today> Twyndyllyngs Chez Mosc
PS3100 Resonator PCBs
Page 5 of 12 [293 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, ..., 10, 11, 12 Next
Fernando
PostPosted: Tue Mar 13, 2007 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
well done, thanks a million for working this out!!!
krisp14u
PostPosted: Tue Mar 13, 2007 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
PCBs arrived yesterday and i populated and tested one PCB.
Everything is fine, worked instantly.
(only one minor error - i mistyped the web address: fonik.modular instead od modular.fonik Shocked )
Nice 1 fonik can't wait to get hold of the PCB's you have done a fine job
if any one is needing the VTL5c3/2 to make this pcb I have some spare PM me
they are 2GBP each + postage
cheers paul darlow
PostPosted: Wed Mar 14, 2007 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
the documentation for the PCB is now online:
PS3100 PCB documentation
etaoin
PostPosted: Wed Mar 14, 2007 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Great stuff.
You have an LM1448 in the BOM. That probably needs to be the LM1458?
andrewF
PostPosted: Wed Mar 14, 2007 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
VERY impressive documentation!!
you deserve a synth-diy medal thumleft
PostPosted: Wed Mar 14, 2007 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Etaoin wrote:
Great stuff.
indeed! will correct that immediately!
BTW any comments welcome...
PostPosted: Wed Mar 14, 2007 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks great Fonik, top job! Cool
I would get one, but I've just got way too much on my plate right now.
Fernando
PostPosted: Wed Mar 14, 2007 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
you are a master! thank you very much!
etaoin
PostPosted: Wed Mar 14, 2007 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there a specific reason you have chosen silver mica caps?
Or more specific, can I use polystyrene there? I have plenty of 1nF polystyrene, but would have to order the (expensive) silver mica ones.
PostPosted: Wed Mar 14, 2007 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
it's good practice, i think - and it follows the original design. you may use poly or ceramic instead...
etaoin
PostPosted: Thu Mar 15, 2007 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, but general poly or ceramic would be less stable I guess. That's why I wondered if silver mica was chosen for a property that polystyrene also has (low leakage, for example).
Ray Wilson still specifies either silver mica or polystyrene for his VCO (where others chose polypropylene, by the way).
Anyway, I'll try polystyrene and see how that sounds. There's only one shop over here that sells 1nF silver mica (at about 3 euros each). I might get them if I need something else from them...
Funky40
G2 patch files: 5
PostPosted: Thu Mar 15, 2007 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry,
1.) what is silver mica in german ? Is it Styroflex ?
2.) and polystyrene ? folie ?
Fernando
PostPosted: Thu Mar 15, 2007 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Styroflex = polystyrene, afaik
Funky40 wrote:
sorry,
PostPosted: Thu Mar 15, 2007 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Funky40 wrote:
sorry,
silver mica is called "glimmer" in german...
PostPosted: Thu Mar 15, 2007 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Silver Mica and Polystyrene both have low Dielectric absorption, which isn't just about leakage, it's also about how the cap discharges as well, and the uniformity that the charge is released. Both would be good.
Here's a sticky on the subject (look at the bottom for Blue Hell's link, not the original post).
http://electro-music.com/forum/topic-7474.html
I think DA% is discussed in Part II of the article. Either way, everyone should read both articles on choosing capacitors (as well as the many other papers at that site!)
-Justin
Funky40
G2 patch files: 5
PostPosted: Fri Mar 16, 2007 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, thank you guys
sneakthief
PostPosted: Fri Mar 16, 2007 11:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just received my PCB in the mail yesterday - looks great Cool
Danke Fonik!
Sneak-Thief - raw electrofunk
etaoin
PostPosted: Sat Mar 17, 2007 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I have two suggestions for a possible future run:
C16 is a bit too close to U4. 680nF WIMA doesn't fit, for instance. Also, it's useful to have an extra hole at 5mm as well for the larger capacitors.
C7, C9 and C11 could also do with 5mm spacing. The only thing I have that actually fits there is multilayer ceramic, which is of course terrible in the audio path.
Otherwise: great job!
PostPosted: Sat Mar 17, 2007 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
wow. do you think there would be this much interest?
sure. i had to bend the pins. not beautiful but it works.
WIMA MKS-2-5 would fit.
etaoin
PostPosted: Sat Mar 17, 2007 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see WIMA also have 680nF in the MKS02 line so I think I´m off to stock up on MKS02 caps.
PostPosted: Sat Mar 17, 2007 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice looking boards Fonik.
PostPosted: Sat Mar 17, 2007 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, you are right: the MKS02! that's the one with RM2.5, NOT the MKS-2-5! my fault.
philpeery
PostPosted: Sun Mar 18, 2007 7:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fonik, this looks like an awesome project! I missed the original announcement, are there any boards left over? I'd take 2 in a heartbeat! If not, will there be another run?
Regards,
Phil
PostPosted: Mon Mar 19, 2007 12:18 am    Post subject: Reply with quote  Mark this post and the followings unread
there are still a few PCBs left...
etaoin
PostPosted: Mon Mar 19, 2007 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
By the way, is the "wet" output supposed to be lower gain than the "dry" output?
I need to have to mix output at about 90% and up to even hear the filtered signal.
