 Forum index » How-tos
akai s1000 floppy+mac
Page 1 of 1 [6 Posts]
aquanaut
PostPosted: Sat May 01, 2004 11:50 pm    Post subject: akai s1000 floppy+mac Reply with quote  Mark this post and the followings unread
hi
i would like to transfer samples from my mac to the s1000 with a floppy disk.
so far i've seen an utility for pc only. is there a app for mac?
Thanks in advance
Nicholas
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun May 02, 2004 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
go there
http://www.akaipro.com/int/download/archive_om.html
and download mesa2(mac)
it should work, it did for me when I had an AKAI S1100 connected via SCSI to my UMAX Mac-compatible computer!
good luck Very Happy
paul e.
PostPosted: Sun May 02, 2004 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
another one is Alchemy by PAssport designs..
an older OS 9 app, but works very well for akai transfers
Spiral Recordings
aquanaut
PostPosted: Sun May 02, 2004 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
the s1000 does'nt have a scsi port. i think it's impossible to create a floppy in the mac that would be read afterward by the s1000.
anyway...thanks...time to give back
http://www.cervix.net/files/BlueQuadLFO.sit
Blue Quad LFO 1.0 is four LFO's in parralel outputing MIDI controll change messages. Amplitude, frequency and bias controlls are available. LFO shapes can be created and saved by the user.
Requirements: Macintosh PPC running OS 8.6 to 9.2.2 with OMS installed.
http://koen.smartelectronix.com/
no comment...nice free plug
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun May 02, 2004 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
actually I was wrong, after the S1100 I owned an AKAI S2000 and that's the one I used with M.E.S.A. 2 Embarassed
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun May 02, 2004 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
MIDI Sample Dump Standard (SDS), developed in 1985, was one of the first major additions to the MlDl Specification. Prior of SDS, musicians who wished to transfer sound data from one sampler to another had no alternative but to resample their sounds into the other instrument. Fortunately, the format of sample data is relatively consistent from instrument to instrument, and since it is digital, the data can be transferred over MIDI.
you should investigate MIDI Sample Dump Standard (SDS)
http://web.inter.nl.net/hcc/davies/samk0789.html
as you can see from the picture the S1000 is one of the samplers that support this "ancient" standard.
Again, Good Luck, and let us know Very Happy
