NL2 patches on my 2x
Page 1 of 1 [12 Posts]
Nordisk Musik
PostPosted: Sat Jun 30, 2007 8:20 am    Post subject: NL2 patches on my 2x Reply with quote  Mark this post and the followings unread
For some time I have experimented with decent trancesounds on my 2x, but I didn't get the result I wanted. Some introduced me to synthdesign.com where I downloaded 40 patches. The format is mid but I couldn't load them into my 2x. Has somebody else tried precisely this file? I even tried with the factory presets from clavia, to be sure that all MIDI setup was correct. I has no problems loading the factory pacthes, this just didn't work.
http://www.synthdesign.de/claviaNL2.htm
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jun 30, 2007 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
As far as I know the file is *.rar so is it Midi?
If you send me the files, I can try to open them.
I'll PM you about details
Wout
Nordisk Musik
PostPosted: Sat Jun 30, 2007 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
The file is a typical .MID file that contains 40 patches. I don't really have any idea what bank it is overwriting as the file is written for the standard NL2.
Normally when you play a .MID file to import patches, you can see the whole bank is being scrolled through. This doesn't happen with this file and no new sounds.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jun 30, 2007 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, the first question... Are you on PC or Mac?
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jun 30, 2007 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I tried it and they are alright.
If you're on PC, go to
http://nm-archives.electro-music.com/020_NordLead2/
and at
http://nm-archives.electro-music.com/020_NordLead2/023_Miscellaneous/NordGenerator_Editor/
you'll find the Editor NordGenerator, which loads Midi Files. Just drag&drop the file from the folder on the tool and it will ond all 40 files.
By using the curser arrows up you'll see the Patch number go from 40 to 1, which will be the first sound. Just hit the 'enter' key on your computer keyboard and the file will load, if the Midi is set right. You'll be able to hear all 40...
Which is quite a desception...
It sounds like, but the audio examples at the site are not the same, at least a lot of effects is used!
If you want I can send you the single files as *.syx to you.
More sounds are at
http://nm-archives.electro-music.com/020_NordLead2/021_Patches/
Wout
Nordisk Musik
PostPosted: Sat Jun 30, 2007 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool! thanks a lot for the help I appreciate it, I'll check this ASAP.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Jul 01, 2007 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Nordisk Musik, you downloaded and opened the file from that site. Maybe I'm missing something, but the *.rar file asks for StuffIt, which converts it into *.sit, which I can't open. How do you did it Smile ?
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Jul 01, 2007 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I've played a little bit with some files...
I send the SysEx of the program and a midi file, because I think mp3 is as terrible as possible to listen to...
Set the Unison at 9 [Shift + 3 times Sys, program cursor to 9] to get the effect.
Midi 180 bpm.
Wout
Stice-Xperiance11-Digeridoo.syx
 Filename:  Stice-Xperiance11-Digeridoo.syx
 Filesize:  139 Bytes
 Downloaded:  451 Time(s)
Chords11.mid
 Filename:  Chords11.mid
 Filesize:  2.28 KB
 Downloaded:  437 Time(s)
Nordisk Musik
PostPosted: Sun Jul 01, 2007 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
yes I simply just draw the .MID file from the .RAR folder without getting any messages. Thanks for helping once again I'll look into this, I never really understood the unison option on this synth. I don't think any specific unison value is saved when writting a patch.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Jul 01, 2007 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could you do this too for the NordLead3 files on that site and send me the midi? I would be grateful!
Mostly I use the Unison set to 1, which means only a stereo sound with a slight delay, because that detuned sound isn't always nice Smile When I use Unison to be detuned I use 5, but mostly 9, which gives the effect the most.
Indeed, Unison is a global effect, to all the Slots and stays the same until changed. The NordLead3 has the ability to save the Unison in the Patch and therefor use different Unison in a Performance (Unison has it's own DSP, so the Voices per Slot stay the same)
Wout
cappy2112
PostPosted: Fri Jul 13, 2007 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout
.RAR files are compressed files like .ZIP. They use a Russian compression tool called WinRar, but I think recent versions of Winzi will uncompress .rar files. If not, you can get a short-trem version of Winrar from the winrar website.
As far as what's inside the .rar file, who knows.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Jul 13, 2007 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, it works!
Wout
