September Equinox 2020 live streaming event
Page 2 of 2 [50 Posts]
Goto page: Previous 1, 2
Audio files: 279
PostPosted: Wed Sep 23, 2020 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm unlikely to just pop by chat so it would help if anyone needing help could say so here and say when they are available so we could arrange things
Audio files: 500
PostPosted: Wed Sep 23, 2020 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laura Woodswalker needs some help to troubleshoot her setup on Friday at 00:30 GMT - so basically at 1:30am BST Friday.
I've agreed to be there to try and work it out and I understand it if that's too late for European people.
laura woodswalker
PostPosted: Wed Sep 23, 2020 8:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK wait a sec...I'm in Eastern US...whatever country you're in...pick a time that's convenient for you. I'm not working so I can connect any time during the day. I'm not making you guys stay up till 1:30. pick a time in the evening & it'll be afternoon for me. And let me know!
woodswalker88@gmail.com
Audio files: 279
PostPosted: Thu Sep 24, 2020 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I am going to try to be around tonight and tomorrow night from 7-12pm BST, so that's 6-11pm GMT or 2-7pm EDT
Audio files: 500
PostPosted: Thu Sep 24, 2020 4:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh I am fine with that, I'm not working either. Smile
I was just thinking more heads are better than two when troubleshooting.
laura woodswalker
PostPosted: Thu Sep 24, 2020 6:08 am    Post subject: Reply with quote  Mark this post and the followings unread
OK I will be here at 3 pm US eastern time today (thursday).
Audio files: 279
PostPosted: Sat Sep 26, 2020 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
My setup for later Smile
e-mSE2020a
 Filesize:  66.41 KB
 Viewed:  487 Time(s)
e-mSE2020b
 Filesize:  55.41 KB
 Viewed:  485 Time(s)
e-mSE2020c
 Filesize:  65.78 KB
 Viewed:  467 Time(s)
PostPosted: Sat Sep 26, 2020 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Broken.
For a broken back I guess, or a broken world and that the back is for the world, or something Rolling Eyes
The image background is my patch compatibility chart, had 16 patches and did a comparison evening last week to see which could go together. Then on the right hand side it has the sequence of patches that I came up with.
Blue Hell - september 2020 equinox - broken
 Filesize:  731.36 KB
 Viewed:  434 Time(s)
2020-09-26--Blue Hell--2020 september equinox - broken.mp3
Blue Hell - September 2020 Equinox - Broken
 Filename:  2020-09-26--Blue Hell--2020 september equinox - broken.mp3
 Filesize:  55.69 MB
 Downloaded:  1069 Time(s)
PostPosted: Sat Sep 26, 2020 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
and here's my set.
PHOBoS - electro-music.com September Equinox 2020 LIVE.mp3
 Filename:  PHOBoS - electro-music.com September Equinox 2020 LIVE.mp3
 Filesize:  26.67 MB
 Downloaded:  831 Time(s)
klangumsetzer
Audio files: 37
PostPosted: Sat Sep 26, 2020 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please find today's set below which was performed on a pre-patched Make Noise B+G modular system.
Thank you all for the music and your companionship!
with kind regards
Eike
klangumsetzer_2020 autumn equinox.mp3
Make a joyful noise!
(C) 2020 by klangumsetzer
 Filename:  klangumsetzer_2020 autumn equinox.mp3
 Filesize:  47.81 MB
 Downloaded:  861 Time(s)
Audio files: 500
PostPosted: Sat Sep 26, 2020 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Buffer free recording of my set. Smile
robsol_equi20.mp3
robsol - september equinox 2020 live set
 Filename:  robsol_equi20.mp3
 Filesize:  51.6 MB
 Downloaded:  772 Time(s)
laura woodswalker
PostPosted: Sat Sep 26, 2020 4:11 pm    Post subject: recordings Reply with quote  Mark this post and the followings unread
did you record as you played, or is there a recording automatically created somewhere?
I didn't want to mess with recording in Ableton as we had already had USB problems earlier.
Audio files: 500
PostPosted: Sat Sep 26, 2020 5:07 pm    Post subject: Re: recordings Reply with quote  Mark this post and the followings unread
I recorded in Reaper, which was also used to stream.
But you can also record in Butt, to wav or mp3 file. I think it's on the last tab in the settings window?
PostPosted: Sat Sep 26, 2020 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
With BUTT you can set it up to automatically record what you stream, you set a format (recording quality) for it on the "Audio" tab of the settings, and then some more settings (like what to record when and where) are on the "Record" tab in the same window.
But I'm using a 2nd computer dedicated to streaming and recording - actually all my audio goes trough that computer.
And then there is PHOBoS who records everything .. usually, and manually.
Ron Holmes
Audio files: 19
PostPosted: Sat Sep 26, 2020 7:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is my set from today. Thanks to all who set this up and for providing a great opportunity to play live in this crazy, messed up year!
EscapeVelocity - Electro Music Live Fall Equinox 2020.mp3
 Filename:  EscapeVelocity - Electro Music Live Fall Equinox 2020.mp3
 Filesize:  35 MB
 Downloaded:  767 Time(s)
PostPosted: Sun Sep 27, 2020 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's Kevin Kissinger's wonderful set
EM SE2020 - 12. Kevin Kissinger.mp3
 Filename:  EM SE2020 - 12. Kevin Kissinger.mp3
 Filesize:  55.53 MB
 Downloaded:  761 Time(s)
PostPosted: Sun Sep 27, 2020 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for posting this! My hard drive filled up during the set and I was unable to capture all of it.
Thank you for your compliment. I look forward to listening to your set when I’m back home later today.
Regarding the photo below, this is the current setup. I built a sturdy stand for the modular with a terraced desk shelf for the lower keyboard. Its casters allow me to save floor space because I can roll the instrument against the wall yet can roll it out to service it.
I found a nice 35u rack for my rack equipment (yes, it has casters, too). My effort has been to arrange the equipment into a clean layout that is easy to work and to service.
Next to the laptop computer is an Elektron Octatrack. I purchased it after hearing Mark Mosher perform an amazing set at Mountain Skies 2019 wherein he used the Octatrack and other Elektron equipment. This is my first performance with the Octatrack and I focused on its MIDI sequencing capabilities (steep learning curve with the Octatrack).
Besides the modular synth, I utilized the Kurzweil K2600 and a Casio VZ1 to the left of the Octatrack. I didn't use any loopers this time -- I wanted to see what I could manage without any looping.
The setup for this performance is indeed DAWless.
 Filesize:  6.73 MB
 Viewed:  241 Time(s)
PostPosted: Sun Sep 27, 2020 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all Smile , had a great day yesterday listening in to all the great music thanks to all who performed & broom control in switching & chat Smile Smile
Here is the Epicyclus set , thanks for listening in Smile
Dave Smile
epicyclus autumn equinox EM 2020.mp3
 Filename:  epicyclus autumn equinox EM 2020.mp3
 Filesize:  41.16 MB
 Downloaded:  603 Time(s)
PostPosted: Mon Sep 28, 2020 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good to see you all had fun! (My current work schedule has me sleeping right when this was going on... Sad hopefully I can join in on the next event!)
klangumsetzer
Audio files: 37
PostPosted: Mon Sep 28, 2020 10:58 pm    Post subject: Re: recordings Reply with quote  Mark this post and the followings unread
Hello Laura,
I also use Reaper's ReaCast to stream.
For recording the stream I use this free plugin by Voxengo called Recorder on the masterbus:
https://www.voxengo.com/product/recorder/
Hope this helps!
with kind regards
Eike
klangumsetzer
Audio files: 37
PostPosted: Mon Sep 28, 2020 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dave Smile
Dave,
Everytime I listen to this my feet cannot stop moving. Very Happy
Thank you for your great set!
with kind regards
Eike
Audio files: 500
PostPosted: Tue Sep 29, 2020 4:12 am    Post subject: Re: recordings Reply with quote  Mark this post and the followings unread
Hello Laura,
Hope this helps!
with kind regards
Eike
You can also record the main output directly in Reaper by pressing Alt+Ctrl+B (bounce/record output to disk).
PostPosted: Sun Oct 04, 2020 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks to PHOBoS for capturing this wonderful performance. Thanks to Kevin for an amazing set (which I missed live--had houseguests) and for all the wonderful details about the current setup (which looks spectacular and very tidy, too) and the gear used in the brilliant performance.
PS: I am familiar with the VZ synth engine and if you are willing to share your patches, would love to use them on my VZ-8m.
Audio files: 279
PostPosted: Thu Oct 15, 2020 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finally got my artwork done and my set uploaded to bandcamp Smile
https://modulator-esp.bandcamp.com/album/mabon-voyager
PostPosted: Sun Oct 25, 2020 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, thank you for your compliment!
I don't have any new or interesting VZ1 patches to share -- I merely used one of the preset patches (the "Bell Tree"). All the other sounds were from the K2600 and the modular synth.
I kept the VZ1 because, despite the difficulty to program it, it makes some very cool sounds.
