 Forum index » Clavia Nord Modular » G2 Patches - Completed » Classic
Yamaha TX81z Lately Bass
Page 1 of 1 [10 Posts]
grantransom
G2 patch files: 13
PostPosted: Sat May 12, 2007 10:04 am    Post subject: Yamaha TX81z Lately Bass Reply with quote  Mark this post and the followings unread
I'm in the process of re-patching some old NM patches to the G2, and tweaking them in the process...
This is a Latelybass patch using custom TX wave generators to get the non-sine waveforms (thanks to help from Rob Hordijk). The architecture is pretty faithful to the original.
I haven't got my TX with me so it may need tweaking to get the velocity sens just right, but then the original gets a bit splatty at hi velocities anyway.
EDIT: See version in next post!!!!!!!
Grant
grantransom
G2 patch files: 13
PostPosted: Tue May 15, 2007 6:17 pm    Post subject: New version - without click at front Reply with quote  Mark this post and the followings unread
OK, 'cause I'm patching on the demo (No keyboard), I didn't notice the "Punch" trick I used was only OK at max velocity...
I've set the punch to track velocity now, I hope it works now.
TX Latelybass2GR.pch2
 Filename:  TX Latelybass2GR.pch2
 Filesize:  2.76 KB
 Downloaded:  2156 Time(s)
Grant
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed May 16, 2007 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Works good. Sounds great.
I've never seen a divider done with a S&H and inverter like that. Cool.
PostPosted: Wed May 16, 2007 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes ! I mean, no, never saw it either.
I just discovered that by adding a tunable delay into the loop it turns into a programmable divider ... fun !
grantransom
G2 patch files: 13
PostPosted: Wed May 16, 2007 8:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, glad it works, thanks!
A Clock Divider could have done it, there *may* be a small cpu advantage to the "Old School" flip-flop (which I found is also now a module on the G2) - as it does a single "job", whereas the Clock/Div probably uses a form of step-counter to get the multiple divisions.(?) That or an array of flip-flops...
S&H is so darn useful for patching trickery.
Grant
mother misty
G2 patch files: 130
PostPosted: Tue May 29, 2007 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
All I get is an annoying click when i load this into my G2, did I miss something.... ?
grantransom
G2 patch files: 13
PostPosted: Tue May 29, 2007 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you download the second version above?
Grant
PostPosted: Tue May 29, 2007 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Tip : it is possible to remove attachments from posts Very Happy
grantransom
G2 patch files: 13
PostPosted: Tue May 29, 2007 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I knew this is possible, but it's an old habit of mine to leave all versions of any sound accessable.
In this instance though, the change is just to the velocity sensitivity - I'll kill the first one.
Grant
PostPosted: Tue May 29, 2007 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought you might have such a reason, just wanted to make sure Very Happy
