Jacks on Foniks Modules
Page 1 of 1 [12 Posts]
slo
PostPosted: Mon May 07, 2007 7:15 pm    Post subject: Jacks on Foniks Modules Reply with quote  Mark this post and the followings unread
I have been checking the modules you built on your great website, what jacks do you use?
etaoin
PostPosted: Mon May 07, 2007 10:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aren't they sockets from Cliff?
PostPosted: Tue May 08, 2007 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
indeed, these are cliff sockets.
i made these layouts for my own needs so be aware of the spacing between the sockets: i use a 20mm spacing, not 20.32mm (0.8inch) - why? it's the hamburger royal story: it's because the metric system (my brain is trained on that).
fluxmonkey
PostPosted: Tue May 08, 2007 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
anybody know of a source for these in the US?
PostPosted: Tue May 08, 2007 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.cliffusa.com/
vc-zazou
PostPosted: Fri May 11, 2007 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi there Smile
So i am planning to buy 100 of these cliff sockets.(for my two sequencers...)
Tell me fonik, where did you source them? in europe?
Farnell don't seems to sell them....
at the very least : hole spacing is about 8 mm am i right?
cheers
PostPosted: Fri May 11, 2007 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
i once got a larger number of these from a fellow from the s-diy list. but you can allways order a larger quantity from cliff uk. don't know what the minimum would be.
you are right.
vc-zazou
PostPosted: Sat May 12, 2007 5:02 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Smile
at the very very least : how much is the thickness of your (wonderful) panels?? 2 mm ? 3mm ?
cheers
PostPosted: Sat May 12, 2007 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
vc-zazou wrote:
thanks Smile
cheers
i found that 1.5mm is fairly enough for 3U panels. before you bend them you'd broke the sockets or potentiometers, i guess.
bearblock
PostPosted: Mon May 14, 2007 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
i use cliff jacks in my DIY modules too. I get mine from 'rapid electronics':
link
if you need loads though it might be cheaper to go direct.
Dave Kendall
PostPosted: Sat May 26, 2007 3:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Guys.
Thought it's about time I de-lurked......
Cliff UK will sell direct, and do the CL13841 sockets as a minimum order of 1000. Works out at £273-ish excluding VAT and delivery. This is the model that will take just about any 3.5mm plug.
The CL1384 is the regular model, is a bit cheaper, and has a minimum order of 200.
Cliff are out of stock of the CL13841 because apparently a German Modular synth manufacturer just bought up all the stock.
Now I wonder who that might be.........
Good to be here Smile
PostPosted: Sat May 26, 2007 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi dave,
good to have you here!
welcome
