Mark Verbos/Buchla 292 LPG adaptation
Page 1 of 1 [25 Posts]
funkyfarm
PostPosted: Tue Feb 13, 2007 9:02 am    Post subject: Mark Verbos/Buchla 292 LPG adaptation
Subject description: Quad Lo Pass gate on one PCB
After almost two years, it's working !
I was sold 1000pF MKP caps for 1000nF ones !? didn't realise they were too small for this value...
Nasty little red caps...(now some big big big 1000nF orange ones fitted the other side)
original here:
http://www.simple-answer.com/DIY.html
funkyfarm
PostPosted: Tue Feb 13, 2007 9:44 am    Post subject: Upgrades ? Reply with quote  Mark this post and the followings unread
As for the 291, I'm wondering if there's any simple improvements to achieve. Very Happy
I've tryied last night to emphasize CV sens. by lowering the input 100K resistor (the one called "may have to be 10K" on Buzzclick's schem)
Maybe with a 91k would be a little more "receptive", while still cutting output when pot is on full CCW.
Or maybe it would be more efficient to play with the "- INPUT" 10K resistor of IC 9 ?
Original schematic
What is the "professional" procedure to trim it ?
I've done calibration by ear with sweet triangle =/-5V LFO...mainly in BOTH and VCA modes ; they sound lovely but who knows ?
And what about Grenader's note ? intentionally using different cap types (or surely "value") which affects the timbral characteristics of each four modules.
Those caps are the one associated with the vactrol (still an RC network, no ?)
So we have 220pf for one and 4n7 for the other.
Is there any simple theory in order to change these values ?
keeping the ratio ?
No use to have four "perfectly tuned" LoPass Gates ?
http://www.buzzclick-music.com/
mono-poly
PostPosted: Tue Feb 13, 2007 10:49 am    Post subject:   Reply with quote  Mark this post and the followings unread
I really like the looks of the module!
Fernando
PostPosted: Tue Feb 13, 2007 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey it looks great!
CJ Miller
PostPosted: Fri Feb 16, 2007 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
How did you handle the switching? I've been looking at Mark's schematic and PCB layout... I'm not very knowledgable and his use of the CMOS switch and that special toggle has me a bit confused.
How is the panel labelling done? It all looks great!
Funky40
G2 patch files: 5
PostPosted: Fri Feb 16, 2007 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, looks great.
And i'm also very interested to know how the Panel labeling is done.
funkyfarm
PostPosted: Fri Feb 16, 2007 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Funky40 wrote:
yeah, looks great.
FORGET ABOUT IT !
this is (unfortunably) real shit.
(sticker from "Canson", here in france)
only a temporary solution...
I'm real sorry that nowadays digital camera make the world seems smoother than it is.
[edit]Here is a better coloured attempt with "Filmolux"[/edit]
CJ Miller
PostPosted: Sat Feb 17, 2007 12:20 am    Post subject: Reply with quote  Mark this post and the followings unread
How about that mode switching? Are you using that particular C&K 7211 switch or doing something else? Looking at the LPG version B it doesn't even use a CMOS switch on the board at all. Mark's appears to based on the C version. Anyway, I keep wondering whether I need to shell out for those 7211 switches - which I can't afford now - or if regular DPDT will work. Some 4.7M resistors are due to arrive this week so I'll try on perf soon anyway.
funkyfarm
PostPosted: Mon Feb 19, 2007 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
According to MV, I'm using "normal" switch STDP
funkyfarm
PostPosted: Mon Feb 19, 2007 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
the four modules seem to draw an important amount of current...On the same PSU rails, my VCO are slightly detuned when changing the GAIN pot position.
As for the KORG PS 3100 RES and Buchla 291, there is no hurt putting in parallel three or six 10KA potentiometers (a small value) between +15 and ground ?
This could help ?
MFOS Control Voltage Distributor
Or maybe a separate PSU ?
Scott Stites
Audio files: 96
PostPosted: Mon Feb 19, 2007 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
3 10K pots will have a parallel resistance of 3.33K, which will draw 4.5 mA from 15V.
6 10K pots in parallel = 1.67k, which will draw 9 mA from 15V.
I wouldn't cnsider either figure excessive. What is the current rating on the power supply you're using?
Scott
funkyfarm
PostPosted: Mon Feb 19, 2007 2:17 pm    Post subject:
Subject description: Too hot in here
Here, the 291 MMF draws 35mA on +15volts and 20mA on -15 volt
while the QUAD 292 is 57mA on +15 volts and 50 mA on negative rail ?!?
Absolutly nothing is hot in here ! Wink
PS : formant PSU
[edit] All four LPG owns a separate 22ohm/22uF RC network for both rails... [/edit]
synth_ollie
PostPosted: Tue Feb 27, 2007 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
wouldn´t it be nice with a resonance control
as on the doepfer lpg ? any ideas of how to do it ?
funkyfarm
PostPosted: Mon May 14, 2007 12:47 pm    Post subject:
Subject description: After few weeks in use, I can say this quad module is way cool !
I've own about seven VCA but was still feeling I need one or two more ; those particular but quite versatile modules I was the solution.
However, as vactrols are fun as you can do music with gates (?!), attenuator-potentiometers have to be added at cv ins. (voltage divider)
It's way more cool if you can offset a bit the incoming controls.
Fonik's CVP is a good add ; it has glide circuitry as bonus !
http://www.modular.fonik.de/Page15.html
I really wish my panel twice big and lookin like that :
vtl5c3
PostPosted: Mon May 14, 2007 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like the lopass gate a lot too. It doesn't do fast transitions, which is too bad, but the sound makes up for it. It's like switching from a metal and plastic cd player (normal VCA) to a wood and leather victrola. In lopass mode it has a nice brassy effect on the sound.
Idea Idea Idea Idea Idea
funkyfarm
PostPosted: Mon May 21, 2007 10:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you own more than two :
yes ! what about ?
Funky40
G2 patch files: 5
PostPosted: Tue May 22, 2007 10:14 am    Post subject:
sounds and looks great.
how about a PCB run for this one ?
fonik has also a LPG adaption, but i don't know the difference
vtl5c3
PostPosted: Tue May 22, 2007 12:01 pm    Post subject:
My vote is for Fonik's version, which I think was based on Peter Grenader's revision. No analog switch IC required, just one that's mechanical. If I were to build another one, that's the way I would go.
Not sure how doepfer did the feedback mod. If I had money to spend, I would buy one and analyze it.
verbos
PostPosted: Wed May 30, 2007 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got into an argument with Peter about this on SDIY a while back. I explained that the gain of the input stage has to be changed between modes to keep the level constant when the switch is flipped. There is a gain stage on the input, that switches in and out 3 dB of gain.
In the B version the op amp is normally in the high gain mode and the switch adds a resistor to ground to bring down the gain of the signal going in. The C version is normally in low gain mode and the switch adds a resistor to ground in the the opamp feedback loop, making the gain go up.
To get constant gain in all three modes, you need the higher gain in the "gate" and "both" modes and the lower gain in the "lopass" mode. You need a 7211 to do that. If a 292B was built with a 7203, the "both" mode would be 3dB lower than the other two modes.
Peter's claim was that Buchla Tech J.L. told him that 292Bs don't use a 7211.
I have since acquired a 292B of my own and have a picture of the C&K 7211 in it. I hope this puts this debate to bed.
Mark
 Filesize:  84.8 KB
 Viewed:  31101 Time(s)
verbos
PostPosted: Wed May 30, 2007 5:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you increase the gain going through the .0047 uF feedback capacitor, you will get resonance. In practice, this can be done by adding an opamp gain stage between the ouput opamp and that capacitor. Just intercept the line between the switch and the .0047uF cap. Send the switch side into the + input and put a 50k pot with the wiper to the - input, the CCW end to the ouput and the CW side thru a 50k resistor to ground. Send the output of that opamp through the .0047uF cap.
The funny thing is how this control is useless in 2 out of the three modes. You could do it like Wiard Borg II.... insted of a 3 position switch, just use a pot with a switch at the CCW end. Then you have a lopass filter with resonance until you turn the resonance all the way down and switch in the gate for a "both" mode. You then lose the "gate" mode, but you probably just wanted the filter anyway.
mark
synth_ollie
PostPosted: Thu May 31, 2007 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you for this Smile
cheers
OLLIE
CJ Miller
PostPosted: Sun Jun 03, 2007 12:21 am    Post subject: Reply with quote  Mark this post and the followings unread
verbos wrote:
I got into an argument with Peter about this on SDIY a while back...
Hi Mark! I remember reading a thread between you two when I was determined to read all of the LPG stuff in the SDIY archives. No debate with me! My guess is that Peter was just going by what was remembered from the Buchla service schems. The 292B doesn't *say* that it uses the 7211, but as we can all see - this is not to say that it in fact doesn't.
My main concerns are that 1. I still can't afford the switches 2. I feel uncertain how to connect them. I'll figure it out one of these days. I'm still doing flood damage control in my basement from weeks ago. Relatively soon I'll hopefully have finished my PSU/breadboard/testing rig I've been dreaming about for exactly this kind of thing.
Anyway, thank you for showing us! You've got some really wonderful kit to play with.
Snaper
PostPosted: Wed Apr 29, 2015 7:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry about renew this old thread, but im still wondering : 3 modes (gate, lopas, both) with a simple spdt switch?
How?
LFLab
PostPosted: Thu Apr 30, 2015 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Not a simple SPDT switch, but a SPDT with center "off"
CMOS switching is involved.
Snaper
PostPosted: Thu Apr 30, 2015 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Aaaaah, yes. Just checked the scmo again Very Happy
