 Forum index » DIY Hardware and Software » The Repair Shop
Korg micropreset M-500
Page 1 of 1 [3 Posts]
tonewill
PostPosted: Sun Mar 02, 2014 7:57 am    Post subject: Korg micropreset M-500
Subject description: portamento problem
Hello,
I'm repairing a Korg Micropreset M-500 synthesizer that has one problem left that I'm not sure what the cause or solution is.
When portamento is on, the pitch of the instrument will drop up to a semi-tone. The higher the portamento time, the lower the pitch drops. I've attached what I think is the relevant part of the schematic, if anyone can suggest a likely candidate please let me know. There are trimpots, but I'm reluctant to adjust them without knowing what they are trimming.
Just to clarify, I do know what portamento does.
Thanks for any help.
Korg micropreset M-500 schematic, portamento section.
 Filesize:  25.24 KB
 Viewed:  410 Time(s)
nisios
PostPosted: Thu Oct 23, 2014 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi tonewill.
I repaired a micro preset 500 with the exact same problem (and a bunch more), but this one was puzzling alright.
The portamento wiring runs along the pcb in two parallel tracks if my memory is correct.
Its a high impedance circuit and you need to keep it that way or else, you loose some precious electrons through the pcb and your pitch drops accordingly.
The solution is to clean thoroughly the pcb near that high impedance circuit. Along those tracks that go to the pot.
Use isopropyl alcohol, or regular alcohol if you don´t have isopropyl (its high impedance, but not condenser microphone kind). I like also like to use a pcb cleaner from kontakt chemie.
Also dry it well under an incandescent lamp. Humidity is low impedance.
In my case it was completely solved this way.
Hope its the same thing with you.
Why is the dove a symbol of peace?
The pillow has a lot more feathers without that dangerous beak.
tonewill
PostPosted: Tue Nov 04, 2014 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot for the information, it's worth giving it a try as soon as I can. I'll report back if it works, may not be for a while yet though.
