brunov
Posted: Wed Oct 12, 2011 3:18 am Post subject:
Hmm, it seems a big part of the problem can be expained by the delay of 10ms I put in the send thread of the server.
Forgot about that.
I put it there to give the other threads some cpu time. Otherwise the receive thread might miss a message from the G2, and then contact is lost. So I have to do something there. I already gave the receive thread a higher priority put that's not enough.
I'll try some different settings. |
brunov
Posted: Wed Oct 12, 2011 2:06 pm Post subject:
I put a delay in the send queue of 1ms if there are messages to process otherwise when the send queue is empty a delay of 10ms, seems to work ok for up to 5 automated parameters with visual editor and vst, or when not visible I can automate more. With some more optimization this can be improved.
But I as a matter of interest : How many parameters of the G2 do you usually automate in a ableton/cubase/or other project? |
Moody33
G2 patch files: 16
Posted: Wed Oct 12, 2011 9:32 pm Post subject:
Hi.
In my case, I often use:
aftertouch+mod wheel+sustain pedal+control pedal+ CC#7+ 2 or 3 other #CC
So 8 parameters in my case is a maximum. |
brunov
Posted: Thu Oct 13, 2011 12:50 pm Post subject:
Ok, thanks. Is that for one slot or do you use this automation for multiple slots? In other words, do you sometimes have 8x4(slots) = 32 parameters automated?
And another question: in a ableton/cubase project do you generally use the G2 as 4 seperate patches or do you use it in performance mode? |
ZeeByeZon
Posted: Fri Oct 14, 2011 12:25 am Post subject:
I think you should not make such assumptions about the use of most users: this is very variable from one user to another, and this will change in time...
For your second question for example, I think both are interesting and depending on the project, I would choose either performance or multi-patch... especially if a VST editor allows the saving of my program with the song! |
brunov
Posted: Fri Oct 14, 2011 3:21 am Post subject:
Yes, I'm asking because it makes a big difference for the application if your automating 8 or 32 parameters.
At some point it can't process the input fast enough so you get a backlog of messages. So then the application could start sampling the input or something to keep up. But I don't think I'm going to do that now, because it'll make it all even more complex.
I was hoping to get some idea of how people use the g2 in ableton, so i could get an idea of how important the above problem is. |
Posted: Fri Oct 14, 2011 2:13 pm Post subject:
Because there are 8 knobs on the front of a G2 with keys, plus aftertouch, modulation, pitch wheel, and volume, I would assume that would be a pretty strong place to start. It allows a typical performance to be played in real time without the feeling of missing something. I would suspect it'd be a lofty (but in the long run worthy!) goal of supporting any number of parameter changes...MIDI supports 128 CC, plus pitch wheel, etc... You get the unfortunate point  |
brunov
Derek Cook
ZeeByeZon
Posted: Mon Oct 17, 2011 2:57 am Post subject:
I could for this help too  |
brunov
Posted: Mon Oct 17, 2011 9:57 am Post subject:
Thank you very much Derek and ZeeByeZon! Yes, if this is ever to progress from a private project to something everybody can use, I will need some serious help!
I've not uploaded any software because I didn't want to bother you with an endless stream of updates and bug fixes. I think I've rewritten the thing 3 or 4 times already but now I'm happy with the structure. It's a matter of adding functionality from now on, optimizing performance and finding and solving bugs.
Of course when your porting it to Java, I don't now what kind of problems you will find...
What I'll do this week is add comments to the source code where I can, and explain a bit of the structure on the website. And then at the end of the week I'll upload what I have so far. Maybe you can have a look then and decide what you want to do. |
Derek Cook
Derek Cook
Posted: Tue Oct 18, 2011 1:43 am Post subject:
Update: I had a quick browse for Java and how it can interface to USB, and that's something that I'd need to look at first, as it does not appear to be straight forward.
If you have a test program that is simply interrogating the G2, that would be the best place to start.
Something I'm happy to look at anyway, as I love my G2 and would like to see it continue to be supported. _________________ Regards
Derek Cook
www.echoes-music.co.uk
www.purefloyd.co.uk
www.carregddu.co.uk
www.xfactory-librarians.co.uk
www.ex5tech.com |
brunov
Posted: Tue Oct 18, 2011 10:00 am Post subject:
Derek,
I use the libusb-win32, that's a generic usb driver that you can put on top of the original clavia driver (filter driver). So you can still use the original clavia software, that's essential i think.
There exists a Java wrapper http://libusbjava.sourceforge.net/wp/
Don't know if you use a windows/linux/max platform? All should be supported according to the info.
I've included a test application that I started with. The units that are important for the connection are the following:
- LibUSB.pas : this is the interface to the libusb-win32 dll
- UnitG2USB.pas
in this there are a couple functions:
Init : to set up the connection to the G2
Done : to close it
bwrite : bulk write data
bread : bulk read data
iread : interrupt read
So basically you send a message with bwrite then you get a message back with interrupt read and when the returning message is bigger than 16 bytes you can read the rest with a bulk read.
I hope this will get you started
135.59 KB |
| Viewed: |
374 Time(s) |
 Download (listen) |
| Filename: |
G2 Tool.rar |
235.28 KB |
| Downloaded: |
379 Time(s) |
Derek Cook
Derek Cook
Posted: Sat Oct 22, 2011 4:10 am Post subject:
Some file info then
pas are the pascal files, dpr is the 'main program file' it will have have a uses clause that lists all other files in the project (but not all source files used need actually be in the project).
Some pas files have an associated dfm (same base name), or form file, usually that one is readable too, or could be made readable at least.
The dfm has the form design which can have some non visual components too (in general, everything descending from TComponent can be in a TForm). The actions associated with the form will be in the pas file, some of the couplings to buttons for instance can be read in the dfm).
dproj is not too interesting for you I think, it's an XML project file that can be regenerated by delphi when it got lost.
dsk files are desktop files, not interesting for porting.
dcu files are compiled units, or pas files (object files), not interesting.
cfg holds compiler options, not interesting.
res is a regular microsoft compiled resource file.
ddp - no idea, but not interesting
identcache - just delete it. _________________ Jan
Derek Cook
Posted: Sun Oct 23, 2011 1:29 am Post subject:
Thanks for that, but it was more the syntax of the code that I am learning.
It's funny I've programmed in all sorts over the years: machine code (yes, hand assembling op codes), assembly, BASIC, FORTRAN, PL/M, OCCAM, C, C++, Java and even some Prolog, but never Pascal for some reason.
Still, the port is going fairly well, I have most of it converted now according to what I think should be happening, so in the next few days I should be ready to try it out for real. _________________ Regards
Derek Cook
www.purefloyd.co.uk
www.carregddu.co.uk
www.ex5tech.com |
Derek Cook
Posted: Sun Oct 23, 2011 10:27 am Post subject:
Well, I can report some success.
I did the initial port, remapping the LibUsb functions to the LibUsbJava wrapper.
The installation of the filter driver went pretty smoothly.
I had a lot of aggravation getting the software to recognise LibUsbJava. Essentially the native DLL needs to be in the C:\Windows directory, which was not obvious.
I then went into debugging mode , focusing on getting the List function working. No GUI at present, everything is being dumped on the command line.
After sorting out basic problems, like the CRC calculation (my errors in the porting ), it all appears to be working pretty well.
So the next step is to try and build the complete test app that Brunov did in Delphi, but in Java, tidy the code up and get it commented and I'll then post the results for others to have a look at. _________________ Regards
Derek Cook
www.purefloyd.co.uk
www.carregddu.co.uk
www.ex5tech.com |
Posted: Sun Oct 23, 2011 10:50 am Post subject:
Wow cool! It would be interesting to get a look at the Java code at some point, if you feel like sharing. _________________ Antimon's Window
brunov
Posted: Sun Oct 23, 2011 11:23 pm Post subject:
The UI looks pretty enough anyway! Going to try to run this today or tomorrow. _________________ Antimon's Window
Derek Cook
Derek Cook
Posted: Mon Oct 24, 2011 12:17 am Post subject:
| brunov wrote: | Since I won't have much time to work on the project the next couple of weeks, I've made an effort to make a first beta release and update the documentation.
You can find it all here : http://www.bverhue.nl/G2dev/
<<SNIP>>
So I hope someone will be able to try it out. I would recommend this only to someone who's experienced in software developement though. I've only been able to test this on an xp machine. And I hope of course that it will help Derek with his java development.
Regards
Bruno |
Wow, you've done a great job on this! I've just had a quick browse, and documentation and the info is very good. You're doing the sort of "sleuthing" that I did on my x.factory librarians in understanding file structures for Yamaha synths, so I'm glad that somebody else got there before me on this one!
Well done, and I'm quite keen to get a Java port of this going alongside what you're doing and getting a basic structure that others can work on and add to if they wish.
This is a a bit of a slow burn thing for me, as I have quite a lot on music wise as well, but I'll keep people updated as I make progress. _________________ Regards
Derek Cook
www.purefloyd.co.uk
www.carregddu.co.uk
www.ex5tech.com |
dorremifasol
Joined: Sep 28, 2006 Posts: 823 Location: Barcelona, Spain
G2 patch files: 49
Posted: Tue Oct 25, 2011 12:39 am Post subject:
This is an amazing work. Editing the G2 from a cheap android tablet may not be a dream after all.  _________________ Cheers,
Albert |
