About VCA-1
Page 1 of 1 [5 Posts]
Arda Eden
PostPosted: Sat Nov 14, 2020 8:44 am    Post subject: About VCA-1
Subject description: Strange Behaviour of my built VCA-1
Hi all,
As many of you, I stepped into the fantastic world of modular synthesizers and the first module I built was the TH's VCO-1. It works perfectly and I already built the second one.
Next, I needed a VCA, and again TH's VCA-1 (https://www.birthofasynth.com/Thomas_Henry/Pages/VCA-1.html) worked, but in a strange way: The gate opens at negative voltages and closes on positive. When I press a key, gate is closed and no sound. On a depress, gate opens up. This is supposed to be the opposite way, isn't it?
I checked my circuit and it is exaclty the same with that TH designed.
What may have gone wrong?
Any ideas?
Thanks already.
Arda Eden
PostPosted: Sat Nov 14, 2020 1:21 pm    Post subject: Update Reply with quote  Mark this post and the followings unread
I figured out that:
1- TL071 is getting very hot and frying some time later. Even if I remove the TL071 from its socket, circuit keeps working in its abnormal behaviour. 071 has no function in my circuit.
2- Checked everything. No shorts or anything wrong.
Couldn't understand why TL071 is getting that hot and not working.
drapdap
PostPosted: Sun Nov 15, 2020 3:18 am    Post subject: Re: Update Reply with quote  Mark this post and the followings unread
The ota you are using, 3080 or 13700?
I’ve built several vca-1’s with the original layout ages ago, and i had this behaviour with fake 3080’s!
I’d try swapping that after gettting the right psu voltages on ic sockets.
Also the 071, it could be fried now.
Arda Eden
PostPosted: Sun Nov 15, 2020 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
It's a 3080, but note sure if it is fake or not. I will check. The same ones work on my VCO-1s without any problem.
I used 7815 and 7915 regulators on my 15v symmetrical PSU. I measure +15 and -15 on the transformer output, but -14,8 and +15,2 on the DC side. This is also interesting. I tried two circuits, and they did the same. This is the only problem with my PSU. I'll also change it.
Finally, I think I will put this VCA-1 aside for some while and find a different simple VCA circuit to build. And also a simple VCF and an ADSR.
Thank you.
My 3080
 Filesize:  454.83 KB
 Viewed:  306 Time(s)
marwatt
PostPosted: Mon Nov 16, 2020 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
It's a 3080, but note sure if it is fake or not. I will check...
Hi all...
regarding fake/not fake CA3080... how to test them on breadbord?
thank you!
