 Forum index » Artists » Seraph
AlgoXenoJazz
Page 1 of 1 [4 Posts]
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Mar 12, 2007 3:58 pm    Post subject: AlgoXenoJazz Reply with quote  Mark this post and the followings unread
well...what you hear here is an experiment involving midi data being generated by M, sent to LMSO that retune them, then forwarded to Reason that plays them and finally recorded on Logic Pro thru Soundflower (no ReWire). All in real time Exclamation The scale used is "septimal heaven" I already used for my other piece "Septimal Klezmer" but the outcome is very different Very Happy
arrow Listen to AlgoXenoJazz
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Mar 12, 2007 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
this picture shows midi assignment for M. Input comes from an Oxygen 8, 3 outputs go to LMSO then to Reason and the 4th goes directly to Reason for drum sounds. It's kind of tricky. I couldn't use ReWire because of conflicts between M and Logic so I simply open Logic after Reason and connect the 2 applications thru Soundflower Idea
 Filesize:  145.47 KB
 Viewed:  908 Time(s)
EdisonRex
Audio files: 172
PostPosted: Wed Mar 21, 2007 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool, you use M. Interesting piece. Smile
Garret: It's so retro.
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Mar 21, 2007 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks EdisonRex
