AR gen. problem
Page 1 of 1 [4 Posts]
manatee
PostPosted: Sat Feb 24, 2007 7:44 pm    Post subject: AR gen. problem Reply with quote  Mark this post and the followings unread
hi there!
ther are some weird things going on my sound lab Confused
the AR it's not working that well...he does only one cycle. some times when i push the manual gate he repeats the cycle but only for 3 or 4 cycle. and repeat it's not working at all....
help! I feel that I'm so near Smile
cheers!
manatee
PostPosted: Sun Feb 25, 2007 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
hi again
I allready switch IC1 and IC2 and all switches involved in the AR module.
who do you think it's the guilty party?
1- capacitor C2?
2- tantalum capacitor C3?
3- transistor Q8?
4- or the diodes?
all this components are in it's right place, in there right direction and with the correct value.
any ideia?
PostPosted: Sun Feb 25, 2007 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
So you have repeat off and then you do get repeats nevertheless ?
Did you set it to gated or to trig'd mode ?
manatee
PostPosted: Sun Feb 25, 2007 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
wow this sound lab it's acting totaly strange.....
repeat is now working for a while and than he shuts up for no reason.
looks like vco's don't like to be modulated by AR and LFO at the same time...every time i turn on the lfo on a vco(that is allready pluged to the AR) he will just end the AR cycle and then quit working.
i'll try to record some sound samples and post them here.
thanks
