Ico Doornekamp's 'Pong' and 'Iclock' request
Page 1 of 1 [7 Posts]
micro
PostPosted: Sat Apr 28, 2007 8:36 am    Post subject: Ico Doornekamp's 'Pong' and 'Iclock' request Reply with quote  Mark this post and the followings unread
If someone is kind enough to post pong and CooCoo clock patch for NM classic, I can't find them anywhere. Sad
Thank's in advance.
Audio files: 297
PostPosted: Sat Apr 28, 2007 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
You can find the patches here.
micro
PostPosted: Tue May 01, 2007 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much Very Happy
cappy2112
PostPosted: Sun May 06, 2007 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
What I should have said was: How do you set the current time with those modules? How do you correlate Hours, min, seconds to the note values in those 4 modules on the left?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon May 07, 2007 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
It's done by the event sequencers, although you have to skip the first step, because the '0' doesn't exist on a clock, does it?
Wout
Audio files: 297
PostPosted: Mon May 07, 2007 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, well actually it's 12 that does not exist in a modulo 12 counting system. We are a bit sloppy with that for 0:15 we also write 12:15, but 72:15 would be just as valid. With minutes and seconds we are a bit more strict like 0:60 is never used but 1:00 instead.
But don't get me started on date and time, we made a mess out that really - as every programmer knows I guess.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon May 07, 2007 3:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I knew it was difficult Smile
Wout
