sebber
G2 patch files: 33
Joined: Jan 31, 2003 Posts: 18310 Location: Durham, NC
Audio files: 235
sebber
G2 patch files: 33
Posted: Wed Jun 27, 2007 12:53 pm Post subject:
Mosc, I was joking. Yeah, but you never know what people do.
I'm pretty sure there's an easy solution, but this is not it. If it doesn't appear immediately change the tempos a bit and it's still there. I tried to insert a pulse module, but that didn't work either. _________________ Fish don't swim. They dive. |
Joined: Apr 03, 2004 Posts: 24669 Location: The Netherlands, Enschede
Posted: Wed Jun 27, 2007 1:13 pm Post subject:
Maybe like this ?
edit: patch 2asyncseq.pch2 got lost in the great crash. _________________ Jan
sebber
G2 patch files: 33
Posted: Wed Jun 27, 2007 1:40 pm Post subject:
I'm afraid I don't get the point then ... I loaded your modification and I get toggling sequencers  _________________ Jan
sebber
G2 patch files: 33
Posted: Wed Jun 27, 2007 1:49 pm Post subject:
Yes, the sequencers toggle, you're right. But in my patch the first event sometimes double triggers and in your patch (the one that I modified shows it more clearly) I can hear the 5th event although it should only be 4 and it seems to be irregular, because the 5th event (the very low notes in this otherwise musically convincing tune) can be heard sometimes longer, sometimes shorter. _________________ Fish don't swim. They dive. |
Posted: Wed Jun 27, 2007 2:00 pm Post subject:
Ah ok, that's the problem, seemed logical to me ... it can be solved by using resettable LFOs and resetting the LFO along with the reset of the sequencer it controls.
Edit the patch 2asyncseqsync.pch2 got lost in the great crash. _________________ Jan
sebber
G2 patch files: 33
Posted: Wed Jun 27, 2007 4:10 pm Post subject:
Amazing. The "insert pulse before and after" reminded me of what I read about the NM. The 2asyncseqsync doesn't work with the sawtooth unless the phase is changed, which is interesting. Now let's see if it works in my patch, because I don't want to only toggle between sequencers but chain the lot of them.
I wish I had one of those new apple laptops. Then I'd only need to hold a mirror in front of my face to make a decent screenshot.  _________________ Fish don't swim. They dive. |
sebber
G2 patch files: 33
Posted: Wed Jun 27, 2007 5:28 pm Post subject:
Ah, I'm sorry that's not it yet. It would be solved if in your patch the first sequencer could repeat 4 times and the second 4 times or 5 and then restart with seemlessly. It's not just toggling, I'm afraid. _________________ Fish don't swim. They dive. |
iPassenger
Joined: Jan 27, 2007 Posts: 1070 Location: Sheffield, UK
G2 patch files: 78
Posted: Thu Jun 28, 2007 10:16 am Post subject:
Hmm.. messed about a little, does this work how you want it to, I cheated a bit and used Clock Gens and not LFOs tho:
Edited: now with lfo driven seqs
Edited 2 (after Server crash) : couldn't find these and not sure what i did, as they didn't really sort the problem thought I would just remove the (dead) attachments. _________________ iP (Ross)
- http://soundcloud.com/ipassenger Last edited by iPassenger on Tue Aug 21, 2007 9:24 am; edited 1 time in total |
sebber
G2 patch files: 33
sebber
G2 patch files: 33
Posted: Thu Jun 28, 2007 3:12 pm Post subject:
I'm trying with the park-input, but as yet there's a lot of reciprocal parking happening  _________________ Fish don't swim. They dive. |
varice
Audio files: 29
G2 patch files: 54
Posted: Thu Jun 28, 2007 7:44 pm Post subject:
Instead of having two LFO clocks set at independent rates and trying to synch them at the repeat step, why not have one clock and change the rate of the single clock at the repeat step? _________________ varice |
cappy2112
Joined: Dec 24, 2004 Posts: 2505 Location: San Jose, California
Posted: Thu Jun 28, 2007 9:34 pm Post subject:
| sebber wrote: | Mosc, I was joking. Yeah, but you never know what people do.
Tech support loves me. I give the most detailed bug reports, and screen shots like they are going out of style. |
sebber
G2 patch files: 33
Posted: Fri Jun 29, 2007 4:11 am Post subject:
| varice wrote: | | Instead of having two LFO clocks set at independent rates and trying to synch them at the repeat step, why not have one clock and change the rate of the single clock at the repeat step? |
Your idea is great, but is has a major setback: I'd only see the rate of the first sequencer and have obscure midi or other data for the others. If the first one runs with 120 and the next with 179 I'd have +59 displayed. Which is a small thing with two sequencers but actually I want 16 in the first variation and 7*16 in the others.
I'm using the LFOs because in the "real patch" there's a master OSC before them so I can change the overall tempo of all the sequencers by e.g. factor .5 without having to change each sequencers rate.
If you look at the first picture it really boils down to: why doesn't the control signal from the Level Sequencer restart both step sequencers together and without delay?
Or to rephrase what I'm trying to achieve: three sequencers, each with different rates and controllable times/numbers of loops. E.g.:
Sequencer 1, 120bpm, 3 loops
Sequencer 2, 179bpm, 2 loops
Sequencer 3, 44bpm, 3 loops
and back to No1. _________________ Fish don't swim. They dive. |
sebber
G2 patch files: 33
