RI
Posted: Sat May 15, 2010 11:02 am Post subject:
And a distortion box called "Living Edge". |
rosch
Posted: Sun May 16, 2010 6:56 am Post subject:
i'd like to buy at least 1 pcb too.
how could one test a MN3005 without this? putting it in a deluxe memory man? i could do that (with the delay of a mate) but don't know if it's socketed.
is there an easy way to test functionality, like a stripboard circuit to take some measures? |
hoyager
Posted: Sun May 23, 2010 7:03 am Post subject:
I'd definitely vote for modulation, and a switch for just vibrato. Is it easy for something like this to be built with an onboard power supply?
Also is there a clock chip? or something needed to go with the 3005 or is there a modern equiv which can be used?
Andy |
blinosynth
mph
Posted: Mon Aug 09, 2010 2:51 pm Post subject:
I am in for one (maybe two ) board.
An onboard modulation would be nice too...
What a great project again.
Thanks JH! |
JoeMorris
Posted: Mon Aug 09, 2010 3:15 pm Post subject:
Is this still going to happen? |
TekniK
Posted: Mon Aug 09, 2010 9:09 pm Post subject:
I wander why this gets delayed over and over while new projects are born.
everybody did source and buy those expensive delay chips.. |
jhaible
Posted: Mon Aug 09, 2010 10:36 pm Post subject:
TekniK wrote: | I wander why this gets delayed over and over while new projects are born.
You wouldn't want me to stop working on the vocoder, now that I have finally gathered the momentum to do it, would you? - And I have to do things like that Trapezoid in between, for the simple reason that I have to earn some money and feed my family.
I'm pretty sure your BBD chips will get more valuable over time, not less.
TekniK
Posted: Mon Aug 09, 2010 11:36 pm Post subject:
The vocoder not,look here an overview of project introduction dates:
Project introductions:
Trapezoid : 25- jul-2010
Moog filterbank: 20-feb-2009
BBD: 1-mar-2009
Vocoder: 17-apr-2008 (reverse engineering in 2007)
Flanger: 8-apr-2009
Resonator: 16-feb-2009
Physical modelling: 19-mar-2010
No offence,its just to remember that you sugested that we buy delay ic's for the comming BBD project,i did buy 20 pcs ,so am getting a bit worry seeing the BBD project been delayed.. |
/mr
Posted: Tue Aug 10, 2010 2:00 am Post subject:
Cheer up, you can design and build 20 of your own BBD delays for the ICs in the meantime, the datasheet tells exactly how to use them!  |
TekniK
Posted: Tue Aug 10, 2010 2:06 am Post subject:
/mr wrote: | Cheer up, you can design and build 20 of your own BBD delays for the ICs in the meantime, the datasheet tells exactly how to use them!  |
Well,i have had already some ideas goin throug my mind,but much simpler as that..
EDIT:
Topic vieuw Stats:
Solina : 48695
Living VCOs : 42247
Vocoder : 32126
Dim D : 25378
BBd : 21505
String Filter: 19725
Resonator : 14997
36db/Oct LPF : 14771
Flanger : 14469
physical mod.: 3965
Trapezoid : 2462
jhaible
Posted: Sat Oct 02, 2010 8:19 am Post subject:
http://matrixsynth.blogspot.com/search/label/Binson
I guess I have to provide a means to connect two delay PCBs (with two 3005's each) to allow for repeat patterns a la Binson.
Love the Interface with all these separte pushbuttons (even though I never had the opportunity to play with a real Binson).
sduck
Posted: Sat Oct 02, 2010 7:55 pm Post subject:
Yes, that's a pretty amazing sounding device!
Personally I'm just hoping that you can come up with something that has similar functionality as the Blacet Time Machine, but with better specs - I'm sure that's the kind of stuff you could do easily enough! |
StephenGiles
Posted: Sun Oct 03, 2010 12:46 am Post subject:
jhaible wrote: | http://matrixsynth.blogspot.com/search/label/Binson
JH. |
I played with a Baby Binson back in 62-63, Fender Strat with an Echolette amp - what a sound!!! |
zthee
Posted: Sun Oct 03, 2010 4:35 am Post subject:
I haven't really followed this project. But I'd be very interested in a 2 PCBs when they become available! _________________ http://www.thehumancomparator.net/ |
