2015 Build Pictures
Page 1 of 6 [136 Posts]
PostPosted: Mon Jan 05, 2015 3:23 am    Post subject: 2015 Build Pictures
Subject description: Show us what you have been building
Hi all , happy new year , thought I'd start a new diy pix thread for 2015 Smile Smile Smile .
Please join in and post pics of whatever you have been constructing in 2015.
Finished last night , the 2nd MPS for the new diy drum synth I am building , this MPS has 2 simple LFO's with skew control(MFOS oldies section) at the right of the module , these are for general use on the drum system to save pinching lfo's from the main modular.
 Filesize:  346.44 KB
 Viewed:  829 Time(s)
PostPosted: Mon Jan 05, 2015 9:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Klee! I started collecting PCBs and eurorack projects a few years ago, but got sidetracked from them. A new baby on the way (and an early-to-bed wife) has given me some new inspiration (and time!) to get back to these gems. 1st up: The venerable and complex Klee. I found a hiden short on the analog PCB, and had to solder the molex connectors rather than just snap the wires in, but otherwise it was pretty smooth! Next up...SN-Voice and a modularization of my Korg Volca Beats.
PostPosted: Wed Jan 07, 2015 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice Klee there Smile
PostPosted: Wed Jan 07, 2015 9:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Klees are hugely fun! So, so much experimentation is possible with them.
Mind you, with mine, I wound up going through and soldering ALL the bloody crimped connectors.
Broadwave
Audio files: 6
PostPosted: Thu Jan 08, 2015 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess it's not really off topic (DIY Hardware Wink )
Electric Stereo Hammered Dulcimer - Day 6. I didn't want to build one with a traditional Polished wood finish, rather something more Contemporary/Art Deco-ish. But at the moment it looks more Darth Vader/Hellraiser!
Still got to fit the output socket & chrome trim, hammer home the hitch pins/tuners, then string up.
EDIT - Finished
Glad to say there's enough Ooomph from the Piezos to get a trigger pulse from, so at least I can process it through the modular Wink
 Filesize:  4.12 MB
 Viewed:  759 Time(s)
 Filesize:  3.84 MB
 Viewed:  814 Time(s)
Snaper
PostPosted: Thu Jan 08, 2015 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just finished the first cabinet.
Hi-Res pics here :
https://www.dropbox.com/sh/blrnl3xt1o2t00t/AAAv2DAlFQBhFTCRYXjf19kMa?dl=0
 Filesize:  5.63 MB
 Viewed:  797 Time(s)
rosch
PostPosted: Thu Jan 08, 2015 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful design! Silkscreened?
Snaper
PostPosted: Thu Jan 08, 2015 8:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
Nope, 2 tone acryllic.
PostPosted: Thu Jan 08, 2015 9:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interface for my guitar. Ken Stone's CatgirlSynth60 stomp box adaptor, tied to Harry Bissell's Envelope Detector, tied to Yves Usson's Comparator.
Quite happy, apart from the fact that I got my coordinates for two jacks wrong. At least they weren't the big ones.
PostPosted: Mon Jan 12, 2015 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I had two issues in bring up, and both were due to connectors needing solder. I quickly decided to solder them all as well, and have no problem with the whole build. I didn't want to debug a crimped cable issue 5 years from now.
And Klees ARE hugely fun! Nice twin sitting behind your GatSynFace Smile
khakifridge
PostPosted: Tue Jan 13, 2015 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow! Cool build. Cool Looking forward to seeing it finished.
Edit: End result looks brilliant. well done
Repeater
PostPosted: Wed Jan 14, 2015 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
One of my Horndogs for an art show. This one has an amplifier that feeds a piezo disc. You put the piezo in your mouth and it resonates your skull. Good times.
PostPosted: Wed Jan 14, 2015 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't try the piezo while on acid or mushrooms Very Happy Very Happy Smile.
Nice build & case .
PostPosted: Wed Jan 14, 2015 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Andy , wow , nice black base , looking forward to see the finished Dulcimer unit.
PostPosted: Wed Jan 14, 2015 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Snaper , very nice modules , good selection there .
AlanP , I like the veneer effect , a bit of arldite or chemical metal will fill the gaps well , nice build .
J3RK
PostPosted: Thu Jan 15, 2015 10:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Thu Jan 15, 2015 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
What, no more green? Very Happy
J3RK
PostPosted: Fri Jan 16, 2015 12:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I've been thinking about another green one actually! I'm thinking of 5U, green panels, and bananas. I think I'm more or less done making larger single-panel systems. It's so much easier to actually use a system in progress when it's fully modular. Very Happy I've got a bit more wiring to do on this black one. The sequencer isn't wired yet, and I'm prototyping the final filter for it now. Should be all wrapped up in a couple weeks though. Then maybe onto the green.
PostPosted: Wed Jan 21, 2015 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
EDIT - Finished
very nice Andy , just spotted your updated pic above Smile
analogmonster
PostPosted: Fri Jan 23, 2015 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Clone of the Moog 911 Envelope Generator module, built as triple bank.
YouTube: https://www.youtube.com/watch?v=REYWp9HbyCQ
More infos on my site http://www.analog-monster.de/mmt911_en.html
PostPosted: Fri Jan 23, 2015 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
AlanP wrote:
Klees... I wound up going through and soldering ALL the bloody crimped connectors.
This is on my do-list: to do the same thing.
PostPosted: Sat Jan 24, 2015 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
J3RK...
analogmonster...
Wow , very nice modules , great looking panel finishes.
PostPosted: Wed Feb 04, 2015 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
no strictly synth DIY, but anyways, i am glad that i finally finished my custom Nvation K-Station.
(wooden cheeks from ross lamond)
PostPosted: Thu Feb 05, 2015 1:18 pm    Post subject: EK2100 Reply with quote  Mark this post and the followings unread
I finally finished the EK2100 which is build around a toy keyboard. Very Happy
(it's also the base and power supply for some of my other synths)
more info and some sounds here
 Filesize:  90.05 KB
 Viewed:  544 Time(s)
 Filesize:  98.45 KB
 Viewed:  567 Time(s)
 Filesize:  131.67 KB
 Viewed:  530 Time(s)
 Filesize:  115.55 KB
 Viewed:  700 Time(s)
PostPosted: Thu Feb 05, 2015 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Matthias .... nice re-build
