Warp633 ...switch pinouts?
Page 1 of 1 [8 Posts]
Freq Band
PostPosted: Mon Dec 18, 2006 7:21 pm    Post subject: Warp633 ...switch pinouts?
Subject description: finished except for....
WARP633
description:
http://m.bareille.free.fr/modular1/warp633/warp633.htm
schemo:
http://m.bareille.free.fr/modular1/warp633/warp633schem.pdf
Hello,
I built this last night, point=to-point wiring, following the schemo.
but with a quad OpAmp (AD713 or similar).
I've some AD633's coming anyday now.
I'm trying to figure out the destination of the "connector pins"...that go to the "mode" switch, SW3....
(board pinouts 1,2,3,4,5)
...and to what kind of switch ?
The photo is not clear, but it looks like a 3PDT or....?
Anyone know this?
...oh, also....Marc states that the "Z" input is optional, and "Z" must be grounded if not used. I am assuming this means if I do include a "Z" input jack, that it should be a shorting type jack, shorted to ground when nothing is plugged in. Correct?
thanks...pics soon.
=FB=
Freq Band
PostPosted: Thu Dec 21, 2006 9:14 pm    Post subject:
Subject description: somebody?
I know there's a few people who have built this.
It's sitting there waiting for a switch........
...I have a chinese "fear-of-frying" the ad633....I have only two of them. Crying or Very sad
=FB=
guitarfool
PostPosted: Mon Feb 26, 2007 8:07 pm    Post subject: Warp633...switch pinouts? Reply with quote  Mark this post and the followings unread
Hello - just joined this forum!
The switch in question is a DPDT. It is not obvious how to wire it up even if you bought PCBs from Marc, as I did. See my webpage for more info:
http://www.guitarfool.com/
http://www.guitarfool.com/modules/Warp633.html
This is one amazing modulator, BTW.
 Filesize:  36.56 KB
 Viewed:  264 Time(s)
synth_ollie
PostPosted: Tue Feb 27, 2007 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
hi guitarfool
welcome
been looking at you modular many times
http://www.guitarfool.com/modular.html
very nice ! Very Happy
Sonarbase
PostPosted: Sun Mar 18, 2007 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
@guitarfool:
Hi, is this top or rear view? The docs I got from Marc show the switch pins the other way around...
If I wire the switch both ways it just doesn't seem to modulate... Evil or Very Mad
SB.
Sonar base
Sonar base on myspace
Sine
PostPosted: Sun Apr 20, 2008 6:11 am    Post subject:   Reply with quote  Mark this post and the followings unread
Hi all, I have been lurking for a wile and this is my first post here.
In the AD633 datasheet there is an example "divison" circuit and from that I can roughly determine how to wire the switch, but i can't figure out why the R17 / R18 divider is there or how that fits in the circuit.
Does somebody have an idea how to correctly wire this switch ?
guitarfool
PostPosted: Sun Apr 20, 2008 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome
I'm not real clear on this myself. I haven't looked at this in a long time. When the switch is in "divide" mode (4 connected to 5, 1 connected to 3), R18 and R17 attenuate the output of U2 which is fed to the "mix" pot.
I re-uploaded my drawing from before - it must have gotten lost in the big crash a while back. I've posted Marc's version below. The switch is a DPDT (on-on) switch, which is really 2 SPDT (on-on) swiches, so left-right (front-back) doesn't matter. That's why mine is a mirror image Very Happy
 Filesize:  16.15 KB
 Viewed:  4914 Time(s)
Sine
PostPosted: Mon Apr 21, 2008 4:28 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Thanks guitarfool, that explains a few things
Time to fire up the soldering iron Smile
