Wanted: Nord 8 Voice Expansion board
Page 1 of 2 [29 Posts]
blackbird
PostPosted: Thu Jun 14, 2007 11:20 am    Post subject: Wanted: Nord 8 Voice Expansion board
Subject description: help?
Hello,
I'm new to the forum.
wanted: a Clavia Nord 8 voice expansion board w/ PCMCIA slot
compatible with the Nord Lead 1 (I have the rack version, but I think it will work with the either rack or keyed synth).
Please PM if you have one available or any info as to where I might purchase one.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Jun 14, 2007 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
The expansion board to NL1 is rather hard to get...
If the only reason is a better way to save the sounds, one can use a piece of software, Windows only, which makes it possible to save to the hard disk. It's freeware and has a nasty bug (read the text about creating banks!), but it works for me for NL1 and NL2.
It's downloadable at
http://nm-archives.electro-music.com/020_NordLead2/023_Miscellaneous/NordGenerator_Editor/
Here is a patch to try it out.
Wout
Nord1-01.syx
 Filename:  Nord1-01.syx
 Filesize:  139 Bytes
 Downloaded:  587 Time(s)
blackbird
PostPosted: Thu Jun 14, 2007 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you.
However, I mostly wanted the expansion card to increase polyphony.
PostPosted: Thu Jun 14, 2007 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
It seemed appropriate to move this to the Nord Lead forum.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Jun 15, 2007 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe in this forum there will be more readers who can possible help you.
At the other hand, the 4 voice limitation is also daring!
Allthough, using Unison leads to only 2 voices and that's really almost nothing Sad
I would suggest to write and to phone every dealer you know. On the second hand market I can't imagine somebody would like to strip down his/her NL1...
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Jun 18, 2007 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
See
http://electro-music.com/forum/topic-18874.html
dougt
PostPosted: Tue Jun 26, 2007 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have an expansion board for sale. I sent a PM.
blackbird
PostPosted: Tue Jun 26, 2007 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks ! i pm-d back.
pfft
breathestop
PostPosted: Thu Jun 28, 2007 5:46 am    Post subject: Re: Wanted: Nord 8 Voice Expansion board
blackbird wrote:
Hello,
i pm'd you as well
rodhart
PostPosted: Wed Jan 23, 2008 2:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
I'm also new to the forum...just managed to get the expansion board for the Nord Lead One but don't have any instructions about fitting it.
Anything to be wary of?
Any links to download any info? Tried searching the web but no luck!
Thanks for any help!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jan 23, 2008 3:04 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome rodhart
It's not that difficult.
Only the flat cable has to go underneat the board, so be sure it isn't folded in any way!!!
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jan 23, 2008 3:15 am    Post subject: Re: Wanted: Nord 8 Voice Expansion board
breathestop wrote:
blackbird wrote:
Hello,
wanted: a Clavia Nord 8 voice expansion board w/ PCMCIA slot compatible with the Nord Lead 1 (I have the rack version, but I think it will work with the either rack or keyed synth).
i pm'd you as well
welcome breathestop
If you have a Expansion to sell, I also received on other forums requests about this...
Funny, the NordLead suddenly comes alive on this forum... Very Happy
Wout
rodhart
PostPosted: Wed Jan 23, 2008 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the quick reply, I'll be happy fitting the board now!
I agree...there's a lot of interest in the Nord Lead One at the moment.
For me it's a simple synth for live use...possibly easier than the Lead 2, 2x and 3 to navigate in terms of patches as I only need a handful of sounds. Works really well with the Electro too and the creative potential of both keyboards together is huge...very compact setup for gigging too...changed my life! I can actually take a train into London rather than driving Very Happy
benberry
PostPosted: Fri Feb 08, 2008 3:09 am    Post subject: help Reply with quote  Mark this post and the followings unread
Hi there, I want to expand my lovely Nord Lead 1 to 12 voices.
I know the people at memorix elektronik in Germany sell a PCMCIA SRAM expansion card but I'm not sure if this will increase the polyphony or just add more storage - can you advise?
Many thanks
Ben
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Feb 08, 2008 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome benberry
To use the memory cards you´ll have to install the card reader into the NordLead1, which also holds the DSP´s which updates the synth from 4 to 12 Voices. You´ll have to find this board first, only second hand availability Sad The PCMIA card only gives a larger memory, but has to be used with the reader.
Wout
benberry
PostPosted: Fri Feb 08, 2008 5:02 am    Post subject: thanks... Reply with quote  Mark this post and the followings unread
Many thanks for that Wout.
I have the opportunity to but a Nord Lead 1 for £300 but not sure I could live with only having 4 note polyphony.
I could probably get a Jp8000 or AN1x for a similar price ( 8 and 10 note polyphony I think) unless someone can convince me to go for the Nord Lead 1.
It will basicly be the only synth in my studio, the rest will be soft synths like the MiniMoog, FM8 etc.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Feb 08, 2008 6:19 am    Post subject: Re: thanks... Reply with quote  Mark this post and the followings unread
benberry wrote:
... I have the opportunity to but a Nord Lead 1 for £300 but not sure I could live with only having 4 note polyphony.
It can be used, special for bass, drums and lead sounds. Indeed, broad strings are difficult.
Wout
benberry
PostPosted: Wed Feb 13, 2008 3:37 am    Post subject: A proud new owner of a Nord Lead 1! Reply with quote  Mark this post and the followings unread
well i decided to buy the Nord Lead 1 despite the limited polyphony. No complaints so far as it sounds great!.
Does anyone know where I can find the 8 voice expansion board?
herbert_lemon
PostPosted: Fri Nov 04, 2011 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi All.
I am new to this forum and I seem to be reviving a topic from 2008!
I have just bought a Nord Lead 1 rack and i am in the same position as some other people on here.
I am in need of a PCMCIA expansion board to increase polyphony. Can anyone on here help me with a link or does anyone happen to have one for sale?
I hope somone can help. Many Thanks in advance.
tmste
PostPosted: Fri Nov 04, 2011 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
We called Clavia from the oficial suport in Italy and they told us is available at 200 and more €
If ithee's somebody in need of the EPROM version OS 2.3 I got a new one for sale.
it completely change the sinth adding alot of functions
Who is interested can send me a PM
herbert_lemon
PostPosted: Fri Nov 04, 2011 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi. Thanks for your reply.
Wow. that's expensive Sad.
Surely that's just Clavia trying to make some money though...
I read through this thread and i saw back in 2008 there were a few people with them to sell. So just hoping there may still be a few people out there who could help.
coolpixel
PostPosted: Sun Feb 05, 2012 6:26 pm    Post subject: Nord Lead 1 Expansion
Subject description: 8-voice Expansion board for Nord 1 synth
Hi all,
I know this thread is perhaps not the most recent but if anyone should be selling (or know of anyone selling) the 8 voice expansion for the NL1 I'd be grateful for a PM... Very Happy I know this is unlikely as they're rare and usually fitted already but it can't hurt to try. Many thanks people and all the best in your musical endeavours Very Happy
jonbongjovi
PostPosted: Sat Jan 05, 2013 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
well its a resurrect for this thread because as much as i love the 4 voices for my nord rack 1 id also like to get the expansion ..
Anyone got one for sale?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jan 05, 2013 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome jonbongjovi
Best is to contact Clavia about this.
You never know Smile
http://www.nordkeyboards.com/main.asp?tm=About_Us&clabm=Feedback
Wout
jonbongjovi
PostPosted: Sat Mar 09, 2013 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Clavia referred me to their dealer here in Australia ... who have treated me with a stoney silence...
Where else can I hunt one of these down?
