how to recreate the drumsounds of the kr55 drummachine?
Page 1 of 1 [12 Posts]
abducted
PostPosted: Wed Jul 11, 2007 2:00 pm    Post subject: how to recreate the drumsounds of the kr55 drummachine? Reply with quote  Mark this post and the followings unread
hi,
i love the korg kr55 drum machine
and I'd like to resynthesize all these sounds...
especially the snare and open hh.
How to do that please?
3phase
G2 patch files: 141
PostPosted: Wed Jul 11, 2007 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
you would need to find information how the internal drumvoices are constructed an rebuild that in the nordmodular..
look at the 808 emulation ptches around..the kpr uses similar principles to do it sounds..
As closer you build the sound engines as closer the results gets..
the 808 cymbal is for example composed out of 6 sqare oscilators while the bassdrum is a resonant filter...
having such things in mind while making a patch that is supposed to sound the same is helpfull...
There is howeveer also another aproach by remodeling the sound from scratch..
look at the incredible funky drummer patch from Sheridan here in the lib...
He modeled the sound of the James Brown drummers sample with the G2..and he did a damn good job... For me the best demo of the G2s abilitys sofar...
with the wright patch you can get almost any drumsound out of the nord modular... To emulate a whole machine with all 16 instruments acurate might get tight with the dsp... but i am shure you can make 2 or 3 kpr sounds in one patch ...
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Wed Jul 11, 2007 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
This type of endevour is quite more rewarding and less time consuming than trying to model something too accurately from a well defined set, in general.
Speaking for myself. Hell, I just throw that preconceived ideas out the window, grab the gist of what I want to do, and go from scratch.
Just some thoughts.
/Dasz
3phase
G2 patch files: 141
PostPosted: Wed Jul 11, 2007 10:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
preconcieved ideas? can safe quite some resoures when you use the wright model...
but the dont might be the chance to do that.. this old korg is not exactly good dokumentated
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Jul 12, 2007 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
3phase,
like I said, I'm speaking for myself. I'm not suggesting others follow.
There is a lot of value in emulating other gear and learning from it, not to mention being able to extend the emulation in ways not possible with the original. I simply do not have the (hand) time to dedicate to such endevours.
/Dasz
G2DREAM
PostPosted: Thu Jul 12, 2007 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
dasz wrote:
There is a lot of value in emulating other gear and learning from it, not to mention being able to extend the emulation in ways not possible with the original./Dasz
I agree with you, i believe faithfully to emulating as i think it is one the most educative method for patching.
Actually i have nothing to reply to the item of this thread so sorry...
_____________
cyber-evolution
G2 patch files: 626
PostPosted: Thu Jul 12, 2007 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I couldn't find any circuit diagrams, which come in handy for emulating. I did find a sample set though and I agree with Sven, they are similar to 808 in construction.
I had a crack at the kick,rim,hihat and snare in the pch. The hihat metal noise is made from fm square waves as apposed to the multi square 808 method. This is just a guess based on comments I read somewhere about early Korg drum machines.
It is not very close but might be useful as a starting point for you.
kr55b.pch2
 Filename:  kr55b.pch2
 Filesize:  3.72 KB
 Downloaded:  1969 Time(s)
3phase
G2 patch files: 141
PostPosted: Fri Jul 13, 2007 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
uii.. a spring bouncer avatar ... Smile)
3phase
G2 patch files: 141
PostPosted: Fri Jul 13, 2007 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
where have you found the sample set?
G2 patch files: 626
PostPosted: Fri Jul 13, 2007 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Here
abducted
PostPosted: Fri Jul 13, 2007 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks ! This is a very good starting point indeed.
I have some samples of this drum machine as well
(I even had one real kr55 a long time ago). I could use
the samples to make a drum kit but I much prefer
to resynthesize the sounds. By the way I think
the kr55 is a much better sounding machine than the 808
(it sounds so electronic)
iPassenger
G2 patch files: 78
PostPosted: Fri Jul 13, 2007 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like the kick, hats sounds well too.
R.
Have no idea if it is like a Kr55 tho as i have never played with one but nice sound either way.
EDIT: I love the snare too, this is a great little beat machine.
iP (Ross)
