Wiring up Futurlec pots ?
Page 1 of 1 [7 Posts]
toybox
PostPosted: Sun Apr 29, 2007 10:30 am    Post subject: Wiring up Futurlec pots ? Reply with quote  Mark this post and the followings unread
Seem to look like a pain in the ass to wire up. But cheap and popular around
here anyone have some tricks?
mY MusIc
http://www.myspace.com/toyboxbastard
PostPosted: Sun Apr 29, 2007 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Toybox Very Happy Which type pots are you referring to? The panel mounts? If you have an idea or application in mind, perhaps we can help .... Wink
Bill
etaoin
PostPosted: Sun Apr 29, 2007 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
The Futurlec pots are PCB-mount. But that said, I've used dozens of them as panel mount without any problems. Just solder the wires onto the pins. Just as easy as real panel mount pots.
toybox
PostPosted: Sun Apr 29, 2007 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I was just worried about wire snapping of the pot. but you have had no problems
mY MusIc
Clack
PostPosted: Sun Apr 29, 2007 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah as long as you wind it round enough times its fine
choklitlove
Audio files: 17
PostPosted: Sun Apr 29, 2007 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
i bend the lugs down straight, then solder the wire straight onto them. i reinforce with shrink tube afterwards.
crashlander42
PostPosted: Sun Apr 29, 2007 9:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I always use those Futurlec pots. It helps to go and "tin' the legs and connecting wires first with a little bit of solder, and then solder the two together. If I get a good rhythm going I can wire'em up faster than standard pots. I don't like wrapping the wires around the leads. It makes it too hard to de-solder if you make a mistake. It you solder it well enough you shouldn't have a problem with wires snapping off.
Oh yeah. and heat shrink tubing is fun too.
When they plug me in the lights go down in Hong Kong.
http://www.myspace.com/isaciongun
http://www.youtube.com/user/Crashlander42
My DIY stuff Flickr
