Fixed Filter Bank
Page 1 of 1 [11 Posts]
3phase
G2 patch files: 141
PostPosted: Fri Jan 12, 2007 7:24 am    Post subject: Fixed Filter Bank Reply with quote  Mark this post and the followings unread
I start really to agree that such a module must return in the G2 just because its so impossible and over expensiv to patch such a thing on the G2..
I also dont see the NM1 Filterbank as so bad sounding anymore...its really not too bad in relation to the amount of bands...
However..here is a minimal version that just needs around 20% ! oh oh... :-/
It still nowhere as steep as the Nm1 version and has less bands...but..
duo some phase changes in the circuit it gives a quite nice exciter fx...
I tried to tweek it for reasonable sound quality..and being related to the Nm1 filterbank to become a module in the patch converter...
However..if anybody has better tweaks for such a thing bring it up..just..
It should stay below 25 %...
 Filesize:  100.65 KB
 Viewed:  21359 Time(s)
FixedFilterBank.pch2
 Filename:  FixedFilterBank.pch2
 Filesize:  2.34 KB
 Downloaded:  2127 Time(s)
Fozzie
G2 patch files: 49
PostPosted: Fri Jan 12, 2007 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wouldn't the approach described by Rob on his tutorial pages be cheaper? He describes a simple method for cascading filters. Or would this differ too much sonically?
This is a pic from his site showing the idea:
Spinning at ~0.0000115740740741 Hz
3phase
G2 patch files: 141
PostPosted: Fri Jan 12, 2007 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
looks intersting... when tere is time i ve a look into that ..one day i patch something where no rob has been before Wink
G2 patch files: 626
PostPosted: Fri Jan 12, 2007 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
about 13% but it takes up so much space!
FixFilBank.pch2
 Filename:  FixFilBank.pch2
 Filesize:  2.19 KB
 Downloaded:  2249 Time(s)
Fozzie
G2 patch files: 49
PostPosted: Fri Jan 12, 2007 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for trying it out G2Ian, I was typing with one hand and juggling my 3-months old in the other, so I couldn't do it myself Very Happy
Funky40
G2 patch files: 5
PostPosted: Thu Jan 25, 2007 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone of the Experts tryed to build a Filterbank with 16 bands and steep angles ?
VA load is NO point. ( space also )
( sorry, i was never into building filterbanks, and since i used my G2 no more for a long time i hope you got maybe allready one patched. )
Is it possible to patch something with sonic qualitis near to the one in the spectralis ?
PostPosted: Thu Jan 25, 2007 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
You can just expand Ian's one and then make the filters steeper and change the frequency settings to you likings.
Funky40
G2 patch files: 5
PostPosted: Thu Jan 25, 2007 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
oh thanks,
and how should i make the Volume of each Band CV controllable, with the AM module ?
PostPosted: Thu Jan 25, 2007 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
When you want to use control signals to dynamically alter the volumes you could do that yes, or use the Level/LevMult instead which probably is a bit cheaper.
When you just want static volumes you could chain another MixFader to the one already in the patch.
Fozzie
G2 patch files: 49
PostPosted: Thu Jan 25, 2007 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Me no expert, but this is just a simple extension of Ians patch. No idea about the sonic qualities of the spectralis either. Let us know how it compares according to you.
edit: ah, I see Blue Hell proposed already what I patched up, well, at least you don't have to do it yourself then Smile . It's no rocket science anyway, but nice to play with. Also nice to use a couple of morphs on several overlapping sets of bands, for nice effects with a few knob turns. Trying out on a laptop/with the demo now, so I am curious how this sounds on the real thing with some audio going trough...
fixfilbank16B36dB.pch2
fixed filterbank with 16 bands (frequencies set approx to doepfer a128 specs) and 36db cutoff slopes. Use keyboard or keyb tool to transpose sequence for auditioning.
 Filename:  fixfilbank16B36dB.pch2
 Filesize:  4.05 KB
 Downloaded:  1874 Time(s)
Funky40
G2 patch files: 5
PostPosted: Thu Jan 25, 2007 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, i gonna try,................................................... will get my first notebook this DAys, so its Time to reactivate my engine.
and thanks
( yes, when i have something to tell, i'll do )
