NPN/PNP Transistor array
Page 1 of 1 [12 Posts]
funkyfarm
PostPosted: Mon May 21, 2007 4:20 pm    Post subject: NPN/PNP Transistor array
Subject description: and matched transistors...
SSM2210 is an Audio Dual Matched NPN Transistor
SSM2220 is an Audio Dual Matched PNP Transistor
CA3046 is a cheaper NPN Transistor Array, General Purpose.
i can't find any PNP equivalent...
in fact, I was wondering if there's any modern equivalent to CA3096, which is three NPN and two indepandant PNP transistors in one package.
http://www.banzai-effects.de/CA-types-c-541.html
At least, i guess i don't understand the difference between "matched transistors" and "transistor array"...
mediatechnology
PostPosted: Mon May 21, 2007 8:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
The THAT340 has both a pair of NPNs and a pair of PNPs.
See: http://www.thatcorp.com/300desc.html
I stock the 300 and 320 and just got some 340 samples in today.
ickystay
PostPosted: Mon May 21, 2007 10:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
The MPQ3906 is a quad PNP. I have no idea how closely matched the individual units may be.
yusynth
PostPosted: Tue May 22, 2007 4:35 am    Post subject: Re: NPN/PNP Transistor array
funkyfarm wrote:
in fact, I was wondering if there's any modern equivalent to CA3096[/url], which is three NPN and two indepandant PNP transistors in one package.
There is one, its the HFA3096 but you'll find it only in SMD package, and living in France you'll have difficulties finding them. Two years ago I tried to buy some from the european distributors but eventually forgot about it because for some obscure reasons (US administration) I had to certify that I did not intend to build some rockets or booby trap with it... I found that humiliating and stopped the process.
Matched transistors means that the transistors on the chip have the very same characteristics (VBE matched to 1mV tolerance for a fixed collector
current).
Transistor array, is a chip with many transistors of the same brand but which characteristics may vary with minimum a tolerance of 10mV
Yves
PostPosted: Tue May 22, 2007 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are we subject to the minimum order requirements Question
Thanks for the post,
Bill
[/quote]
mediatechnology
PostPosted: Thu May 24, 2007 4:41 am    Post subject: Reply with quote  Mark this post and the followings unread
No minimum order requirements on THAT Products from me.
From THAT direct the MOQ is a single tube which on that part is 25 pcs.
Scott Stites
Audio files: 96
PostPosted: Thu May 24, 2007 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Mediatechnology has some very cool stuff there.....
Freq Band
PostPosted: Fri May 25, 2007 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just recieved some 300,320 THAT's from Mr mediatechnology.
Looking for a good project for them.
Also there's the tiny sized:
...but in seperate packages..
http://www.diodes.com/datasheets/ds30311.pdf
http://www.diodes.com/datasheets/ds30312.pdf
and there's the CA3096A
http://www.intersil.com/data/fn/fn595.pdf
=FB=
PostPosted: Sun May 27, 2007 10:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, OK. Thanks .........
Bill
funkyfarm
PostPosted: Mon May 28, 2007 5:15 pm    Post subject: Re: NPN/PNP Transistor array
current).
"a tolerance of 10mV" which is less good than matched transistor.
There's another topic which states than moog once changed their matched transistor pairs for cheaper to get CA3096 on a prodcut line...
OK, so DIY diy BC550/560 matched transistor are better than those in the CA4000 series.
Thank ! (but it's a lot of work)
yusynth
PostPosted: Mon May 28, 2007 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
No the CA3046 is quite alright because the differential pair (Q1 and Q2) are matched wihin 1mV. The 3 other trannies of the package are not matched.
Therfore the diff-pair is usable for expo converters as Moog did.
The THAT transistor array series are all matched within 1mV so they very useable.
Other transistor arrays such as those containing 2N39.. in a same package are not matched.
If you want to have measurements check René Schmitz page :
http://www.uni-bonn.de/~uzs159/rbe.html
Yves
funkyfarm
PostPosted: Tue May 29, 2007 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
yusson wrote:
No the CA3046 is quite allright because the differential pair (Q1 and Q2) are matched wihin 1mV.
If you want to have measuremants check René Schmidz page :
that's interesting !
This is the scoop I was after, while it guess it maight be wrote somewhere in some ways in the datasheet Wink
there's nothing like a good discussion, isn't it ?
Thank you very much.
How to match transistors? topic
