abis
Joined: Apr 28, 2007 Posts: 35 Location: Toronto, Ontario
Posted: Fri Aug 24, 2007 8:18 am Post subject:
Brushed Aluminum |
I just made my first attempt at brushing aluminum and it went quite well, I must say. I was wondering if anyone could recommend a product I could use to seal the aluminum. I plan on printing up a decal as per Thomas Henry's Nuts and Volts article. (the link for that appears to have been lost btw.)
Here is the link to the tutorial I followed for the brushed aluminum:
http://forums.bit-tech.net/showthread.php?t=114028
Andrew |
Photon
Posted: Fri Aug 24, 2007 9:58 am Post subject:
This is the stuff:
http://www.permalac.com/
I've been using it on my brass panels to keep them from oxidizing and it works great. I use the matte finish. expensive but was worth it for me. _________________ Freq Out
o---------------<>---------------o
flickr |
goldenechos
Joined: Jun 06, 2007 Posts: 201 Location: Marshall, NC
Posted: Sun Aug 26, 2007 5:36 am Post subject:
I have been brushing aluminum and I have not found anything that works well to prevent oxidizing... I have tried clear laquer as well as a spray on clear POLY both in matte finishes. The metal looked AWESOME that day, but has since small patches of what I presume to be oxidization. These were small freckles of discoloration...
So I put the POLY on thicker and I am getting almmost no oxidization BUT, the look of the metal is not as pleasing... the thick coat of POLY obscures much of the brushing and gives the metal a more grey, plain look.
Permalac looks promising, and yes it is about 3 tmies the cost, but if it works, it will be worth it!
Please share if you have other success.
TR |
Photon
goldenechos
Posted: Sun Aug 26, 2007 7:15 am Post subject:
UPDATE. Just had a chat with my Dad about this... he works on hot rods and custom cars. He shot down the spray on POLY as he said that it WILL YELLOW with age. This could be desirable to some, but if you are trying to preserve a look, it will obviously not be good.
He sugested a clear laquer... appparently I was using clear enamel, which, he said, will not do a very good job at preventing oxidization.
BTW...
Photon your work is beautiful. It has this steampunk vibe that is too often missing from modular panels.
TR |
Photon
Posted: Sun Aug 26, 2007 7:26 am Post subject:
Yeah, Permalac is a laquer. I'm pretty sure thats what the 'lac' part refers to  _________________ Freq Out
flickr |
Clack
Joined: Aug 08, 2005 Posts: 438 Location: Walthamstow - london
Posted: Mon Aug 27, 2007 4:03 am Post subject:
Hello,
Do you think the 'clear laquer' spray paint you can get in car shops would work?
sorry to budge in, maybe off topic, but is it possible to etch aluminum with ferric chloride? I have some of that laying around with some press'n'peel _________________ Clacktronics.co.uk |
Joined: Apr 03, 2004 Posts: 24499 Location: The Netherlands, Enschede
Posted: Mon Aug 27, 2007 4:31 am Post subject:
| Mr Clack wrote: | | is it possible to etch aluminum with ferric chloride? |
http://www.finishing.com/205/56.shtml suggests it is. _________________ Jan
Photon
Posted: Mon Aug 27, 2007 5:41 am Post subject:
| Mr Clack wrote: |
I imagine it would. I probably would have tried it if I hadn't stumbled across the other first.
| Mr Clack wrote: |
sorry to budge in, maybe off topic, but is it possible to etch aluminum with ferric chloride? I have some of that laying around with some press'n'peel |
It's worth a try. You may need a stronger concentration than is sold for PCB etching. I guess experimentation is key here. |
goldenechos
Posted: Mon Aug 27, 2007 8:24 am Post subject:
Check out Galv-etch as well if you are into etching Aluminum.
I have been wanting to try this as it is an enviromentally sane method of etching metal.
Works on Brass as well Photon.
TR |
markusw
Joined: Jun 16, 2007 Posts: 23 Location: Vienna/Austria
Posted: Thu Aug 30, 2007 6:55 am Post subject:
This one was done with photo resist and exposure through an ink jet transparency. Developing was done with 1% NaOH, etching with ferric chloride (slightly lower concentration than I use for PCB's).
Finally, I put on a clear coat of "Zapon" laquer. Zapon laquers, as far as I know, are nitro cellulose-based. They are supposed not to get yellow over time.
So far this seems to be true.
Regards,
Markus |
Photon
Posted: Thu Aug 30, 2007 7:10 am Post subject:
Markus
Great job! Absolutely magnificent! |
Dan Lavin
Joined: Nov 09, 2006 Posts: 649 Location: Spring Lake, Mi, USA
Audio files: 21
Posted: Thu Aug 30, 2007 7:24 am Post subject:
Markus,
That is freakin' amazing!  |
markusw
Posted: Thu Aug 30, 2007 7:47 am Post subject:
Glad you like it
The only drawback: you really need some good ventilation because that photoresist doesn't smell very healthy. Ideally, you also should have some kind of stove to dry the photo resist at IIRC 60°C for about 15 min.
The photo resist btw is them same type used for PCB's.
For exposure (like for my PCB's) I used a standard 250W bulb. It takes about 10 min to develop, but since I don't do enclosures on a large scale this isn't a problem.
Developing and etching is pretty straightforward. |
Unkie Al
Joined: Nov 02, 2007 Posts: 24 Location: Washington DC
goldenechos
Posted: Thu Nov 08, 2007 5:17 am Post subject:
I did something like an engine turn finish using a dremmel. I did not like it though... too distracting to look at, and the printing on the panel was hard to read.
Tony |
