TL072 vs. better ones / Replacing 4OPa chips with 2x 2OPAs
Page 1 of 1 [8 Posts]
Funky40
G2 patch files: 5
PostPosted: Mon Apr 02, 2007 3:57 am    Post subject: TL072 vs. better ones / Replacing 4OPa chips with 2x 2OPAs
Subject description: i have drawn a little Add-on PCb. Make this sense ?
there was a post from 3 Phase.
The Thread is overall meant that i like to hear more about cheap OPAmps ( TL 072) versus better ones ( 2134, and what there exists).
But my post now is about a converter PCB ---> Quad OPA--> 2x dual OPA
3phase wrote:
just one thing about the pcb and schematics,
I started to experiment with more expensiv op amps and found areas where i got significantly better results than with tl082 when using opa2134.
Sometimes as significant that i dont like to use TL´s in the audiopath if possible..
I even modified my drummachine..and it just sounds better...
problem. There is no 4 op chip availible anymore, only 1 and 2 op amp packages in 8 pin housings. Same applies to many other highend opamps. Often only singel opamp chips are availible..but that is only for the real expensiv ones.
What i want to suggest is to avoid 4 op amp chips in audio circuits where possible to allow modifications and experimentation with high end audio op amps.
i cant really say if its worth the hazzle yet..have to do some experiments..just can say that i like the sound of the OPA´s much more than the somhow more grainy sound of the TL´s...
The OPA´s have a finer and warmer sound...less harsh more silky...
especially in stages that amplify this gets vissible...
In others the change is maybe not big enough to justify the 10 times higher cost than a TL...but it might be still good to have the option.
I'm very courious about this things.
Unfortunatedly my PCBs are all drawn for 4OP Amps.
( and Boosters become more and more important for me. And as i undesrtand this is such a situation where a better OPAmp could be the right choice)
Now i just draw a little PCB to replace one TL074 with two 2Op Amps.
what do you think about this Pcb . Makes it sense to test it ?
are the caps right, or has something to be changed ?
Because of space, one needs to stack some sockets i think.
Can such a add-on replacement be used regardless ?
I have no Idea about this Things, maybe it is just a stuppid Idea.
If not, i look that i get this edged
 Filesize:  75.36 KB
 Viewed:  4679 Time(s)
Scott Stites
Audio files: 96
PostPosted: Mon Apr 02, 2007 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks right to me! I don't normally put caps across the rails, but that doesn't mean it's not right.
One alternative you might consider is that TI still manufactures the OPA4134 in SMT (OPA4134UA). If you don't mind soldering SMT, you might be able to make a little surf-board to mount them on - you could easily make it fit the footprint of a DIP part. The added advantage is that all four packages are on the same substrate, and the OPA4134 has an excellent cross-talk spec.
Downside is it's SMT Evil or Very Mad I can deal with it, but I still don't like it. Main reason I hate'em is you have to do something like the above if you want to breadboard with them.
Take care,
Scott
toppobrillo
PostPosted: Mon Apr 02, 2007 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
OPA4277s are what i have, it's a quad 177 are they no longer available?
Scott Stites
Audio files: 96
PostPosted: Mon Apr 02, 2007 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Why, yes! Yes they are (according to TI).
Cheerios,
Scott
etaoin
PostPosted: Mon Apr 02, 2007 10:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also note that the TL you are replacing probably already has decoupling caps so it might not be necessary to add more.
PostPosted: Tue Apr 03, 2007 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Wouldn't it be more important to put a bypass cap on the main board from the +ve to GND and from the -ve to GND? Therefore, you wouldn't need to worry about them on the daughter board at all.
Funky40
G2 patch files: 5
PostPosted: Tue Apr 03, 2007 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
the thing with the Caps i don't understand really.
an electronic expert sayd in the german Synthesizerforum that both works,
from Ve- to Ve + and from Ve- to Ground plus Ve+ to Ground.
In another disscussion it was sayed that the Ground is very very important,
and one gets the risk to "disturb" a proper Ground when decoupling into the Ground.
So i draw my modules, -just very simple ones as Mixer, Buffer and Inverter-, with decoupling between VE+ and Ve-.
But now i changed this, because i was not shure about how to do when putting OpAmps in series.
Ok, i think i see some more clear about this and the converterboard.
I read between all the words that it is not in general a Problem to deal with such a Board,
also when there's a need to stack Ic sockets.
It's good to know that the decoupling is not needed when the basic Ic allready is.
In one way i decouple all ICs.
As with all this things, i was really unshure.
But hey: i have allready own modules running Very Happy
Thanks alot for Replays
zipzap
PostPosted: Tue Apr 03, 2007 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just some thoughts - for discussion:
when high gain is needed or smaal signals are processed the choice of opamp is important to me because of noise (and distortion).
in most cases on a synth i think it doesn´t really matter, since your generating audio on high level from the start, rather than amplifying a tiny signal from a mike or LP. With a 10v signal noise is no big issue.
I´ll make some experiments if i can hear the difference from a tl072 and say an opa627 at different gains. some switch for direct comparing. Maybe one is more silky, the other more grainy. don´t know but it interests me. I think the main difference is the input noise.
in other non audio aplications like cv summing in vcos, integrators etc the right opamp can make a big difference.
I read some hifi forums from time to time. There are many questions about opamps. Some people say that the surrounding like layout, correct decoupling, right source impedance etc is more important than the amp itself. Some bipolar highend low noise opamps are said to perform worse on high source impedances (in the circuit) than the old 5534 or tl072.
http://www.myspace.com/lorolocoacousticpop
http://www.myspace.com/petrolvendor
music and transcribed jazz basslines
