 Forum index » Discussion » Schmooze » Miscellaneous DIY Art
PONG TV-Game
PostPosted: Tue Dec 02, 2014 3:38 pm    Post subject: PONG TV-Game
Subject description: velleman kit
I finished an old project which I probably started on >10 years ago.
It was actually mostly finished, I just had to drill some mounting holes and put everything together.
It's not build from scratch but was a velleman kit. (at least the PCB & components)
It should just give out a black and white video signal and I know that when I had just soldered the PCB I tested it and it worked fine.
However now that it's finished I'm getting some weird psychedelic color signal Shocked
Maybe it's because I'm using a 5V regulated supply instead of 3 batteries, or because it's attached to a video switcher which
has some color enhancing controls. Anyway I don't mind at all Laughing (I'll try to take some 'screen shots')
edit: hmm the colors are gone, maybe it was some weird magnetic disturbance Very Happy
It still didn't look right but I just found out that if I press 2 buttons on the video switcher at once (it has 'radiobuttons')
it looks as it should.
Velleman Pong Game (hmm, maybe I should have dusted of the controllers a bit,.)
 Filesize:  85.39 KB
 Viewed:  427 Time(s)
Velleman Pong Game
 Filesize:  79.34 KB
 Viewed:  412 Time(s)
Velleman Pong Game
 Filesize:  78.38 KB
 Viewed:  441 Time(s)
