December 2024 New Years Eve Streaming Concert
Page 2 of 2 [49 Posts]
Goto page: Previous 1, 2
Audio files: 297
PostPosted: Sat Dec 28, 2024 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please note ..
the schdule has been changed - some people and some switchers have been moved to different time slots.
keep an eye at : https://electro-music.com/wiki/pmwiki.php?n=Radio.NextSpecialEvent
Audio files: 278
PostPosted: Sun Dec 29, 2024 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like my last bus into town is 20:01, so is there any chance my set could finish by 19:30 please, if not then I'll just do 30 minutes instead
PostPosted: Sun Dec 29, 2024 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like I can make a revision so that you can start earlier. I have to step away now and will be back around 2330 GMT to work on it.
electro-nyc
PostPosted: Sun Dec 29, 2024 11:53 am    Post subject: redgreenblue Reply with quote  Mark this post and the followings unread
2 things, can my name be changed to redgreenblue on the poster?
And the link in the poster is for the Sept 2024 concert
That time works for me, see you all Tuesday!
Audio files: 297
PostPosted: Sun Dec 29, 2024 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
The wiki was pointing to the previous event .. i've changed that .. but i don't know about a link in a poster ...
Also changed redgreen to redgreenblue on the wiki, but not on the poster(s).
Audio files: 278
PostPosted: Sun Dec 29, 2024 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Smile
Audio files: 278
PostPosted: Sun Dec 29, 2024 12:58 pm    Post subject: Re: redgreenblue Reply with quote  Mark this post and the followings unread
I thought it was odd you were shown as redgreen Shane, but checked and that's what you put in your sign-up post, so I thought maybe it was something new
EscapeVelocity
PostPosted: Sun Dec 29, 2024 6:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looking for the port information so I can test. Thanks.
PostPosted: Sun Dec 29, 2024 8:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Plan to use port 8132.
Detailed information is here:
https://electro-music.com/wiki/pmwiki.php?n=Radio.ConnectionDetails
mtvic
PostPosted: Mon Dec 30, 2024 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
kkissinger wrote:
Mike, you are now on the schedule at 22:30 GMT.
Thanks Kevin.
I will try testing my port later today.
PostPosted: Mon Dec 30, 2024 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
mtvic wrote:
Thanks Kevin.
Excellent! btw -- I had to revise the schedule, and your start time has moved by 30 minutes to 22:00 GMT.
Hope that works for you. Thank you!
PostPosted: Mon Dec 30, 2024 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello! I went ahead and closed the signup now. Since the schedule changed a few times, please check it and let me know if your assigned time won't work for you.
See you Tuesday!
Audio files: 278
PostPosted: Mon Dec 30, 2024 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm happy with my slot now, thanks Kevin Very Happy
klangumsetzer
Audio files: 37
PostPosted: Mon Dec 30, 2024 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Kevin, all fine with me.
Make a joyful noise!
Eike
Audio files: 297
PostPosted: Tue Dec 31, 2024 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Kevin for organizing things and for playing a set Cool
2024-12-31--Blue Hell--2024 nye - not every thing you can do.mp3
blue hell - nye 2024 _ not every thing you can do
 Filename:  2024-12-31--Blue Hell--2024 nye - not every thing you can do.mp3
 Filesize:  54.52 MB
 Downloaded:  114 Time(s)
EscapeVelocity
PostPosted: Tue Dec 31, 2024 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is my NYE set. Thanks to Kevin for organizing and to Jan for testing.
Escape Velocity Live on ElectroMusic Radio NYE 12-31-24.mp3
 Filename:  Escape Velocity Live on ElectroMusic Radio NYE 12-31-24.mp3
 Filesize:  35.97 MB
 Downloaded:  110 Time(s)
Audio files: 297
PostPosted: Tue Dec 31, 2024 8:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
mtvic just turned up in the irc chat and said he did have troubles using the internet.
This would of course have made it impossible for him to perform - bloody interwebs always.
Anyway, this was not a noshow but a sad case of tech issues.
too bad mike Sad & next time beter Cool
We missed you.
PostPosted: Wed Jan 01, 2025 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
We missed you.
Sorry that you had internet issues. Alas, these things happen sometimes.
Mike, please plan to play for the March Equinox event. Always enjoy your music!
usr_sbin
PostPosted: Wed Jan 01, 2025 8:19 am    Post subject: Posting recording of my set... Reply with quote  Mark this post and the followings unread
Here's a link to the recording I made of my stream from last night —
https://audiozoloft.bandcamp.com/album/walking-with-janus-ever-forward-ever-backwards
Try me ... ... said the Dalai Lama to the hot-dog vendor, "Make me one with everything."
PostPosted: Wed Jan 01, 2025 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Unplanned Improvisation for the Event
Although I wasn’t originally scheduled to perform, I ended up doing an impromptu improvisation using my modular system with a test patch.
Lately, I’ve been focused on building Arduino-based control modules, which served as the backbone of the setup. The audio path was intentionally simple: just four VCOs (each outputting triangle waves) without any filters or additional complexity.
The first new module I used was a Sample and Hold with voltage quantization and mapping. It includes a built-in mini-sequencer that I can engage and adjust on the fly, with a selectable number of steps. The quantizer/mapper allows me to choose from several predefined scales and modes, which are stored in software. One of the key features is the cross-fader, which lets me smoothly transition between modes. A particularly useful algorithm for the cross-fader is the common-tone method, where the transition passes through a middle mode that represents the intersection of the two scales.
I also used a new Quad Envelope Generator. On this prototype module, all the envelopes share the same ADDSR parameters, but I can control two sets of envelopes (A and B) and blend between them using the cross-fader.
The melodies in the set were generated by an older module I built years ago, the CGS 1/finite Melody Generator (designed by Ken Stone). The new Sample and Hold module was designed with this and future melody generators in mind, providing a versatile foundation for evolving patches.
In the end, the performance was an off-the-cuff exploration, with me adjusting the patch in real-time—turning knobs and tweaking parameters to keep the sound musically varied and interesting.
NYE_Dec_31_2024.mp3
Unplanned improv for NYE, Dec 31 2024 streaming event
 Filename:  NYE_Dec_31_2024.mp3
 Filesize:  53.21 MB
 Downloaded:  103 Time(s)
Audio files: 278
PostPosted: Wed Jan 01, 2025 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my set, a space music/ berlin school improvisation for hydrasynth, jd-08, se-02 (arpeggiated by hydrasynth), minifreak and wavestate (through 2 pole filter)
Available to view on twitch for another 6 days:
https://www.twitch.tv/videos/2340807779
e-m NYE setup 1
 Filesize:  288.24 KB
 Viewed:  43 Time(s)
e-m NYE setup 2
 Filesize:  268.13 KB
 Viewed:  47 Time(s)
modulator_esp_e-m_nye_2024_timeshifts.mp3
 Filename:  modulator_esp_e-m_nye_2024_timeshifts.mp3
 Filesize:  55.47 MB
 Downloaded:  109 Time(s)
PostPosted: Wed Jan 01, 2025 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the Epicyclus set , had a great day yesterday streaming and listening in till i zonked out on couch and missed the bells!! Very Happy
Blue diy modular used with Modal Argon8M / juno 60 / Nord G1 / Waldorf pulse v1 and trusty old korg X5 , for the acidyy end track i used th 2 TD-3's and fired up theYamaha A3000v2 rack sampler for a couple of drum loops Smile
Thanks for having a listen in Smile Smile
Epicyclus NYE 24 into 25 set.mp3
 Filename:  Epicyclus NYE 24 into 25 set.mp3
 Filesize:  41.16 MB
 Downloaded:  119 Time(s)
klangumsetzer
Audio files: 37
PostPosted: Thu Jan 02, 2025 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
This concert was great fun and a nice way to start the new year!
Thanks Kevin for organizing and Jan for testing and switching.
This time I only used my Virus kb and Cockos Reaper for sequencing and recording.
Enjoy the dancy set!
klangumsetzer_NYE 2025 concert.mp3
(C)2025 by klangumsetzer
 Filename:  klangumsetzer_NYE 2025 concert.mp3
 Filesize:  128.64 MB
 Downloaded:  142 Time(s)
Eike
PostPosted: Thu Feb 27, 2025 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I finally made some time to have a listen or rather finally made some time to leave a comment after making some time to listen 2 weeks ago.
Great set, even gave me some goosebumps at parts,. also nice 303 acid bassline Very Happy
