choklitlove
Audio files: 17
Posted: Wed Apr 25, 2007 2:16 pm Post subject:
percussion sequencer? |
i've been thinking about this, as i'm trying to wrap my head around the entire sequencer thing.
a sequencer takes programmed voltages and loops them, triggering whatever is controlled by those voltages, i.e. notes on a synth. is that close? if not, what exactly does that?
if we had a separate circuit for say, three different types of drum sounds, and each was triggered by a piezo element. a "hit" on a piezo element is a voltage itself, correct? could we set up a sequencer to 8 steps (1 measure, eighth notes), and programmed 8 drum hits into it? so it would loop a 1 measure, 8 eighth note pattern.
i also thought an "empty" step would be handy. like the equivalent of an eighth rest. what about that?
it was just me thinking randomly, and as usual not understanding things. so enlighten me! |
Posted: Wed Apr 25, 2007 3:36 pm Post subject:
Yep, that's exactly right.
A drum machine is basically just a sequencer where the gates can be sent to trigger multiple voices. If your voices are relatively fixed, you only need the gates. This could be built with just a 4017 (or similar). If however you include a method for dialing up a CV for each step (most analogue sequencers) you can use this to vary volume, tone, waveshape, etc. for each step. This can have great results even if you've only got one voice. _________________ What makes a space ours, is what we put there, and what we do there. |
Scott Stites
Audio files: 96
Posted: Wed Apr 25, 2007 3:44 pm Post subject:
Step sequencers work more or less like those marquee lights that you see on movie theaters - the one's where the lights chase around and around.
If you imagine that only one light is going around and around, that's pretty much how a step sequencer works. Each time a light bulb goes on, the voltage assigned to that light bulb is present on the voltage output of sequencer. Also, when that light bulb goes on, a gate is triggered on the gate output. Then that light goes off and the next light comes on. Then, the voltage programmed for that light is present on the voltage output of the sequencer and a gate signal is generated on the gate output of the sequencer.
Like you say, this process loops around and around. The voltage on the voltage output changes with each change of lightbulbs, and each time a new lightbulb goes on, a gate signal is produced from the gate output.
If you have eight lightbulbs, then for each iteration of the loop, you get eight gates. Of course, the gates can easily be triggers instead, but you get the point. But, yes, if you connected this gate output to a drum voice, you would get eight eighth notes per measure.
The ability to create rests depends on the sequencer. Most sequencers will give you this ability one way or another.
Some sequencers have a separate jack per light bulb. When the lightbulb associated with the jack goes on, a gate signal is sent out that jack. If you combine different jacks to a single output, you will be able to get rests. For example, say you combine jack 2, jack 4, jack 6 and jack 8 into a common output - now you will have four quarter notes for your eight beat measure.
Of course, you could combine any number of these outputs to get irregular beats, etc.
Now, many sequencers also provide what's known as a bus for distributing these signals. Usually there are two or three busses. Each bus has a common output.
For each lightbulb, there is a switch that will determine if that lightbulb's gate signal is going to be sent out of bus 1's output or bus 2's output, or bus 3's output. So, once you have your switches all set up, some gate signals will go out one bus output, while other gate signals will go out the other bus outputs.
In this way, you can set up a drum voice for each bus output and have all three drum machines playing a different 'beat' in that measure.
Edit: Aahhhh pooo - had a spiffy asterisk based illustration that didn't format right.
Hope this helps,
Scott |
Joined: Apr 03, 2004 Posts: 24484 Location: The Netherlands, Enschede
Posted: Wed Apr 25, 2007 4:05 pm Post subject:
Scott Stites wrote: | Edit: Aahhhh pooo - had a spiffy asterisk based illustration that didn't format right.
Edit it in your fav. code/ascii editor and then paste it as a code section into the post. that'll make it behave. _________________ Jan
choklitlove
Audio files: 17
Posted: Wed Apr 25, 2007 4:45 pm Post subject:
okay, sequencers have "pulse outs" for each step, right? how are those programmed? or is it just whatever is connected to each one takes that step? is that where those matrices with all of the jumpers come into play? like, each step has its own jack, then you jumper that to whatever you want triggered for that step. that makes sense to me... am i thinking in the right path?
if what i just said is true, how would i make buttons for each triggerable sound, and just press them in order to program the sequencer?
what i'm thinking is similar to mike's "silver sequencer" thing i was talking about a couple weeks ago, just in case it doesn't make sense. |
Clack
Joined: Aug 08, 2005 Posts: 438 Location: Walthamstow - london
Posted: Thu Apr 26, 2007 8:21 am Post subject:
i think It all depends on the type of sequencer,
yeah so an analog gate sequencer would need a trigger out for each sound you want to trigger , you would need a seperate sequence for each sound.
your basic sequencer has a counter that counts 1 - 2 - 3 - 4 .. looping, then on each of those steps you have a different channels for each sound with a corresponding switch on / off - in a matrix. so if it got to step 4 and the switch is on on channel 1 a snare will sound
+'s are the switches
Code: |
1 2 3 4 5 6 7 8
ch1 + + + + + + + + -----> pulse to snare
ch2 + + + + + + + + -----> pulse to kick |
a MIDI sequencer on the other hand can handle many channels on one output as the triggeres are sent as data that tell the machine on the other end which sound to trigger. its a very different process less physical |
Scott Stites
Audio files: 96
Posted: Thu Apr 26, 2007 10:52 am Post subject:
Quote: | you would need a seperate sequence for each sound. |
Yes, or you could use one common sequence and trigger different voices with the various trigger/gate outputs. The result of that would be one sequence with different notes 'sung' by different voices.
For example, half the gate outputs could trigger voice 1 and the other half could trigger voice 2. If you panned voice 1 right and voice 2 left, then the sequence would ping-pong from side to side in whatever pattern you patched the trigger outputs.
Scott |
MIKEFORD
Posted: Fri Apr 27, 2007 10:00 am Post subject:
Subject description: drum sequencer |
Here is something I want to incorporate with about 4 of marc brailles ds7 clones(gotta order some PCBs from him in France this summer!)
here is the link
http://www.sailormouth.org/index2.php?pg=seq.inc
Good Luck |
RF
Audio files: 28
Photon
Posted: Sat Apr 28, 2007 10:44 am Post subject:
the MM5871 Rhythm Generator IC is still available if you hunt around. There a 4 or so on ebay right now for $8 ea. Delton Horn's book, "Music Synthesizers : a Manual of Construction" has some info and circuits for using this chip.
peter |
Mikmo
Joined: Dec 01, 2005 Posts: 150 Location: Copenhagen - Denmark
Posted: Sat Apr 28, 2007 3:45 pm Post subject:
If you don't mind a PC beeing part of the system you should take a look at the simple parallel port interface and trigger sequencer program i made for triggering circuit bend toys. It could be used to trigger anything that a switch could trigger. Limited of course to what the 4066 IC allows.
http://www.mikmo.dk/cbsequencer.html
http://www.mikmo.dk/cbinterfacedetails.html
Only problem is that the sequencer program does currently not synch to any thing else. _________________ Stay Cool
Mikael
http://www.mikmo.dk |
