 Forum index » Clavia Nord Modular » G2 Performances - Experimental
Hysteresis
Page 1 of 1 [3 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed May 18, 2005 6:42 pm    Post subject: Hysteresis Reply with quote  Mark this post and the followings unread
The sync effect you get from a very basic patch on the G2 seems to be a little thin and gritty (not in a nice way) compared with other synthesisers. This perf is built around an enhanced sync patch in slot A. The first step was to phase modulate the sync point by simply adding a modulation signal to the master wave. Next, using the double saw on the slave then doubling it all up to further thicken and mask the grit.
hysteresis.prf2
simple G2 Perf with phase sync
 Filename:  hysteresis.prf2
 Filesize:  10.38 KB
 Downloaded:  1876 Time(s)
Audio files: 227
PostPosted: Thu May 19, 2005 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice. This sounds great and really cooks. I like that you can play the bell sounds on the keyboard while this is playing. My kind of noodle. Very Happy
Wan
G2 patch files: 46
PostPosted: Sun Jun 05, 2005 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Again a very spherical work. The buildups of the pad sound in particular is very nice. Where do you get the inspiration to produce such beauties? <insert emoticon for jealousy here>
Grtz Wan
