Some questions about DIY power supplies
Page 1 of 1 [16 Posts]
crashlander42
PostPosted: Sat Mar 03, 2007 2:31 pm    Post subject:  Some questions about DIY power supplies Reply with quote  Mark this post and the followings unread
I just put together my first diy power supply (and I'm still alive!) using this layout and have a couple questions.
My voltages coming out of it are not exactly 12v. I have +11.75 and -11.83. Is this type of variation normal?
I seem to have my positive voltage coming off of my 7912 and my negative is coming off my 7812. Is that even possible? Positive voltage off of a negative regulator?
Any one built this before that might have some insight into whats wrong, or maybe it's just my multimeter.
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
PostPosted: Sat Mar 03, 2007 2:42 pm    Post subject: Re: Some questions about DIY power supplies Reply with quote  Mark this post and the followings unread
That's definitely an unwanted situation ...
I'd check the voltage after D1 and D2, after D1 there should be a positive voltage and after D2 a negative one. If not put the diodes the other way around - I hope that he regulators did survive this ... but they do have every right to give up under such a condition I'm affraid. Also C1 and C2 will not be too happy about this, so don't leave it on too long.
PostPosted: Sat Mar 03, 2007 3:43 pm    Post subject: Re: Some questions about DIY power supplies Reply with quote  Mark this post and the followings unread
just to be shure: how did you use the multimeter? you don't mixed the connections? com to ground?
sometimes we do these strange things... (i recently built a MFOS dual VCA, hooked it up and it didn't do anything - just nothing. everything seemed to be okay - and eventually i recognized that i've forgotten to put the IC into the sockets!!!!)
PostPosted: Sat Mar 03, 2007 4:31 pm    Post subject: Re: Some questions about DIY power supplies Reply with quote  Mark this post and the followings unread
Oh yes we do, good question about the polarity !
crashlander42
PostPosted: Sat Mar 03, 2007 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
AH! Yes! I am retarded and had my leads to my multimeter hooked up wrong. wow. Power supply works fine. Smile Thanks! Embarassed
My DIY stuff Flickr
PostPosted: Sun Mar 04, 2007 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
hey, that's great. simple solutions are what we want sometimes (i was very happy when i recognized i only forgot the ICs!) Very Happy
BTW the variation is normal, i think. you may want to take a look at the datasheet.
PostPosted: Mon Mar 05, 2007 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah,
The spec's only promise somewhere between 11.5 and 12.5 for the 7812. I imagine the 7912 wouldn't be any more accurate than that.
stefano
PostPosted: Fri Mar 09, 2007 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
Yeah,
I built the same project and I get a -12V from negative voltage and a +10.5V voltage from the positive one. Should I change the 78xx regulator ?
PostPosted: Fri Mar 09, 2007 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would check everything else first. (diode & cap polarity?) The 78XX has a different pinout to the 79XX, is that okay? It's pretty rare that a regulator would be so far out without just dying. Does it run hot?
crashlander42
PostPosted: Fri Mar 09, 2007 6:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Once I corrected my multimeter problem ( Embarassed ) I found I was getting +11.98 & -11.94. Which seems reasonable considering the specs for the regulators. Make sure you've got good heat sinks. Those things get hot.
While we're on the topic. This seems like a good quick cheap (cost me about $3) and easy power supply project, but I'm sure it wouldn't run a modular. Is there a DIY power supply project out there for greater power needs?
My DIY stuff Flickr
zipzap
PostPosted: Sat Mar 10, 2007 3:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it´s quite ok. I would use a full wav rectifierer (4 diodes in a ring). Better because it produces less ripple and the regulators have an easier job.
The rest of the design is common and has been used many times.
The cabs can be increased (i use 10000uf), and you can use regulators with different power ratings. I use the 1A types, enough for quite a number of modules. you can also use more of those regulators in parralell if one is not enough. just give each regulator a 10uf and a 0.1uf cab. But don´t connect the outputs, they are to be used seperately for different mudules.
Only grund is connected (right by the big cabs)
Only thing to look after is that the transformer and the diodes can handle the power. The 0.1 cabs must be right by the regulator, i soldered them directly to the pin.
http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines
zipzap
PostPosted: Sat Mar 10, 2007 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
like this.
http://www.synrise.de/diy/supply/schaltplan.htm
c1/5 depends on the total power consumption, 10000uf will be enough in any case, but i´m no expert in this question...
the diode in the negative rail is just a power indicator, not needed.
The whole thing right from c1/5 can be built several times in parallel.
crashlander42
PostPosted: Sat Mar 10, 2007 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. I'm gonna play with these this weekend. I'm pretty sure I've got a grasp on the concept now.
My DIY stuff Flickr
PostPosted: Sun Mar 11, 2007 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Keep in mind though that you can't do this if using a transformer like the one in the first schem. To have full wave rectification on a bipolar supply you'll need a centre tapped transformer, like the one in that last schem.
PostPosted: Sun Mar 11, 2007 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Because it uses a single tap transformer, the positive going cycle goes to the +ve regulator, and the negative one to the -ve. This means that the current you draw from either side can only be half of what the transformer is rated at.
The transformer is always going to be the most expensive part of a PSU like this, and will be the deciding factor in it's current handling capabilities. The diodes, regulators and caps don't cost very much and will be basically the same, right up to one which supplies 1Amp per rail. (which would be fine for most medium sized modular setups)
The type of transformer I'd recommend is a toroidal one like this
http://www.jaycar.com.au/productView.asp?ID=MT2113&CATID=19&keywords=&SPECIAL=&form=CAT&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=539
About AU$50
crashlander42
PostPosted: Sun Mar 11, 2007 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
AH! I'd been wondering what those big copper doughnut lookin things were.
I've had a lot of luck with finding cheap parts. I have this Skycraft place down the street from me thats been selling surplus for NASA and defense contractors for the last 30 years. They even had LM709's. I'll have to check them for copper doughnuts.
My DIY stuff Flickr
