bugbrand
Posted: Mon Feb 26, 2007 7:49 am Post subject:
Re: Question on PTCs Subject description: ..are these any good for VCOs etc? |
| bugbrand wrote: | Its not so easy or cheap to find suitable PTC resistors for VCO temp compensation etc, so I wondered if anyone could help identify whether these may be useful:: ???::::
1k PTC axial
And another similar one |
looks good, i think. 1k, 3000ppm - exactly the value tom gamble used for his VCO designs.
BTW the next VCO i build will be a renee schmitz design. he uses very cheap and easy to get NTCs... _________________
Tech Buddy at Random*Source |
ickystay
Posted: Mon Feb 26, 2007 7:14 pm Post subject:
Those look nice!
This guy uses Farnell smt tempcos and transistor pairs in his quad vco:
http://hem.bredband.net/bersyn/VCO/vco_quad.htm
(scroll down a bit).
I checked into ordering from the US, and it was going to be some freaking astronomical shipping for what amounted to an ounce of parts. Ditched that idea post haste. |
etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
Posted: Mon Feb 26, 2007 11:50 pm Post subject:
| Quote: |
Farnell are like that even voor Europeans. They have a local office here in the Netherlands that is almost across the road from me. However, since I'm not a registered company, I need to pay a minimum of 50 euros in advance, per order. Oh, and you need to get registered with Farnell before you can order trom their shop, which (at least for the Dutch branch of Farnell) means faxing a company registration to their office. So if you're not a company, you can't even order from their online shop.
Although I heard this policy differs from country to country. |
bugbrand
Posted: Tue Feb 27, 2007 3:17 am Post subject:
Yeah, I think you can make up a trading name / company if you want to register. I don't use them too much, but there's some useful bits.. I find searching for anything pretty tricky 'cos they stock so many items - got the catalogues and they're meaty!
Lets discuss some more about these PTCs - if they're deemed to be useful then I'd be able to order a bunch next time I order from Farnell and then ship 'em out wherever for very little..
But first I want INFO! -- I'm sure there was a webpage somewhere that really explained about exchanging different ptc values -- for example, if I want to use them in the XRVCO should I series two of them or just use one and halve the input resistors?
Thanks guys _________________ http://www.bugbrand.co.uk
Posted: Tue Feb 27, 2007 4:03 am Post subject:
| bugbrand wrote: | -- for example, if I want to use them in the XRVCO should I series two of them or just use one and halve the input resistors?
divide the value of the input resistors according to the tempco value. that's what ray wilson did in the last revision of his VCO! (same case: tempco in the feedbackpath of the summing opa) you can always do this as long as you keep the ratio. _________________
bugbrand
Posted: Tue Feb 27, 2007 5:09 am Post subject:
| bugbrand wrote: | | Ahha - yes he's got 49.9k input resistors and a 1k tempco in this VCO -- ahhhh, Ray's always the source! |
actually i bought the 1st revision PCB and had some 1k tempcos in the drawer. i emailed ray to verifiy my suggestion of replacing the input resistors, what he did then  _________________
Coriolis
Joined: Apr 11, 2005 Posts: 616 Location: Stilling, Denmark
Posted: Tue Feb 27, 2007 12:27 pm Post subject:
One thing I don't get - from Renee Schmitz' site:
| Quote: | | One can use it as the feedback resistor of an opamp, thus giving a gain of that circuit which is proportional to T. But this is usually avoided, because tempcos have (one must say had, with newer types) inductance, and you introduce errors from the opamps output voltage drift. It works when you use opamps with very low drift. |
As far as I can see, he puts the tempco in the feedback path of an opamp in, for example, his VCO3! Am I wrong? Same thing with Ray Wilson and Thomas Henry designs btw; are they wrong too?
C |
para
Posted: Wed Feb 28, 2007 9:22 am Post subject:
if you don't mind me jumping in here Tom,
i've been meaning to ask if there is a difference between the $8 thermistor and the NTC which runs like $0.35, that i'm not seeing?
the $8 tempco's run at : -40°C to 125°C / which is : -104°F to 257°F (i think i did that right?)
and NTC's run at : 55°C to 125°C / which is : 131°F to 257°F (that too?)
obviously the tempco has a much bigger range but i can only image the NTC running hotter then room temp anyway, so i would think 131°F and up is completely reasonable, even expected.
if they are both meant to hold a steady resistance at excessive temperatures then why are they not interchangeable?
steven |
Dan Lavin
Joined: Nov 09, 2006 Posts: 649 Location: Spring Lake, Mi, USA
Audio files: 21
Posted: Wed Feb 28, 2007 11:05 am Post subject:
para:
'tempcos' and 'NTC's" are 2 forms of thermistors = thermally sensitive resistors. They don't 'run' at temperatures (unless you get a switching type PTC thermistor); they vary their resistance with temperature.
First, there is really no such thing as a 'tempco'. It is really a PTC thermistor (positive temperature coefficient) thermistor. If you use the term "tempco' outside of the synth DIY circle, engineers and techs will look at you like you've got a third eye. 'Tempco' came from the original SSM music IC application data sheets where the schematics appreviated a device with a 3300ppm/degreeC positive temperature coefficient device as a "+3300ppm/C tempco" device. We've been living with that term ever since.
Next, the temp ranges mentions are the operating ambient ranges for those devices. I think the NTC should be minus 55C (-55C) not +55C.
NTC's can be used in place of PTC's but you have to take into account that NTC's have a logarithmic R-T curve (resistance vs. Temperature) and the 'tempco' has a linear R-T curve. Also, NTC's typically change -30,000 to -50,000ppm vs 3000 to 3500ppm for 'tempcos'. Generally you can linearize and knock down the R-T slope with a series and parallel fixed resistor. And of course the circuit location will need to be changed. For instance, if you had a voltage divider with a PTC on top and a fixed resistor on the bottom, you would need to replace the PTC with a fixed resistor and the original fixed resistor with the NTC network described above.
Well I hope this doesn't add to the confusion |
Dan Lavin
Audio files: 21
Posted: Wed Feb 28, 2007 11:13 am Post subject:
| Quote: | Quote:
Coriolis:
I think what Renee is referring to is that most 'tempcos' are actually wirewound resistors. The wire being +temperature sensitive wire. If that's the case, they really are an inductor and with DC currents, no big deal, but with an AC signal (ie audio), there would be a reactance effect. Not sure if all +3000~3500ppm/C PTC thermistors are still made this way, but maybe Renee has made some measurements? |
para
Posted: Wed Feb 28, 2007 12:35 pm Post subject:
actually that makes it more complicated then i was expecting. i was under the impression that its job was to keep a steady resistance under varying temps, but you say that its job is to intentionally change a specified amount based the temp it is "told" to run at or however you want to say it ????????
hmmm
and the datasheet for the NTC i read didn't indicate - minus 55C ?? it doesn’t matter i’m not going to be able to figure out how to get it to react properly in things like the XRVCO's i have Bugs printing me or anything else anytime soon. its a bit over my head to honest, but i'll keep beating my head against it and one day it will make sense, just like everything else.
thanks ant!
steven |
Dan Lavin
Audio files: 21
Posted: Wed Feb 28, 2007 1:16 pm Post subject:
| Quote: | | i was under the impression that its job was to keep a steady resistance under varying temps, but you say that its job is to intentionally change a specified amount based the temp it is "told" to run at or however you want to say it ???????? |
All resistors will change resistance somewhat with temperature, but you can buy ones with very low ppm numbers to minimize the effect. Generally for Synth DIY, these aren't needed.
The reason temperature compensation is needed in many circuits is that the PN junction in semiconductors will vary with temperature and it's output degrades with increasing temp at a rate of around -3300ppm, so to compensate we use +3300ppm to negate the effect....well in theory anyway. There are tolerances on both sides to figure in, but you get the picture.
Good luck on your projects! |
Fernando
Joined: Dec 30, 2006 Posts: 286 Location: Barcelona & Emporda, Spain
Posted: Fri Mar 02, 2007 3:26 pm Post subject:
| Fernando wrote: | Fonik, I'd like to build some Rene's 4069 VCOs too (oops, assuming you meant this one!)
It seems the 4069 gets hot. Maybe a heatsink glued to the chip will help?
i actually planned to build the zero oscillator but thought of the 4069, too. when i remember right, the temperature isn't that big issue. it gets hot, but it won't burn!!
and there are other project to be done before. i will start the 3rd cabinet not before 2008. _________________
Joined: Jan 31, 2003 Posts: 18324 Location: Durham, NC
Audio files: 235
Posted: Fri Mar 02, 2007 4:02 pm Post subject:
That's a fine site. That guy does some great work.  _________________ --Howard
my music and other stuff |
Coriolis
Posted: Sun Mar 04, 2007 1:08 am Post subject:
Sorry to quote myself, but isn't there a problem here:
| Quote: | One thing I don't get - from Renee Schmitz' site:
As far as I can see, he puts the tempco in the feedback path of an opamp in, for example, his VCO3! Am I wrong? Same thing with Ray Wilson and Thomas Henry designs btw; are they wrong too? |
C |
