 Forum index » Clavia Nord Modular » G2 Performances - Noodles
Sub Wave Therapy
Page 1 of 1 [10 Posts]
iPassenger
G2 patch files: 78
PostPosted: Wed Aug 22, 2007 2:42 pm    Post subject: Sub Wave Therapy Reply with quote  Mark this post and the followings unread
A noodle, loosely based on the KLEE sequencer, revised version of sample stored here:
http://www.electro-music.com/forum/topic-20036.html
Sub Wave Therapy.prf2
Hope u like.
 Filename:  Sub Wave Therapy.prf2
 Filesize:  8.79 KB
 Downloaded:  1982 Time(s)
iP (Ross)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Aug 22, 2007 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is excellent. Thanks.
gomidas
G2 patch files: 6
PostPosted: Thu Aug 23, 2007 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice and peaceful...
PostPosted: Sat Aug 25, 2007 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice patch indeed !
Audio files: 229
PostPosted: Sat Aug 25, 2007 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice; I like it too. I don't see all that much of a connection to the Klee architecture though. I'm sure it's in there.
PostPosted: Sat Aug 25, 2007 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
The klee cell is in the upper left, four clocked delays and a 4 input mixer, this is the Klee Classic kernel (or much like it at least), not the Klee-2 one (which has 16 pots).
Audio files: 229
PostPosted: Sat Aug 25, 2007 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I can see that now. Very Happy
iPassenger
G2 patch files: 78
PostPosted: Sun Aug 26, 2007 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, thanks for all the nice comments.
I wasn't entirely sure if it was Klee or not, I had a look at a couple of patches already on here (Blue hell/mosc) on here and figured out what i thought was the klee-y bit of those patches, a lot of the technical klee thread elsewhere on the forum kind of lost me a bit, other than it had something to do with delayed signal looping. Amazing how the nord can make something relatively complex seem relatively simple.
Glad to know i was right in my assumptions. Smile
Hey Blue, what this about 16 pots? how does this one differ? from the 4 delay thingy.
iP (Ross)
PostPosted: Sun Aug 26, 2007 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Instead of the 4 sample delays each delaying for four samples and then looping back on itself you make 16 discrete delays all delaying one step (i.e. you can use s&h modules with a biphase clock instead of delay modules) and then all the 16 outputs go into attenuators that you sum. When one bit is running round this is equivalent to an "ordinary" sequencer but once you have more bits in the loop it gets a sort of a generalized sequencer, that is the Klee principle Very Happy
iPassenger
G2 patch files: 78
PostPosted: Mon Aug 27, 2007 1:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahh i see.
Cheers.
R
iP (Ross)
