ouroboros
Joined: Dec 04, 2006 Posts: 2 Location: below sealevel
Posted: Sun Apr 22, 2007 4:54 am Post subject:
[usb] why no connection? Subject description: Macbook ( Intel ) -> G2 = doesn´t work |
hi all, i'm quite new to this forum! so far i found loads of use/helpfull stuff keep up the good work! thanks!
this topic is not about the midi connection which is working fine. this topic is about the usb connection related to the editor. my g2 and my powerbookg4 always worked together.
a while ago i bought a macbook. now somehow the editor of BOTH macs doesnt find my g2 ... i checked all versions macos, g2os and editor should be working fine ... i tried multiple usb cables they all seem to be fine in other connections.
does anybody have some tips? that might help pin down the problem? or to get the mothership connection up again?
if i get it up and running i'll check back this topic
thanks & regards! |
Posted: Sun Apr 22, 2007 5:02 am Post subject:
I added "Macbook ( Intel ) -> G2 = doesn´t work" in the subject description.  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Tue Apr 24, 2007 10:37 am Post subject:
Just to be sure - do you use a USB hub? The G2 doesn't generally like to be connected to a hub.
ouroboros
Posted: Mon May 28, 2007 4:27 am Post subject:
no hub man, just straight usb connection...
I've been reading about some problem regarding usb & grounding issues
http://www.nordusa.com/forum/topic-32.html
i guess i will have to take it back to the shop ...
does anybody happen to have the same problem? did you have it repaired? how much did the repair cost? /derk |
G2egory
Joined: Nov 19, 2004 Posts: 69 Location: Charlottesville VA
Posted: Mon May 28, 2007 8:05 am Post subject:
I once had the same USB connection problem. In my case, I think the problem arose from forming a USB connection by plugging a live laptop into a live Clavia G2X. Both the G2X and laptop were plugged into a power surge strip, which did not protect me from the problem. I will never make a "hot plug" connection again. I always turn my laptop off now before plugging it into the delicate G2X, and then turn the laptop on.
Clavia, being a company of honor, stood by its product and paid for the complete repair. The repair required a new motherboard, which would have cost me $500+ labor. Apparently, the early models (G2; G2X) had this potential USB problem and Clavia has fixed it in later models. Now, the not-so-good news: it took 4 months to get my G2X repaired. They had to cannabilize a motherboard from another G2X. I worry that this means that there are few new motherboard production runs and that the G2X is being phased out, which would be a shame because it is an incredibly powerful, creative instrument. |
goathers
Posted: Wed Jun 06, 2007 6:24 pm Post subject:
I have a new MacBook Pro and I have the same problem.
The Modular G2's editor works, but its imposible to connect to synth.
I tried several usb cables, works well on Windows and OS X on PowerPC, and not work on OS X over Intel.
I contact Clavia on Technical Support in www.clavia.se and I`m waiting their answer.
I think we will to wait to universal binary editor's version. |
Suilebhain
Posted: Mon Jul 16, 2007 9:53 pm Post subject:
| I have a PC, no USB hub, just straight in, and I am having connection issues as well. |
goathers
Posted: Sun Dec 09, 2007 8:28 am Post subject:
My problems with usb connection was out with my macbook pro.
I update to leopard and the G2 connect with editor perfectly.
Not only direct to computer, It works fine through usb hub.
Anyway I'm waiting the update to universal binary editor's version. |
Joined: Apr 03, 2004 Posts: 24488 Location: The Netherlands, Enschede
Posted: Sun Dec 09, 2007 8:58 am Post subject:
Re: [usb] why no connection? Subject description: Macbook ( Intel ) -> G2 = doesn´t work |
| goathers wrote: | | I update to leopard and the G2 connect with editor perfectly. |
Glad to see you got something working now! _________________ Jan
