<on air> Modulator ESP Adventures In Sound
Scoping for Ideas
Page 1 of 1 [10 Posts]
iPassenger
G2 patch files: 78
PostPosted: Wed Feb 14, 2007 2:40 pm    Post subject: Scoping for Ideas Reply with quote  Mark this post and the followings unread
Any recommendations for decent software oscilloscopes for looking at the signals generated by the Nord (or other equipment for that matter)?
Ideally it would run both within music prog (VSTi etc) and as a stand alone (on Windows pc).
Even more ideal would be the ability to run in both stereo (allowing the monitor of phase) and mono modes (seeing actual waveforms), even, even more ideal would be one which doesn't hammer the pc's cpu.
Many thanks
iP
iP (Ross)
X-Electric
PostPosted: Wed Feb 14, 2007 5:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some time ago I used TFD Scope , although as far as I remember it was a bit CPU expensive. Easy and user friendly one though.
iPassenger
G2 patch files: 78
PostPosted: Fri Feb 16, 2007 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers fella, I'll give it a go.
R.
iP (Ross)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Feb 16, 2007 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I like Visual Analyser 8, it is free.
(sorry, link is on old PC, try Google)
iPassenger
G2 patch files: 78
PostPosted: Fri Feb 16, 2007 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also thanks will try that one too.
Smile
iP (Ross)
Funky40
G2 patch files: 5
PostPosted: Sun Feb 18, 2007 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
tryed it today for looking the Waves of my analog VCOs.
It's a cool tool
http://www.electronics-lab.com/downloads/pc/016/Visual_Analyzer/index.html
( hope it works. I had it allready on my Drive. That must be spoken about here some month bevore..................... )
PostPosted: Mon Feb 19, 2007 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
There's a good free (as in beer) VST one called "inspector", I forgot where I got it.
This one looks nice as well;
http://soundlab.cs.princeton.edu/software/sndpeek/
(free as in freedom as well as form)
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Mon Feb 19, 2007 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Found it: http://www.rogernicholsdigital.com/inspector.htm
Looks quite decent, cheers Kassen
PostPosted: Mon Feb 19, 2007 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
That's it! That's the one I use most of the time for actual work. It's not so clear on the phase-corelation side, at least not compared to one of those 2d shapes, IMHO but in return it does have a very clear RMS meter.
Sndpeek is still quite cool (and a version is also built into the Audicle ChucK editor). It's realy good for showing off visualisation of sound to people because you can rotate the 3d visualisation in real time and so on. Would be good for presentations and classes, I think.
jima
PostPosted: Tue Feb 20, 2007 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
thumrightI'm with g2ian - I can certainly put a tick in the box for VA8. thumleft
Jim
