paia theremax interferences
Page 1 of 1 [8 Posts]
SuperKoopa
PostPosted: Wed Jul 26, 2006 7:09 am    Post subject: paia theremax interferences Reply with quote  Mark this post and the followings unread
Hi!
i want to build a sound lab with an integrated paia theremax.
did you know if the SL PCB will interact with theremax PCB or antennas?
Someone of you could try to approach any oscillating device to the theremax pcb and tell me what happens?
Audio files: 235
PostPosted: Thu Jul 27, 2006 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I moved this to the Sound Lab forum but left a link behind in Theremin. This is a more active forum and there is a better chance of getting an appropriate responce.
Wild Zebra
PostPosted: Thu Jul 27, 2006 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure what you mean in your post, but the Theremax has CV outs that could control the Soundlab as well as a gate. http://www.paia.com/therpanl.htm
"your stripes are killer bro"
SuperKoopa
PostPosted: Thu Jul 27, 2006 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry again and again.... for my english.
when i say interaction i mean "unwanted" interaction.
i'm afraid that electro-magnetic fields produced by sound lab pcb will disturb the theremax functioning.
this is the reason because i ask to someone to approach a oscillating module pcb (because without oscillations there is no EM fields) like VCOs or LFOs to the theremax pcb and tell me what you listen.
this could be very helpful for me!
thanks
dnny
PostPosted: Fri Jul 28, 2006 1:14 am    Post subject: Reply with quote  Mark this post and the followings unread
i don't have theremax board and my SL is still on construction - so i can't try this for you.
but i suggest that you should build the theremax inside a metal housing (Faraday cage) if it's sensitive to EM-fields.
if SL is sending too much EM-radiation change to a metal box would help.
www.koelse.org
flickr: cable porn group
Wild Zebra
PostPosted: Fri Jul 28, 2006 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Please no apologies needed. I don't have a theremax so cannot test either, but I would agree with Daniel. I hope someone can chime in or consider sending a pm to someone who has more electronics knowledge. Or e-mail Ray Wilson
Budgrubber
PostPosted: Wed Jan 03, 2007 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I have a Theremax and have used it with my Soundlab. The two work great together. I have the Tmax mounted in a case with a small amp and speaker and there seems to be no interference from that, so i don't think a Soundlab would do anything. I do get a hell of a lot of radio interference where i live which some fine tuning of the oscillators took care of (for the most part)
here are some mods to do to make the CV out on the Tmax sensitive thanks to kevin kissinger. To get the lag out of your Pitch CV try the following:
1) Remove C24, and
2) Replace C21 (10uf) with a 5uf electrolytic capacitor
crashlander42
PostPosted: Thu Jan 04, 2007 9:46 pm    Post subject: theremax soundlab Reply with quote  Mark this post and the followings unread
I've actually used my theremax with my soundlab also. I keep them stacked on to of one another and haven't had any problems. I would suggest shielding the RF oscillators on your theremax even if you don't integrate it into your soundlab. I stuck pieces of copper board in between the individual oscillators and ran one above them as well. You can find a lot of information about theremax mods on this page. I wouldn't think you'd run into any problems combining it with a soundlab. I've seen people add boards into their theremax including adding the power supply into the case.
Good luck!
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
