1st pics of Stylus Keyboard Case
Page 1 of 1 [15 Posts]
bugbrand
PostPosted: Wed Mar 07, 2007 2:40 pm    Post subject: 1st pics of Stylus Keyboard Case
Subject description: ..also holds 7 Fracrak modules
Whoop, though its not quite finished yet...
Porta-modular case holding 7 fracrak modules, 1v/oct stylus keyboard and footswitch functions!
Built from Ray's MFOS design for a 1 octave keyboard but built with a simple stylus interface (allowing compact size and a wierdy feel!)
!!!Plus YouTube Demo Video (edit - now online)!!!
Whoop!
This is so fun to play with.!.
Still a few little bits to tweak/do -- low leakage hold capacitor & quality opamp for the keyboard S/H, redo the env gens, put in the footswitch sockets and wire up the passive output...
But its working already! Today I had fun playing it with my newish cranky ISD1416 lofi modular sampler (VC-pitching - not 1v/oct yet though..)..
Features::
Case - similar style case to the BugBrand DroneMachine but a bit deeper.
Holds 7 Fracrak-width modules.
Internal +/-12v power supply..
Keyboard - 3.5 octave chromatic stylus keyboard with wobbly wand!
Trigger output (plus LED)
Gate output (plus LED)
Two drum style env outs -- vari-decay rate fired from the trig output.
(based on Thomas Henry Electronic Drum Cookbook ideas -- but not actually working quite right at the moment.. silly mistake!)
CV1 - 1v/oct output with glide
CV2 - 1v/oct output with glide, pitchbend / offset dial (add or subtract roughly 1v (ie 1 octave) - needs a little tweaking), range switch adds or subtracts 2 octaves (+ or - 2v or 0v -- centre off switch)
Then in the same panel there's:
Footswitch (/panelswitch) - electronic switch with momentary or toggling response. Also trigger output - 1ms pulse each time the button is pressed
Footpedal - +5v signal range passed through an attenuverter - giving attenuated + or - 5v range.
Passive output - simple / useful audio output (not yet wired up)
Whooop!
The panel is based on thin wood, painted over (yukky green!) and then a laminated laser-print acetate is stuck on top and varnished --- I think the idea of laminating the frontpanels (I hadn't done so on the drone machine) comes from Mikmo's webpage of his DIY frontpanel experience -- Thanks! ..Its still not a perfect solution, but its pretty simple and effective.
http://www.bugbrand.co.uk
toybox
PostPosted: Wed Mar 07, 2007 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm always vary impressed by your equipment cant wait to see the video Shocked
mY MusIc
http://www.myspace.com/toyboxbastard
crashlander42
PostPosted: Wed Mar 07, 2007 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
That looks like fun.
How do you tin your homemade pcbs? I did a couple of searches and came up with nothing.
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
bugbrand
PostPosted: Thu Mar 08, 2007 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a bunch!
The keys are just covered with solder - hence the slightly dirty nature of them..!.. I'd not really thought of tinplating before but it'd be good, no? Rapid (my regular supplier) has crystals for tin plating
YouTube Video is now up - playing the DroneMachine
synth_ollie
PostPosted: Thu Mar 08, 2007 3:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I just must say that kbd looks great !
bugbrand
PostPosted: Thu Mar 08, 2007 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ollie!
.....I've just uploaded a schematic for the simple electronic switching circuit - uses a momentary button to generate a momentary or toggling gate output, plus trigger pulse of c.1ms. Easily made into a dual unit using the spare gates.
http://bugbrand.co.uk/pages/electronics.htm
Electronic Mom/Tog switch schematic
 Filesize:  104.58 KB
 Viewed:  7509 Time(s)
para
PostPosted: Thu Mar 08, 2007 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
nice work tom! great additions to the control too
PostPosted: Thu Mar 08, 2007 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Very impressive!
I don't completely understand what the extra controls are for though. Then again, any extra controls have to be a good thing! Very Happy
Scott Stites
Audio files: 96
PostPosted: Thu Mar 08, 2007 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Typical BugBrand goodness!
Do you etch the keyboard PCB or put a Dremel tool to it?
Scott
Wild Zebra
PostPosted: Thu Mar 08, 2007 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Bugbrand, that is awesome. Nice work.
"your stripes are killer bro"
bugbrand
PostPosted: Thu Mar 08, 2007 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, thanks for all the goodness!
Boo I didn't have much of a play today - sidetracked by laptop hardrive death = badness
Uncle -- the controls are varied.. The gate/trig is standard, but the trig is also taken direct to generate two vari-decay drum style envelope gens. There're then two CV ouputs - the first just has glide, whereas the 2nd (also having glide) has offset controls - a 3 position switch gives +2 oct, normal, -2 octave (ie adds or subtracts 2v) and there's a bend dial - centre-detent knob that is meant to range between -1v and +1v thus giving an octave shift in either direction (though the range isn't set quite right yet) - basically the 2nd CV can be offset from the 1st CV in a nice easy manner direct from the keyboard module....
The other parts are to use up the space -- feet functions and just a simple passive output to 1/4" jack (from banana)
Scott - yeah, that's just an etch - I took the image from an SN942xx (?i think) project from a German mag, stretched and multiplied it into 3 and a bit octaves.
...should be setting up a CNC router before too long, so more experiments in store.
Inspiration from this amazing Buchla Magic Flute image I saw today:: wow ::
(via MatrixSynth & The Audities Foundation (check their other Buchla models too))
shawn
PostPosted: Fri Mar 09, 2007 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
CNC router huh? Biter! j/k Smile Finally getting to do your xr2206 on the router. Had to do some conversion from the image from the pdf to the actual eagle pcb so I can redraw the tracks (guess I could have just asked you for the file)
Way off topic but I wanted to point you to a good website regarding eagle pcb and cnc routers.
http://www.brusselsprout.org/PCB-Routing/
That keyboard looks pretty amazing. Kudos.
bugbrand
PostPosted: Sat Mar 10, 2007 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey thanks a load Shawn - that's really damn useful 'cos I'm using Eagle & will be using Mach3 too - so, spot on!
PS - yeah, I can certainly send you the XRVCO eagle files if you'd like (and if its not too late) - I'd also be very interested to see what results you get from either method!
shawn
PostPosted: Sat Mar 10, 2007 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll pm you my email address. Smile
synthmonger
PostPosted: Sat Mar 10, 2007 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow! That is some very swanky work Bugbrand!
