Yet another SN76477 question...
Page 1 of 1 [6 Posts]
Pehr
PostPosted: Sun May 20, 2007 1:20 am    Post subject: Yet another SN76477 question...
Subject description: VCO pitch control of the SN-voice...
In the TH&SS SN-voice the processed CV inputs is connected to pin 18 of the SN-chip, but I read in the SN76477 datasheet that it is pin 16 that controls VCO pitch Confused Question and that pin 18 is for "VCO control resistor"...
Is the SN-voice schematic correct? or should I do like the datasheet?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Thomas Henry
PostPosted: Sun May 20, 2007 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
The SN-Voice schematic is correct.
Actually, pin 18 is a control current input, while pin 16 is a control voltage input.
Thomas Henry
Pehr
PostPosted: Sun May 20, 2007 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks! Very Happy
YouTube channel
flickr photostream
Pehr
PostPosted: Fri Jun 22, 2007 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Is it possible to run the SN-voice on +/-12V instead of 15? are there any modifications I have to do for that? Confused
YouTube channel
flickr photostream
PostPosted: Fri Jun 22, 2007 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
It seems like you could operate from those voltages and not have any trouble. With 12V/-12V things would clip earlier as the operational amplifiers output can only go about 1.5 volts from the rail, but you will not even approach that point so it's a not an issue.
Bill
Pehr
PostPosted: Sun Jun 24, 2007 1:42 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks! Very Happy
YouTube channel
flickr photostream
