today> Twyndyllyngs Chez Mosc
nord lead 2 reset?
Page 1 of 1 [5 Posts]
michi111
PostPosted: Thu Jul 26, 2007 6:05 am    Post subject: nord lead 2 reset? Reply with quote  Mark this post and the followings unread
hi does anyone know how i can reset my nord lead 2 fully. i want to try it because the sounds always change without doing something. filter goes up and down and it sounds very distorted and bubbling.
thanks for help
greetings from vienna
michi
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Jul 26, 2007 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome michi111,
I'm sorry, but there is no global reset known to the users of the NL2. Maybe Clavia at http://www.clavia.se on the support page can help you out.
Anyway, I think it won't help much. Is the shifting that much? Maybe the pots are a little bit worn out... Are you the first owner?
Wout
DimensionFour
PostPosted: Thu Jul 26, 2007 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Probably obvious but:
Did you try to press shift + panic?
are you sure your Lfo1/2 rate/ammount isn't set too high?
michi111
PostPosted: Thu Jul 26, 2007 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for replaying
yes i´m´the first owner.
panic doesnt changes anything and the lfo is not the cause
clavia told me
"Hello, if knobs and settings "jumps" by them selves it is more likely to be a hardware failure I would say, but please send me the audiofile and I´ll take a listen. You can make a simple reset by holding SHIFT and press the MOD ENV, M-PW-OSC2 button, I doubt that changes anything but you can try it. Send me the file and will take it from there, send me the patch as well and I´ll try that also"
whats m-pw-osc2 button
when i press shift and on lfo1 source the dispaly says cop and its blinking.
does anybody know what this means?
thanks
michi
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Jul 26, 2007 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
michi111 wrote:
"... You can make a simple reset by holding SHIFT and press the MOD ENV, M-PW-OSC2 button ..."
They mean FM-PW-Osc2 button on the Modulation Envelope.
Take also a look at
http://nm-archives.electro-music.com/020_NordLead2/023_Miscellaneous/NordLeadSecrets.htm
Wout
Press this one while holding Shift
 Filesize:  31.53 KB
 Viewed:  8588 Time(s)
