rubendelacosta
Posted: Thu Apr 26, 2007 8:48 am Post subject:
stop me if i'm wrong!! Subject description: psu ideia |
it's too obvious to be right...i don't know.
but following ray's way to hook up two 9v batterys...could i just hook up two 15v 1A DC transformers like this? :
somthing like this doepfer low cost psu kit http://www.doepfer.de/A100_DIY_low_cost.gif
can it be done?
thanks, rubens. |
Dan Lavin
Joined: Nov 09, 2006 Posts: 649 Location: Spring Lake, Mi, USA
Audio files: 21
Posted: Thu Apr 26, 2007 9:08 am Post subject:
| It does work with AC transformers as long as the output connections are in phase. Never tried DC, though. |
rubendelacosta
Posted: Thu Apr 26, 2007 9:17 am Post subject:
maybe some extras would have to be made. I can see two caps on doepfer's kit.
would be nice not messing arround with 220v. |
Wild Zebra
Posted: Thu Apr 26, 2007 9:52 am Post subject:
Ruben I haven't read your other post, but I'm getting a PSU ready you should check my post "The Official..." I got a Power one from mouser 40 bucks. Lots of people say good things about them. They're good quality, professional and come in different amps. I got a 1amp +-12V I'm told it should run up to about ten modules. I edited my post to show how it gets hooked up. They also pop up on ebay I got a better one for 9.99 recently. So you can get them fairly inexpensively if thats an issue. _________________ "your stripes are killer bro" |
Joined: Apr 03, 2004 Posts: 24613 Location: The Netherlands, Enschede
Audio files: 316
Posted: Thu Apr 26, 2007 9:57 am Post subject:
Re: stop me if i'm wrong!! Subject description: psu ideia |
| rubendelacosta wrote: | | can it be done? |
Yes, provided that the power supplies do not have a (mains side) safety ground connection that is connected to the (low voltage side) - or + ouput.
So you're safe when the supplies have no safete ground connection. When there is a safety ground you should measure if the safety ground is connected to either the + or - output of the supply, when this is not the case, it's OK as well.
When such a connection is present it would result in a short circuit, but not on the mains side but on the output side. This might damage the power supplies but this is not very likely. Stop the experiment when things start to smell funny or run hot.
No further circuitery is needed.
There is one possibly problematic aspect on this solution. Not all circuits do like it very much when only one of the supplies is present and the other is not - a situation that could exist when one power supply is plugged in while the other is not. This situation might result in massive audio clicks as well, which could be unpleasant for ears and or speakers. So you might want to make a solution which prevents this situation (with a switched dual outlet thingy or something, you wouldn't have to mess with 230 V that way). Damage to the circuit connected to the power supplies is not very likely though.
Following Wild Zebra's advice might be more elegant  _________________ Jan
Joined: Jan 31, 2003 Posts: 18284 Location: Durham, NC
Audio files: 235
Posted: Thu Apr 26, 2007 10:27 am Post subject:
I wouldn't recommend hooking up two positive supplies to get a bipolar supply. Without getting into a lot of details, you'll probably get noise problems and worse. Get a real bipolar supply. _________________ --Howard
my music and other stuff |
Audio files: 316
Posted: Thu Apr 26, 2007 11:54 am Post subject:
| mosc wrote: | | Without getting into a lot of details, you'll probably get noise problems and worse. |
If regulated ... hmm ... yes, didn't even think about that possibility  _________________ Jan
Posted: Fri Apr 27, 2007 3:56 am Post subject:
I new there must be other reasons why you shouldn't do it.  _________________ What makes a space ours, is what we put there, and what we do there. |
