deadmicro
Joined: Feb 16, 2007 Posts: 8 Location: Philadelphia, PA, USA
Posted: Fri Feb 16, 2007 3:22 am Post subject:
MICRO MODULAR USERS: My second DEAD Micro Modular Subject description: A warning and potential cause to a very unfortunate situation |
Hi there to everyone on the forum!
About a month ago, my second Nord Micro Modular died inexplicably. All I know for sure is, one day the unit worked perfectly fine. The next day, it didn't. The unit will not turn on, the display shows nothing, and the internal components do not get warm to the touch. The AC adapter works according to my multi-meter, so the unit is definitely broken. The same thing happened once before, within 6 months of purchase.
The first time this happened, it was also a mystery, but the unit was still under warranty. I sent it to a company in Florida, along with a copy of my receipt. About a month and a half later, I received a working Micro, paying only to ship the item for service.
Now, several years later, the same damn thing happened again. I looked over at the unit and it appeared to be off. I checked it and the damn thing won't turn on, just like last time! This time the unit is well out of warranty. So what's going on here? How can this happen TWICE, exactly the same way?
The only thing I can't eliminate as a cause this time is a power surge. We did have a power outage not long before I noticed the unit had stopped functioning. I use CyberPower, APC, and Belkin surge suppression and UPS units in my studio. The units are all new and upgraded from the first time, so I doubt it's the fault of my power equipment. Neither Micro has ever been plugged directly into an outlet in its life. Much of the time neither were even plugged in at all! They never exhibited signs of ground loop, were never bumped, dropped, kicked, spilled on, etc. They got first class treatment, and had easy lives. If it was a power surge, then it seems to me the Micro Modular is one SENSITIVE device! Out of all the electronics I have, I've never lost a thing to a power outage.
My prediction is, if I pay to have this thing fixed, it is going to cost me as much for the repair as just going on eBay and buying a working one. I feel ripped off and cheated by Clavia. But if this is Clavia's fault, then there have to be other cases of this. Searching Google, I found no other mentions of "non-functioning", "damaged", "dead", "broken", etc. units.
I don't know what to do with this Micro Modular now other than put it away in my closet so I don't have to look at it any more. I can't throw it out, and it's probably not worth paying to have it repaired.
A word of advice to other Nord Micro Modular users out there:
BEWARE OF POWER SURGES: IF IT'S NOT IN USE, UNPLUG IT.
Also, back up your patches on a regular basis. Better safe than sorry. |
Posted: Fri Feb 16, 2007 4:44 am Post subject:
Re: MICRO MODULAR USERS: My second DEAD Micro Modular Subject description: A warning and potential cause to a very unfortunate situation |
deadmicro wrote: |
Hmm, IMO, this says more about the wiring in your house than a sensitive MM to my ears. There are two MM's in this house, both were bought when they first came out and both have been gigged extensively (right across the globe). We've NEVER had any problems- and that's also using a wide range of PSU's. The iMac in the front room picks up the sound of the refrigerator turning on and off too- so the mains supply is far from perfect.
I'd get a sparky in if I were you  |
Posted: Fri Feb 16, 2007 4:45 am Post subject:
oh yes,
to electro-music.com deaddy  |
Posted: Fri Feb 16, 2007 6:11 am Post subject:
Trivia: Whenever a piece of pro audio gear dies, I always try to figure out why it died.
Did you ever get a specific answer re what was wrong with that micro? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
X-Electric
Joined: Jul 11, 2005 Posts: 182 Location: Warsaw, Poland
Posted: Fri Feb 16, 2007 6:28 am Post subject:
v-un-v wrote: | There are two MM's in this house, both were bought when they first came out and both have been gigged extensively (right across the globe). We've NEVER had any problems- and that's also using a wide range of PSU's. |
Same here - mine sits in front of me, where I usually put fizzy drinks - I spilled a bit of beer on it a couple of times (the unit was off of course), it's always VERY dusty, I use a non original Yamaha power supply, I've used it in a high humidity areas and it still works as it should. IMO they are built pretty solid.  |
deadmicro
Posted: Fri Feb 16, 2007 8:07 am Post subject:
Quote: | I'd get a sparky in if I were you |
I would do that if I knew there was a problem. The main UPS unit I have is a 1500VA CyberPower with voltage regulation. The monitoring software shows a continuous 119-124V. Grounding tests OK, but that wouldn't matter since the Micro Modular uses a wall wart AC adapter. So bringing in a proffessional and saying "my Micro Modular stopped working" isn't warranted yet.
Quote: | Trivia: Whenever a piece of pro audio gear dies, I always try to figure out why it died.
Did you ever get a specific answer re what was wrong with that micro? |
The only pieces of pro-audio gear I've ever had die were two Micro Modulars! As for the cause of the first one, they said the board was bad. That was it.
Mirco Modulars basically consist of a DSP, a MIDI interface, a couple of audio amplifiers, some IC's that read the unit's controls, and a small power module. That's about it. For the unit not to work AT ALL, and to be cold to the touch with power supplied to it, I would guess its something that's used for power that has been damaged. If I could find a service manual for it, I would attempt to diagnose the problem myself. Alas, this kind of info is not easily acquired from a company like Clavia. |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Fri Feb 16, 2007 9:48 am Post subject:
deadmicro wrote: | About a month and a half later, I received a working Micro, paying only to ship the item for service.
You got a replacement or they fixed the old one? |
deadmicro
Posted: Fri Feb 16, 2007 4:05 pm Post subject:
They fixed the old one by doing the following:
1) Remove the old board
2) Replace with new / refurbished / reconditioned board
3) Change the serial number sticker to match the replacement board
In other words, I got the same chassis back with new guts, a few new scratches, and a new SN. |
Posted: Fri Feb 16, 2007 4:43 pm Post subject:
deadmicro wrote: | They fixed the old one by doing the following:
Ah now we are getting closer to what might be the problem.
How many of the connections to the outside world are pcb mounted? The power socket on the micro is pretty poor anyway. I've had similar problems with this- but on other pieces of equipment with the same type of sockets.
If the board is a refurb job it may too have micro-sized cracks in it? This can happen if the unit was left in extreme cold (in a garage or whatever) conditions. This can also cause dry joints.
I doubt, after looking at what mains conditioning you have, that mains spikes are to blame.
My final advice is if this one is jinxed, try to fix it, then flogg it, and buy another unit (reduced price of course for a quick sale and no hard feelings ) |
Posted: Fri Feb 16, 2007 9:28 pm Post subject:
I'll buy it for cheap if you decide to abandoned it!
Have you tried:
1) A substitute power supply? Find one with the same connector, polarity (center = +?), voltage, and power or amp rating (or higher).
2) Opening the device? Most debugging could be done easily by sight...If something looks or smells blackened, burnt, popped, etc, again, it 's probably the problem. |
deadmicro
Posted: Sat Feb 17, 2007 4:13 pm Post subject:
I did open the sucker both times this happened, and in neither case did anything smell burnt. I know that fried smell quite well.
HOWEVER, I just checked the power supply again with a multimeter, and I noticed that the PSU is putting out 13V! On the label it says 9V!
Could someone please check their AC adapter with a multimeter and see what yours is outputting?
If mine is overvolting and its not incorrect labeling, this could be the damn reason why both units failed. A defective power supply from day one, and warranty service that isn't worth a damn. |
X-Electric
Posted: Sat Feb 17, 2007 5:03 pm Post subject:
deadmicro wrote: | [...]I noticed that the PSU is putting out 13V! On the label it says 9V!
Could someone please check their AC adapter with a multimeter and see what yours is outputting? |
As I said before, I'm using a non-original power adaptor that came with a CS1x - I checked with a multimeter and it gives 15.62 V on the output (which should be around 12 btw), then I guess 13 should be also ok.
Some time ago my CZ-101 became to act weird - I checked it's power adaptor (an old, russian one, from late 70's), and there was a bit more than 17V on the output - almost 2 times more than Casio recommended - it acted strangely, but nothing got fried.
I'm attaching photos to show that Micro works ok with voltage even that high.
Description: |
Filesize: |
70.73 KB |
Viewed: |
5779 Time(s) |
Description: |
Filesize: |
48.5 KB |
Viewed: |
5783 Time(s) |
Description: |
Filesize: |
48.4 KB |
Viewed: |
5779 Time(s) |
Joined: Apr 03, 2004 Posts: 24456 Location: The Netherlands, Enschede
Audio files: 297
Posted: Sat Feb 17, 2007 5:29 pm Post subject:
When no current flows those wall warts always have way too much output voltage, nothing to worry about.
When you want to try and fix it you should measure some stuff in the micro itself. Probably a power regulator died. Unfortunately I've never seen the micro's private parts ... so erm here it stops for me. _________________ Jan
X-Electric
Audio files: 297
Posted: Sat Feb 17, 2007 6:16 pm Post subject:
Ah that's the spirit
Such voltages seem OK to me, a bit high on the input seems not really too bad, there is only one DSP to feed and the regulator should be able to do that probably with up to 25 V on it's input.
Besides when too high an input voltage would be the problem the regulator would simply run hot, to then go into thermal shutdwn top awake again after a cool down etc. That is .. as long as it's not over 40 Volt or so.
Or you might get some terrible hum like noise due to a capacitor having had over voltage. Hmm,maybe not necesarrily so, for the capacitor case. _________________ Jan
X-Electric
Posted: Sat Feb 17, 2007 7:16 pm Post subject:
I recommend doing same thing to you deadmicro. If there's no voltage on output of the regulator, then there's no power in circuit at all, and I guess that would be good news, concerning the replacement cost of course when only this part got hurt. When there's no voltage on input - maybe just the power input socket got damaged. Anyway it's a good starting point to diagnose the unit that is not powering on at all. |
Posted: Sat Feb 17, 2007 8:09 pm Post subject:
X-Electric wrote: | I recommend doing same thing to you deadmicro. If there's no voltage on output of the regulator, then there's no power in circuit at all, and I guess that would be good news, concerning the replacement cost of course when only this part got hurt. When there's no voltage on input - maybe just the power input socket got damaged. Anyway it's a good starting point to diagnose the unit that is not powering on at all. |
Great work!  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
deadmicro
Posted: Sat Feb 17, 2007 8:45 pm Post subject:
Thank you all for the help and the excellent ideas. Especially you, X-Electric for the test results and the images.
I tried the same test X-Electric did. With the original power supply I got LOW voltages that were below X-Electric's measurements:
7.6V on the far left lead
4.9V on the right lead
The funniest part is I dug through all the AC adapters I have and found one:
YAMAHA PA-3 (don't ask me where this came from! ) 10VDC, 700mA, + tip = about 12V with the multimeter
I don't know what else to say other than WOW. There is justice after all. It's a shame I didn't do this in the first place. But, who cares now. It works, my unsaved patches aren't lost, and the world is beautiful again. This is the best possible news. No doubt I will be celebrating tonight.
It's a weird one though. The problem was obviously the power supply. It gives enough voltage to the multimeter to give a reading above its specifications, but when it comes time to actually supply power, it's not up the task. It bothers me that I was so sure this thing was dead again. I don't know. I guess its just bad memories from the first time.
So now I've got to track down a replacement power supply. In the meantime, I can use this Yamaha PA-3 that I swear I've never seen before until now.
IT'S ALIVE!
Description: |
Filesize: |
3.33 MB |
Viewed: |
5776 Time(s) |
Description: |
Filesize: |
2.6 MB |
Viewed: |
5769 Time(s) |
Description: |
Filesize: |
2.61 MB |
Viewed: |
5778 Time(s) |
Description: |
Filesize: |
2.24 MB |
Viewed: |
5777 Time(s) |
Description: |
Filesize: |
3.01 MB |
Viewed: |
5777 Time(s) |
Audio files: 297
Posted: Sat Feb 17, 2007 9:07 pm Post subject:
deadmicro wrote: | It works, my unsaved patches aren't lost, and the world is beautiful again. |
Well what can I say, I'm happy for you. It seemed so unlikely, I've never seen, heard of, this problem before and you'd have it twice.
Better cahnge your username now - but please give us a hint then
erm .. that is assuming you'd want to stay around. _________________ Jan
deadmicro
Posted: Sat Feb 17, 2007 9:22 pm Post subject:
Quote: | Better cahnge your username now - but please give us a hint then Very Happy
erm .. that is assuming you'd want to stay around. |
Absolutely, but if I change my nickname, next it will be "deadfirstjuno106filtervoicebuttherestworksok"
But that's the subject of another thread I guess. |
Audio files: 297
Posted: Sat Feb 17, 2007 9:27 pm Post subject:
deadmicro wrote: | But that's the subject of another thread I guess. |
i hope so ... hey noone did the welcome thing for you... aboard, and may all the bugs die that easy. _________________ Jan
X-Electric
Posted: Sun Feb 18, 2007 4:50 am Post subject:
deadmicro wrote: | Thank you [...] X-Electric for the test results and the images. |
Hey, no problem. Glad to see it's working again  |
G2DREAM
Joined: Apr 27, 2005 Posts: 171 Location: Athens,Greece
Posted: Sun Feb 18, 2007 5:28 am Post subject:
As a micro owner too i am very happy for you my friend!!!
______________
cyber-evolution |
Posted: Sun Feb 18, 2007 5:37 am Post subject:
This is all very cool!
Nice one X-Electric- you're a star!
(Sorry for not coming back over the last couple of days, I've been entertaining family).
Tom  |
seraph
Editor
Audio files: 33
Posted: Sun Feb 18, 2007 6:22 am Post subject:
deadmicro wrote: | It bothers me that I was so sure this thing was dead again. I don't know. I guess its just bad memories from the first time.
it looks like a case of self-fulfilling prophecies but who cares now
the force of this forum is great may the force be with us  _________________ homepage - blog - forum - youtube
Quote: | Don't die with your music still in you - Wayne Dyer |
