I got a synth and drum machine
Page 1 of 1 [15 Posts]
strms
PostPosted: Thu Aug 16, 2007 10:22 am    Post subject: I got a synth and drum machine
Subject description: now how do I record them
I finally got an Alesis Micron and a boss dr 202 drum machine....how am I supposed to record them.
I want to be able to directly record into my computer, my computer doesn't have any midi in/out.
I bought a Behinger MX400 4 channel mixer.....
I have a tascam 4 track portastudio
Am I supposed to record them with the midi out/thru or through the headphone output?
Totally confused with this.
Andrew
PostPosted: Thu Aug 16, 2007 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
You need some sort of audio interface for you PC. Many come with a built in midi interface too. Most of such products also come with a lot of bundled software.
Something like this: http://www.echoaudio.com/Products/FireWire/AudioFire4/specs.php
or:
http://www.emu.com/products/product.asp?category=610&subcategory=611&product=15185
strms
PostPosted: Thu Aug 16, 2007 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just ended up buying a midi to usb cable today, it will work.
jksuperstar
G2 patch files: 18
PostPosted: Thu Aug 16, 2007 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
MIDI does not do audio. It contains only the information that, for example, a musical score would have. MIDI was developed in the early 80's. Long before computers were doing anything near quality audio.
G2 patch files: 626
PostPosted: Thu Aug 16, 2007 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
It will let you play the drum machine and synth from a midi sequencer on the PC.
To record the sound, you will need to take the L R outputs of the Drum machine and Micron to your mixer, then take the L R out of the mixer into the PC audio in.
What recording/sequencing software are you using?
strms
PostPosted: Fri Aug 17, 2007 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
audacity and fl studio
strms
PostPosted: Fri Aug 17, 2007 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I pretty much already did that....the mixer doesn't have l/r output or input, its 1/4" phone jacks I think.
www.myspace.com/awbproject - tester, thats the song I made with the line in on my computer.
EdisonRex
Audio files: 172
PostPosted: Fri Aug 17, 2007 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
You might need to visit Radio Shack to get some adaptors.
Garret: It's so retro.
strms
PostPosted: Fri Aug 17, 2007 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
so you mean.... the l/r outputs have higher audio output quality? Those adapters are pretty cheap.
EdisonRex
Audio files: 172
PostPosted: Fri Aug 17, 2007 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Let's put it this way.
The mixer takes the signals from your synthesizer and drum machine and allows to to mix, or combine, them, as well as position them in the stereo field (using the pan controls). Also allows you to colour the tone using the equalisation controls.
The output of the mixer is what you need to record. So you need to look at those outputs. Depending on the mixer, they could be RCA (phono) jacks, they could be 1/4" phone jacks, or they could be XLR balanced output jacks. In any case, they are all "line level", or of suitable amplitude (volume) to serve as input to your computer's sound card.
However the sound card probably uses 1/8" mini-phone jacks, and stereo to boot, so you'll need an adaptor. Radio Shack carries these, most computer stores would have them too, but usually they are mini-phono stereo to RCA, so you might need RCA to 1/4" phone jacks. Not knowing the mixer, I couldn't tell you for sure.
strms
PostPosted: Fri Aug 17, 2007 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I already have 2 1/8" to 1/8" cables, and two 1/8" - 1/4" adapters. So I can take the output from the mixer and plug it into the line in on my computer. I have that much figured out. When I recorded that "song" yesterday, the sound got somewhat distorted, I really don't know how or why. I'll figure it out don't worry I guess.
EdisonRex
Audio files: 172
PostPosted: Mon Aug 20, 2007 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Levels are too high. Turn down both the mixer output, but especially the computer input. Especially turn down the computer input. You will hear less noise if your sources are loud and your inputs are low.
strms
PostPosted: Mon Aug 20, 2007 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
O.K.
dewdrop_world
PostPosted: Tue Aug 21, 2007 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
To be more specific... the audio interface has to convert the analog signal from the mixing board to digital. Digital audio has a fixed range of amplitude values it can handle. If the voltage coming in goes out of that range, the digital stream will be clipped to the minimum and maximum values.
The only way to fix it is to make sure the input signal to the computer is not too loud. Audio interfaces don't magically adjust the input volume for you.
Have you read any material on digital audio basics? A quick google search on "digital audio tutorial" turned up some useful documents.
I strongly recommend you check some of this out. Recording audio (analog or digital) requires some specialist knowledge... not too hard to learn but you should be prepared to put the time into it if you want to get good results.
James
dewdrop_world
PostPosted: Tue Aug 21, 2007 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
This one isn't everything you need to know, but it's a decent start.
Digital Audio Primer
Also a couple of nice ones from Wikipedia:
http://en.wikipedia.org/wiki/Digital_audio
http://en.wikipedia.org/wiki/Pulse-code_modulation - still the most typical way of converting analog audio into digital (and vice versa)
http://en.wikipedia.org/wiki/Analog_sound_vs._digital_sound - a bit of a weird article but it does contain some useful concepts
James
