qfingers
Posted: Sun Feb 04, 2007 8:32 pm Post subject:
Announcement: g2ools-1.5 nm2g2 and dx2g2 converters. |
Hey,
Here is where the new release is located:
http://electro-music.com/forum/topic-15405.html
This is primarily a bug fix release. There are a couple of new features. The main one is the -s option. This shortens the cables so the patch looks cleaner. Here is the list of updates:
Bugs/Features/Models:
X removed unneeded mixers from fm input when values==0
X fixed mixer3 and mixer8 to be audio output
X fixed *10 bug because env times are in milliseconds.
X optimized handlepitchmod with function and remove unneeded mixers.
X fixed pulse width when no mod present.
X added modtable to vocal filter level.
X removed freq table from vocal filter.
X fixed combining nets when destination has output
X added -s, cable shorten routine
X update pitcheg and lfo table
X update dx7 model
X add Ian's pitch eg fix, factory coloring
X fixed dxtime and variation number.
X fixed cable coloring when shortening cables.
X correct RatioFixed handling.
X updated dx7 model from 3phase.
X gentab.py table formatting cleanup
Enjoy,
q |
Hyde
Posted: Mon Feb 05, 2007 3:29 pm Post subject:
do i need to reconvert all my patches again and again with each new release? like will it make them sound even more true to the original? |
3phase
G2 patch files: 141
Posted: Mon Feb 05, 2007 4:34 pm Post subject:
depends on the changes...in this release some patches will work better that are related to the PW bug or the vocal filter...
most improovments are done for DX patches...
on the next release it will be probably a bigger difference for the nm2g2 converter...
depends on your patches... m ost areas are pretty good developed allreaDY..BUT DELAY LINES WILL BE OPTIMIZED..ups..the caps lock...
or morphs on switches will be translated in future release..A better model for the shelving EQ´s will be implemented..and if we find further bugs they will be eliminated...
And... the szise of converted patches will be a bit optimized so that some patches that go over 100% now can be loaded...
So its on you if you convert all patches again..but... if you do you help us to find bugs that might sneak in during the update process. |
jellytots
Posted: Mon Feb 05, 2007 4:50 pm Post subject:
can this convert G2 patches into nm1 patches ?
that would be so sweet....I could patch on the G2 engine, and take it to a micro modular for those dirty d/a's....
tell me it's so! |
3phase
G2 patch files: 141
Posted: Mon Feb 05, 2007 7:30 pm Post subject:
no ..the other way... |
jellytots
Posted: Mon Feb 05, 2007 8:57 pm Post subject:
ever thought about doing it the other way round ? |
G2 patch files: 626
Derek Cook
Posted: Sat Feb 17, 2007 2:16 am Post subject:
Sounds cool, and thanks for your efforts!
As a programmer myself (see www.xfactory-librarians.co.uk), it's good to see this sort of work going on elsewhere, as quite often "self help in the community" is the way forward these days for getting features the manufactures don't think are worth the hassle.
Out of interest, I don't a G1, so is it worth trawling the G1 back catalog, as the G2 patch library is pretty comprehensive in itself? |
3phase
G2 patch files: 141
Posted: Sat Feb 17, 2007 5:36 am Post subject:
i think the G1 lib is by far more interesting. more strange stuff... you cant says better because booth libs have good sounds... but there are defenetly lots of them in the G1 lib |
Derek Cook
Posted: Sat Feb 17, 2007 6:22 am Post subject:
Thanks, I'll put a G1 patch trawl down on my "rainy day list"  |
Joined: Apr 03, 2004 Posts: 24484 Location: The Netherlands, Enschede
Posted: Sat Feb 17, 2007 6:27 am Post subject:
Derek Cook wrote: | Thanks, I'll put a G1 patch trawl down on my "rainy day list"  |
For a sec I was afraid you wouldn't ever have enough rainy days, but then I saw where you are from  _________________ Jan
dasz
Audio files: 29
G2 patch files: 56
Posted: Sat Feb 17, 2007 7:42 am Post subject:
it's worth doing this on a rainy morning ... to ensure you have a lot of time that day as you will be adding tons of variations to your g1 patches
/Dasz |
Derek Cook
Posted: Sat Feb 17, 2007 8:37 am Post subject:
Blue Hell wrote: | Derek Cook wrote: | Thanks, I'll put a G1 patch trawl down on my "rainy day list"  |
For a sec I was afraid you wouldn't ever have enough rainy days, but then I saw where you are from  |
Wales is a green and pleasant land for a reason, but we never have to worry about hosepipe pans  |
kmmcdonald
Posted: Sat Mar 10, 2007 12:07 pm Post subject:
1.5 problem? |
This does not work for me. When I double-click nmg2.exe, the window pops up and disappears within a split second. I am running XP.
Is there something to understanding this utility that is eluding me?
thanks
Keith _________________ Keith M in AZ |
Fozzie
G2 patch files: 49
Posted: Sat Mar 10, 2007 12:16 pm Post subject:
Re: 1.5 problem? |
kmmcdonald wrote: |
thanks
Keith |
Yes, it's a command line utility. You need to use it from the good ole DOS prompt. Search around a little, especially in the converter-subforum, and you should be fine. Not hard to use at all. _________________ Spinning at ~0.0000115740740741 Hz |
cappy2112
Joined: Dec 24, 2004 Posts: 2498 Location: San Jose, California
Posted: Sat Mar 10, 2007 9:20 pm Post subject:
Re: 1.5 problem? |
kmmcdonald wrote: | This does not work for me. When I double-click nmg2.exe, the window pops up and disappears within a split second. I am running XP.
thanks
Keith |
You need to pass it some arguments. Because of that, you must run it from a cmd prompt.
There is gui version is in the works. |
Project
Posted: Mon Mar 19, 2007 12:37 pm Post subject:
BTW, has someone already converted the patches J. clark has made for his fabolous book on synthesis on the G1?
TIA
Project |
glitched
Joined: Mar 25, 2006 Posts: 80 Location: phila., pa USA
Posted: Fri Mar 23, 2007 6:20 pm Post subject:
Forgive me if this has already been asked, but have you guys uploaded these NM1-converted (or DX-converted) patches somewhere?
I'd love to dl a huge .zip of either of those collections.
Actually, I'd just be happy if someone could point me to a patch that takes full advantage of the DX router.
[EDIT] Disregard this, I found the converted collection. Good work!
