psylux
Posted: Wed Jul 25, 2007 9:00 am Post subject:
Beautiful Soundlab Psylux!
edit; err Wooster!  _________________ ACHTUNG!
psylux
Posted: Wed Jul 25, 2007 9:06 am Post subject:
| Right, just clarify, I merely reposted it! Props to Wooster! |
Alienation
Posted: Wed Jul 25, 2007 10:37 am Post subject:
That is an awesome little synth. I wonder if Wooster would share details on construction with other DIY's??
Thought's? |
LukeDI
Joined: Sep 23, 2006 Posts: 50 Location: Boston MA, USA
Posted: Wed Jul 25, 2007 3:59 pm Post subject:
| That may rate as the new best looking SLMS. Cute as a button (or knob in the case) |
wooster
Posted: Wed Jul 25, 2007 7:05 pm Post subject:
Thanks everybody for the positive feedback! I'll take a picture of the inside soon. Here are some construction details:
- The synthesizer portion is a standard soundlab with some of the suggested modifications (1 V/OCT, fine tuners, S&H, intra-VCO modulation). I built this about a year ago and put it in a simple plywood box, which is why the audio output is on the front panel.
- The panels are made of aluminum from www.onlinemetals.com, laminated with paper and drilled with a press or cut with a jigsaw.
- The case is mostly made out of walnut, the bottom is made of plywood.
- The keyboard and the PB wheel are from Doepfer spare parts section of Analog Haven.
- I designed the keyboard scanner using a PIC microcontroller. It can output pitch, velocity, and gate. There is also pitch bend and portamento.
- The echo portion is not actually functional yet - I am basing it on the PT-80 delay project you can search for on google.
- It was originally battery powered, but after the first set of batteries died I switched to using a small linear power supply.
The keyboard scanner works pretty well, I think I will make another one for the modular I am building, and might do a PCB. |
Alienation
Posted: Wed Jul 25, 2007 7:49 pm Post subject:
Thanks for the detail, the pcb idea sounds great.
Is that something you would consider doing and offering as in a (PCB) group buy or strictly for your personal use?
Don't mean to jump the gun on this, I realize you may have no intention of going the business route.
What about the fatar keyboard portion? Was that removed from a small stock keyboard, I'm assuming here.
Again, congrats on a very cool synth. |
crazeydazey
Posted: Thu Jul 26, 2007 4:40 am Post subject:
very very nice... |
Wild Zebra
Posted: Thu Jul 26, 2007 7:18 am Post subject:
Looks awesome, great job!
| Quote: | | The keyboard scanner works pretty well, I think I will make another one for the modular I am building, and might do a PCB |
I know you already designed one so you should take a look at this thread
http://electro-music.com/forum/topic-17815.html
Welcome to electro-music home of the klee sequencer  _________________ "your stripes are killer bro" |
wooster
Posted: Thu Jul 26, 2007 9:47 am Post subject:
Thanks Zebra. I was thinking people might like a low cost alternative to MIDI->CV converters for DIY projects. However the Thomas Henry keyboard seems great. If its total cost is low I probably won't bother doing a PCB. Here are some pictures of the inside of the case.
| Description: |
| Filesize: |
180.77 KB |
| Viewed: |
5632 Time(s) |
| Description: |
| Keyboard scanner close-up |
| Filesize: |
177.55 KB |
| Viewed: |
5606 Time(s) |
