Has anyone used the MOTU 828mkII?
Page 2 of 2 [48 Posts]
Goto page: Previous 1, 2
DES
PostPosted: Mon Apr 26, 2004 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm. Sounds like bad problems. I would think that if they didn't clean these issues up, then they'd be out of business. I guess they were originally an Apple-only product and moved to support the PC to get at a larger market.
I think you basically hit the nail on the head with that Howard. If they had not had a strong business on the Apple side of things they would not have survived. They provided little to no support for the PC side of things..it was a shame really - the Midi Time Piece AV is perhaps one of the best units on the market feature wise - all they had to do was fix the drivers...many people offered to do it for them for free but it would have required them to release code from inside the unit which they could have done using non-disclosure agreements. I tried to get an update for the eprom in mine - I told them the number that was installed (in fact THEY had sent me the eprom optimized for Cakewalk when I first purchased it) and they said that the number I was giving them was impossible.... This leads me to think that they had to have an outside jobshop/silent partner making them and perhaps they split apart. Something like Event and Echo did... I know that they lost a lot of sales because of it...and with Apple aquiring emagic - that has to hurt too.
But that was several years ago. I have not seen too much negative information about them recently. I am interested in the 828MKII as well but have been very cautious. In my position if I order it I can't return it unless it's defective. So - I am VERY interested in Howards results!
As a point of reference, John Christian brought one with him from the UK when AirSculpture played over here recently. He has a very high opinion of this device.
Bill - was he using a Mac?
des
djfoxyfox
PostPosted: Tue Apr 27, 2004 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
No, it was a Windows laptop. That's why I felt that the data point was pertinent. MOTU's drivers for Windows seem much improved these days.
Audio files: 225
PostPosted: Tue Apr 27, 2004 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it is partially Microsoft improving their end of things too. What convinced me to buy this was actually the ASIO4ALL driver that DES turned us onto in this post http://electro-music.com/forum/topic-1963.html . That makes my obsolete Yamaha DSP Factory work soooo much better than the factory driver. ASIO4ALL takes advantage for the WDM architecture of recent versions of Windows. I figure if that old relic sound card can work that well, then the MOTU should scream. MOTO ships with a WDM/ASIO driver, of course.
Audio files: 225
PostPosted: Fri Apr 30, 2004 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I received my MOTU 828 MKII yesterday and hooked it up. It was my 58th birthday. It was kinda like a present. Also, being that old has taught me something, I read the manual before hooking it up. Shocked
The install on my XP machine went pretty much flawlessly. The windows driver installed without any problems. There is both a WDM and ASIO driver. Sonar can use either mode. ASIO has one big problem, an application can't share the port with another one. This appears to be an ASIO feature, not a problem with the 828. I experience the same thing with the ASIO4ALL driver. It is mentioned in the ASIO4ALL driver's documentation.
I tested out both ASIO and WDM modes in Sonar. Certainly ASIO has less latency. Once I figured out the Sonar audio config process, I am able to switch back and forth pretty effortlessly.
All of the Windows programs, XP itself, WinAmp, QuickTime, etc. seem to work perfectly.
The sound quality is excellent as far as I can tell.
I couldn't get the SPDIF port to talk to my Pioneer amplifier, but I haven't been able to get any piece of gear work with it either, so that's not very significant.
The unit is pretty feature-rich with the ability to have 4 internal mixing busses that you can assign to Main Outs, SPDIF, ADAT, Analog Outs, Phones, etc. These are kept in memory when the box is turned off. You can set up these mixes with a little app they provide called CUEMIX, or you can set these up with the front panel. I don't have much use for this so I didn't dig in too deeply. It might be very useful in some circumstances.
The instructions say you can set it up either to do mixing in the computer, or do mixing with a mixer. They say don't try to do both at the same time or you'll get confused. I tend to agree. I use mine as just a good I/O device for my computer. I use my Mackie mixer as I was doing before. I'm sure there are applications to do all mixing in the computer, but for me it's easier to use the Mackie. When Xeroid Entity plays here in my studio, I'll switch over to computer mixing and use SONAR as a multi track recorder. I can switch from one mode to the other without repatching.
One nice feature is that there are front panel LEDs to indicate the levels on all of the I/Os. There are only 4 LEDs per signal, so the resolution is very poor, but it is a good easy check to see if the inputs are receiving signals and if they are too hot or too weak. Very handy.
One thing I don't like about it is that I can't set the sample rate from within Sonar. The 828's sample rate is set either via the front panel or via a little application they give you. So, if it is set it at 96K and you want to record at 44.1 K on Sonar, it won't work. I guess this is no big deal, but it is at least an inconvenience.
The MOTU people include a copy of Audio Desk for use with the Mac (OS9 or OSX). Audio Desk is a pretty complete multi-track recording program, but without VST plugins or much MIDI capability. Still, it might be useful to have. The is also a copy of the CUEMIX application (virtually identical to the PC version). There is also an ASIO driver for the Mac, as well as the Core Audio driver, as you would expect.
There are two manuals, one for the interface and CUEMIX, and one for Audio Desk. The one for the interface has information for Windows and Mac. The pages for each are printed upside down in relation to the other. You open the book from one end, and it's for Windows. Turn the book over and open from the other end and it's the Mac version. Very cool. The Audio Desk book is the same, but for OS9 on one hand, and OSX on the other.
I will install Audio Desk on my Mac, but that's for another post.
All in all, this is a very nice device. I like that I can always buy a second one for more tracks if needed. I can use it in the studio and on the road, with the Mac or with the PC, and with a laptop or a desk top. Wouldn't it be nice if people were as agreeable?
7
PostPosted: Mon May 10, 2004 11:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, now that you've had time to play have you run into any issues?
Audio files: 225
PostPosted: Tue May 11, 2004 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
No issues with the MOTU. I don't care for the ASIO drivers though as they hog the I/O device. I'm content to use the WMA drivers. I like to keep Sonar open with a project in progress, check the browser and perhaps listen to an mp3 file someone posts. Probably, it's stupid to keep your web browser even loaded while working on an audio project. These are things that have nothing to do with the MOTU though. It seems to be very solid.
PostPosted: Tue May 11, 2004 6:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Sound on Sound magazine is still referring to the original Motu 828 as "one of best". They should know.. Very Happy
Flickr
7
PostPosted: Tue May 11, 2004 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, hot diggity dog.
Perhaps I'll zip over and pick one (or two) of these critters up next weekend.
DES
PostPosted: Tue May 11, 2004 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Howard - try using the ASIO4ALL driver - it might speed up the WMA drivers a bit...then again it may not work at all... Shocked
DES
7
PostPosted: Wed May 19, 2004 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got mine today. I'm still messing with it. I'll let you know what I think later.
7
PostPosted: Thu May 20, 2004 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, here's my take on the thing.
First the bummers in my system.
1) The new drivers from MOTU (3.30) didn't work on my recording computer. They would crash during the install. I decided to load the ones from the CD that came with the unit -version 3.01.. worked like a charm.
2) When I turn the 828mkii off, a driver crashes on my computer. I haven't worked this problem out yet. It isn't too much of a hassle because I can just kill the software manually. This might have something to do with installing the newer drivers first.
3) There are pictures in the manual showing the unit displaying incoming signals on both its displays. (the one in the middle is what I can't seem to get working) I've not figured out how to do this yet. It seems like a simple thing to switch on but I can't seem to find this info in the manual. Anyone know this trick?
Now the good.
THIS THING ROCKS!
One I got the driver issue worked out (which took me about 5 minutes) I opened Sonar and started recording. I patched my old Tascam 8 track reel to reel directly into the 828mkii and started dumping tracks. Not a single problem. In the matter of a few hours I had transfered 5 reels into the computer. On playback they sound just like the reel does.
I'm quite happy with it so far.
I would like to get the input monitoring thing figured out. the little 4 element display on the left side seems a bit weak to me. I'd like to take advantage of the slightly better middle display. But other then that, I'm pleased with the buy.
Audio files: 225
PostPosted: Thu May 20, 2004 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
7, what OS are you using. I'm on XP Professional.
Don't know what you mean by the middle display. There are only two displays, or are you talking about the middle of the right hand display? Or, do you mean the middle of the left hand display?
7
PostPosted: Thu May 20, 2004 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right in the middle is the main display. the one you look at when making changes to settings. This also doubles as an input monitor -at least from the pictures this is what it seems.
That is the one I'd like to have show incoming signals.
It can be done right?
the recording computer is a stripped down version of Windows 98se. I've not upgraded this OS because it works perfectly for all my other software -you know, the whole "if it ain't broke" thing.
the driver issue is really minimal. I'm sure I can sort it out.
Audio files: 225
PostPosted: Thu May 20, 2004 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see how that can be done, but I couldn't find anything in the manual about., The window shows the levels of the virtual faders for the inputs to the 4 internal mixers. The do look like they might be used for input level monitoring, but they aren't I don't think.
Audio files: 225
PostPosted: Thu May 20, 2004 10:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
The best way to monitor the levels is with the CUEMIX program. It's got very good meters and seems to place very little load on the PC.
DES
PostPosted: Fri May 21, 2004 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Quick question guys - can you use the 828MKII as an audio patch bay? In other words - can you route any input to any output? I realize that in most software this could be done but I am looking at keeping some signals out of the software to minimize latency issues.
The idea is to plug two signal sources into the 828 and then route them out any of 4 outputs that will go to selected processors. The outputs of the signal processors could possibly be connected to other inputs.
Do you think this could do it?
Audio files: 225
PostPosted: Fri May 21, 2004 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think so. There are 4 mixers - built in. They have two channel outputs, but can have any or all inputs. You can, of course, run them simultaniously. The output pairs are sorta fixed. For example analog 1 and 2, 3 and 4, phones, main, SPDIF, etc. You can't have a mixer route to analog 1 and 7, for example.
7
PostPosted: Fri May 21, 2004 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
DES: Yes. I haven't done it yet, but it can be done.
Here's the answer to my question about the display from MOTU
Hello Seven,
Those screenshots were of beta units of the 828mkII before the final
shipping model. That display was not included in the final shipping version of the 828mkII. The default screen is the Gain/Mix screen which tells you the input sensitivity as well as the mix output.
Thanks for writing,
Thomas
MOTU Tech
Audio files: 225
PostPosted: Fri May 21, 2004 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, they answered your email enquiry. I'm impressed.
7
PostPosted: Sat May 22, 2004 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, neat huh. But just one reply from their tech support wasn't enough I guess. heh heh
Seven,
The center LCD on the 828mk2 does not display VU levels. It instead
shows the current CueMix parameters. You can program a variety of
CueMix parameters from the front panel, but the "Gain -- Mix1" screen
you are referring to is showing the CueMix levels for Mix1. You can use
the Value knob to turn up an input's CueMix level. You can also use the
FireWire CueMix Console software application to control CueMix
functions. For more info on CueMix, check out the 828mk2 manual.
Thanks for writing,
Josh Hetrick
MOTU Tech
I think their first response answered my question better. Wink
7
PostPosted: Wed Jun 02, 2004 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built a new computer (doubled the power I had before) and installed Win2k. The MOTU 828mkii now works perfectly.
Now all I have to figure out is how to get Gigasampler to speak with Sonar 3 in Win2k. Grrr.
Audio files: 225
PostPosted: Wed Jun 02, 2004 8:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was doing some recording and was getting distortion. I was able to fix it by reducing the buffer size on the MOTU. I've got it set at 256 samples per buffer.
7
PostPosted: Thu Jun 03, 2004 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
mosc wrote:
I was doing some recording and was getting distortion. I was able to fix it by unplugging the fuzztone.
*snicker*
